Washer fills with water. then does nothing. - Washing Machines
    Master:
  • 400 Answers
Most likely this is a problem caused by a faulty timer mechanism. It is a device that is best replaced by a service agent and will cost around $150 to replace. It is possible to access the timer panel from the rear of the machine, removing the top plate and exposing the electronics that control the operation. There is also a solenoid, but to determine the cause of inoperation between cycles, such as you've outlined, only a technician can determine which module is malfunctioning.
Posted on Oct 08, 2010
MY FRIGIDAIRE FRONT LOAD WASHER WONT FILL WITH WATER OR SPIN . HAVE TRIED CLEANING THE DOOR LOCK & UNPLUGGING IT FOR EXTENDED PERIODS OF TIME.
Sounds like the fill water solenoid has bust, they are cheap to replace and fairly easy. make sure you disconnect from power supply and water supply before trying.
Jan 30, 2014 | Frigidaire GLTF2940ES Front Load Washer
Water fills the tub then nothing happens.
it does not aggitate? Thats the cycle that allows the water to wash the clothes. It may be broken, I have had that happen a couple times. I would take the aggitator off and see if the teeth in the groves are worn out, It happen's when used alot. Commen problem and easy to replace.
Apr 05, 2009 | Maytag Ensignia MAV2757AWW Top Load Washer
Washer fills then stops
there are contacts that are in the timer that get arched and don't make good contact. also there is a set down by the motor that sometimes mess up and stop working you can use some emery cloth to clean the contacts. good luck.
Jan 12, 2009 | Washing Machines
Washer will not fill
not your timer / if anything its eather the water valve or the water slector switch
Nov 23, 2008 | Kenmore 24032\24036 Top Load Washer
Frigidaire top load washer FWS933FS not filling
cold water has nothing to do with the water level this is the normal level for this machine
Apr 16, 2008 | Washing Machines
Smeg washer/dryer not filling
Check the pressure switch, aka water level switch. If this isn't the problem, it may be the water valve.
Mar 26, 2008 | Washing Machines
Washer filled with water & then stopped & will not work in any cycle.
could be a bad pressure switch did it fill all the way is it a top loader or front loader any noise or nothing
Dec 31, 2007 | Kenmore 24622 Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
