Question about Canon EOS-AE-1 35mm SLR Camera
My canon AE 1 shutter is not firing, the button will press down but when I pull back to advance the camera it just won't work.
    Brigadier General:
  • 3,006 Answers
That is normally a classic indication of a failed battery. Try a new 4SR44 battery.
If you are absolutely certain that it cannot be the battery, then your camera is most likely in need of a full professional CLA service (Clean, Lubricate, Adjust). The internal lubricant films dry out over about 30 years of use and gum up the mechanism.
A professional repair costs far more than the camera is worth, and most repairers won't attempt this on your non-functional model unless you agree to pay up front due to the possibility of carrying out work only to find a more serious fault (unusual on the AE1 as it's well built, but still possible). Although the repair may not make economic sense, if it works then you'll have a camera which should be good for many more years and which can still produce results which will put a digital SLR to shame, especially if you shoot on transparencies and then scan them. Plus there's all those nice, cheap/free, used FD lenses lying around...
Posted on Oct 08, 2010
Canon AE-1 program shutter fires when cocked
Unless you are a camera technician, this is a problem that has to go in for repair. The mechanical hold is defective or broken. Please weigh the cost of repair vs buying a used camera
You can buy a used/refurbished AE-1 Program in the $80-$140 range. Call several repair places by looking on the internet, some will give a free repair estimate.
Jan 22, 2014 | Canon EOS-AE-1 35mm SLR Camera
Hi , I have a Canon AE-1 camera and I'm haviving a problem with the film advance lever . It seems to be stuck . It will not advance. Have you ever come across this problem before? Thanks ,John.
Canon AE-1 35mm SLR is a manual focus camera EOS is Canon's designation of auto focus EOS stands for Electro-Optical System. The problem you are experiencing is caused by several little things that throws the camera, wind and cocking leaver out of synchronization or simply come to the end of the roll. There is a frame counter window just to the left of the shutter release behind the shutter speed dial. Also if you have just loaded film in the camera it may not be seated correctly check by releasing the rewind button, wind the film back but not all the way and open the camera to restart the film.
Diagram
Mar 03, 2011 | Canon EOS-AE-1 35mm SLR Camera
Where is the shutter release button on a Canon AE-1? I am trying to load film in the camera, and the shutter crank "thing" is stuck. do i need to release it with a press of a button???
Did you actually mean shutter release or shutter advance? And to load the film,you need to pull the roll winder upwards. While you pull the winder upwards, it would have a tuck voice and then the back cover would open up. Make sure you have wound the entire roll before you open the back.
Jan 23, 2011 | Canon EOS-AE-1 35mm SLR Camera
I cannot press down the shutter release and the film advance tab will not move, therefore making it impossible for me to take photos. Please help.
I guess it is actually an AE1 and not an EOS, as EOS is a digital camera! You will have to scrap the film in the camera by opening the back and removing the film. Take out the film can, then pull the film off the take up spool press the windback button on the bottom of the camera. This should get it working again. Try a few shutter releases and wind ons before putting a new film in. If you have important images on the film you don't wan to lose just do the above in complete darkness, and wind the loose film back into the can using the knob at the bottom.
Jan 04, 2011 | Canon EOS-AE-1 35mm SLR Camera
My shutter release button is not working, instead the shutter is being released when I use the film advance lever.
Your camera has a bad magnet in the body.
Repairs will cost more than probably what you paid for it; I'd suggest getting a replacement (I got a Canon AE-1 Program for $40 on craigslist, ebay has good prices)
Nov 11, 2009 | Canon EOS-AE-1 35mm SLR Camera
Have a Canon AE-1 Program that I've received yesterday.. while taking it out for a shoot, a problem occured: Everytime I would Advance the lever to the next exposure it would take a photograph as if the...
Camera has a bad magnet, the A series were plagued by this.
Repairs will cost more than probably what it's worth.
The AE-1's used an electromagnet system to activate the shutter for a smoother press and less shake from the camera system.
I got lucky and recently purchased an AE-1 program that doesn't have this problem, it seems to be a hit and miss with these.
Oct 17, 2009 | Canon EOS-AE-1 35mm SLR Camera
Canon AE1 program film advance locked
The cost of fixing is almost the same as buying a used or refurbished AE-1 about $80-120
Dec 21, 2008 | Canon EOS-AE-1 35mm SLR Camera
When we advance film, it takes a picture
The problem is usually caused by a dirty release magnet. I can tell you how to fix it if you are handy with small tools
Feb 03, 2008 | Canon EOS-AE-1 35mm SLR Camera
Canon ae-1
To open the back pull on the rewind knob ( pulling up ) until back opens. Check that your 6 volt battery is ok ( ae -1 has an electronic shutter so will not work without a battery ): battery situated on the left hand side of the camera ( if it is facing you ) underneath small flip up door ( lock is at the bottom on the left of the small door ) . Check the battery by pressing the shutter release gently and seeing if your light meter needle moves. No movement ? replace battery. You have two modes for taking pictures : auto which is actually AV ( aperture priority) or full manual : both are set by moving the shutter speed dial on the top right hand side ( underneath film winding lever ).
Sep 16, 2007 | Canon EOS-AE-1 35mm SLR Camera
Canon EOS-AE-1 35mm SLR Camera Logo
177 people viewed this question
Top Canon Photography Experts
old marine
old marine
pontelemon
pontelemon
David Payne
David Payne
Are you a Canon Photography Expert? Answer questions, earn points and help others
