Question about Viking VDSC365-6B Dual Fuel (Electric and Gas) Kitchen Range
I have an VDSC364 dual fuel open burner viking range and the front left burner will not click when turned on. The gas does come on. I replaced the igniter but there does not seem to be any current getting to the igniter. There is a green wire not attached to anything. Any suggestions?
  • jpepitone287 Oct 09, 2010
    What does the green wire attach to?
    3 of the 4 burners get spark. it is only the front left burner that does not get spark. If the spark module was bad the 3 operating burners would not get spark
    The 4th burner does not click but the gas does come on. The igniter is not giving off spark.
  • 2,272 Answers
ear clicking but there's no ignition.First thing to do in this case are the following observation checks which do not require any tools, instruments, or taking anything apart.
  1. Check the spark color. A healthy ignition system will produce crisp blue sparks. A weak ignition system, on the other hand, will produce light blue, almost white sparks. The following two checks can be made by switching the suspected burner with a known operating burner:
    • Ignite the burner with a match to verify proper gas supply and air shutter adjustment. Make sure the flame is a clean blue flame, not yellow and sooty.
    • The gap between the ignitor and the burner base is too large. It should be about the thickness of two dimes.
    • Gookus is caked on the ignitor or burner base. Clean the burner caps, heads, flame spreaders, ignitors...that whole area. HINT: do not use stuff like Comet because you'll gunk everything up big time. Warm water and Basic-H are a good choice.
    These following two checks are done by physical inspection "under the hood":
    • Loose wiring connections at the ignitor, the grounding strap, or spark module.
    • Broken or pinched ignitor wire between the burner and module.
  2. Check the spark frequency. Say what? A healthy spark system will crank out three to five sparks per second. If yours is a lot slower than this, then the prime suspect is reverse polarity at the 120vac outlet the range is plugged into. The picture below shows a 120vac outlet with the proper polarity.
You hear clicking but it's erratic.I have an VDSC364 dual - tn_sparkmoduleflowdiag1.jpgThis is usually a bad spark module. But first, verify that the outlet polarity is correct before you change the module.This flow chart gives you further guidance on troubleshooting erratic spark problems.
You don't have ignition and you don't even hear clicking.:-First, verify that the spark module is getting the 120v on terminal L when you turn on any one of the surface switches. If it is, and still no spark, that module is dead--replace it.
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation
Posted on Oct 08, 2010
  • raj somaiya
    raj somaiya Oct 09, 2010
    If 3 of the 4 burners light, but the 4th burner just clicks with no ignition, then make sure that the valve is completely clear of any debris that could be blocking the flow of gas.Also check and make sure the igniter is giving off spark. Make sure while you are cleaning, that you did not accidentally bend the position of the ignitor too far away from the gas exit valve.
Where can I locate the model number on my viking range? (48")
Mine was located to the left of the top burners. Remove the grates covering the burners, remove the 'spill' pans, lift up the surface that held the spill pans and then on the LHS you should see a plate with your units details.
Jan 20, 2010 | Viking 48" 6 Burner, Griddle Professional...
Had no gas coming into the oven of my Viking 305. bought a new dual thermal valve and replaced it. now i have small flame on left burner and none on right. right after installation, flame was strong for...
Are the burners on top getting enough gas? Is there enough gas coming out of the wall? Did you purchase the correct dual valve? Is the orifice sizing correct? Make sure the holes are not plugged on the burners. And u should also check to see if your line has debris in it. Either unplug the holes or check the pressure out of the line in the wall. What makes you think the right one isn't getting enough gas? Could it be an ignitor? Anyways, the burners have a 5 yr warranty. Try replacing those. Good luck.
Apr 28, 2009 | Viking VDSC365-6B Dual Fuel (Electric and...
Gas cooktop clicks while we are using it
They will all click everytime you ignite a burner. The clicking will stop when you turn the knob past the ignite setting to high, medium, low.
Apr 01, 2009 | Viking VDSC365-6B Dual Fuel (Electric and...
Ignitor won't shut off
The Viking manual says that an ignitor that continues to try to light even after the burner has been lit indicates improper grounding, and that an electrician should be consulted.
Perhaps you could try to replace the ignitor, and see if that fixes the problem?
I have a similar age, 6-burner 36" rangetop.
Sep 30, 2008 | Viking 48" 6 Burner, Grill Professional...
36 inch range gas not flowing to both burners
I am having the same problem with my oven. One burner comes lights on just one side. Then the second one comes on. Just one side. After a while both side get lit. My concern is unburnt fuel coming out of the oven. Going to trying taking the burner out and cleaning the ports
Sep 18, 2008 | Viking VDSC365-6B Dual Fuel (Electric and...
Burner
You probably have an open or shorted igniter that burner. Check the igniter if defective replace it.
Sep 15, 2007 | Viking VDSC365-6B Dual Fuel (Electric and...
Viking Range
Juliac, the burner valve switch for that burner is either shorted or grounding out. Each burner control has a valve switch that controls the power to the igniter. Sometimes they just get full of gunk and short. Part number is PA020015. Catriver...post back.
Nov 09, 2006 | Viking VDSC365-6B Dual Fuel (Electric and...
Viking VDSC365-6B Dual Fuel (Electric and Gas) Kitchen Range Logo
132 people viewed this question
Top Viking Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Viking Kitchen Range Expert? Answer questions, earn points and help others
