Question about JVC Ksax4302 Bridgable 4-Channel Power Amplifier with 600 Watts Max. Music Power
I just bought a VC KS-AX4302 amplifier. When hooked up to power, the amp immediately turns on and the deck turns on and starts playing music, with no key in the ignition. Both stay on until the power is disconnected. I am using all of the same hook-ups from my old amp, which did not exhibit this problem.
  • 447 Answers
You must have gotten the power lines mixed up. You need to connect the power to the amp and radio the the switched side of the power supply. Or, you connected the amp power and the amp switch wire, usually the blue wire in reverse.
Posted on Oct 08, 2010
My jvc ks-ax4302 goes straight to protection when I turn it on, just curious what could be the cause and where could I find a schematic of the mother board?
If the Power/Protect LED is red, usually the speaker wiring has a short-circuit or the speaker total impedance is wrong for the system. The most common issue is a bare spot on a speaker wire that is coming in contact with part of the car or another bare wire. Sometimes, it just means that the system got too hot.
Before you look for a problem with the KS-AX4302 board, look at your wiring and replace any damaged wires.
I hope this helps.
Apr 11, 2015 | JVC Car Audio & Video
My amp stopped workin, when i turn the stereo on, the green light is on, then when the music starts to play it turns red and stops working,
The red light on amplifier relates to power supply while the green light is indication of sound functionality. An amplifier that allows sound to generate should display both red and green lights. Howeever, some amplifiers would display only green as long as the sound is functioning.
Solving the problem
First, a red light still on means the power connections to the amplifier is fucntional least requirng repairs.
Second, the green ligh should turn on once the stereo were tuned up to produce sound. If the stereo is still on only least produce sound on the amplifier, check on the connection wires between stereo to amplifier that may have disconnected due to woofing or dubbing sound generals with unfirm wiring.
Third,
Jan 28, 2011 | JVC KS-AR7501D Car Amp
Car subwoofer amp powerup problem, insufficient remote voltage
Your deck sends 4.5 volts only through the rca jacks to send musical information to the amp,which is a good musical signal. On the rear of the deck there should be a blue wire called a remote turn on( or antenna or amp turn on ). Any of these wires send a 12 volt signal to whatever you hook them up to. run a wire from any of these wires that were just mentioned to the remote terminal on the amp, whenever you turn on the deck it should turn on the amp now. If for some reason your deck does not have any of these wires you can run a wire to the fuse box and pull the fuse that is designated for the radio-twist your wire over one prong of the fuse and insert the fuse back into its spot and turn your vehicle on- you may need to reprogram your radio but probably not depends on how you have it wired up-anyhow in this configuration every time you turn on the key to the acc or start it up it should turn your amp on .
Jan 25, 2010 | Car Audio & Video
Amp power protector comes on
Dis connect the sub then turn it on, don't let the wires touch or it will have a problem. If your lucky, it's just your sub that needs replaced. If not, your amp needs serviced. Rockford use to have a three year warranty... I'm not sure what they have now since mass merchants beat up the line. Hope this helps
Jun 02, 2009 | Car Audio & Video
I have a rockford fosgate 501bd amp the protect light comes on when my deck turns on even with no speakers connected
un hook the subs and let the amp sit there on if the protect light shuts off you wired your subs wrong if it doesnt go off tun it off then back on with no sub music all the way down then slowly turn the music up if the light is off then comes on you need new rcas
May 03, 2009 | Rockford Fosgate Power 501BD Car Audio...
Sony output problem
All i did was mess with the REM wire, and found out i had to hook the REM wire to the blue/white wire on the deck. Instead of the blue/white wire, i had it hooked up to the solid blue wire on the deck which was preventing my amp from playing on CD.
Nov 22, 2008 | Sony TA-E9000ES Amplifier
My amp keeps going into protective mode.
try to lower the SLA option on ur deck maybe the amp is pulling to much current from the battery try putting a battery with more AMPS
Jan 06, 2006 | Jensen LXA400 Car Audio Amplifier
JVC Ksax4302 Bridgable 4-Channel Power Amplifier with 600 Watts Max. Music Power Logo
77 people viewed this question
Top JVC Car Audio & Video Experts
xxxxxx xxx
Tygh Duval
Tygh Duval
Are you a JVC Car Audio and Video Expert? Answer questions, earn points and help others
