Question about John Deere Tractor 520, 530, 620, ITJD16
How do I properly jump start a john deere 620 tractor
SOURCE: JOHN DEERE TRACTOR - MODEL A - SERIAL 642202 CLUTCH REPAIR
Try the John Deere web site, I think they will be able to help. donnyb60
Posted on Mar 21, 2009
  • 10865 Answers
SOURCE: john deere 420 trouble starting getting gas and
The engine needs air, so be sure the air filter is clean. If it is not, replace it.
The engine needs spark. Replace the spark plug and be sure that the battery has a complete charge.
The engine needs good fuel so be sure the gas is newly purchased, not gas that has been sitting around for months.
Posted on May 19, 2009
wilsodfarm
  • 986 Answers
SOURCE: 3020 carburetor ? john deere gas tractor, 3020
those carbs are real simple you will not have any problem
Posted on Jul 29, 2009
rwvanlue
  • 486 Answers
SOURCE: I have a John deere 317 tractor that does not start.
We will be testing for voltage to the points, coil, engine to tractor wiring harness, ignition switch
Tools needed:
volt meter to read 12 volts, or test light
1) with the points open: is there voltage at the connection wire at the points
If yes; adjust points to .020" and try to crank engine and check for spark
*** you may want to determine if condensor is connected to this wire also
if no
2) check point side (neg or - ) of coil for voltage
if yes, engine should start
if no
3) check for voltage at the + side of coil
If yes, coil is bad
if no
4) check wire connector from engine to frame wiring harness
if yes; engine should start
if no
5) check wiring on the back of ignition switch
if no
6) check that ignition switch RED or BATTERY supply wire has voltage
if yes; switch is bad
if no
7) check supply wire and circuit breaker connected to the battery side of the solenoid
if no; circuit breaker could be at fault or wire connector at battery supply
Posted on Nov 08, 2009
nova2nv
  • 197 Answers
SOURCE: adjusting John deere ''Sabre'' model deck
Move machine to flat/level surface,with deck raised put a 2x4 between rear of deck and ground.Make sure that the 2x4 goes all the way under deck from one side too the other.Once that is done lower deck all the way and make sure lift lever is all the way forward.Then on the rear top side of deck loosen bolt that holds arm to deck bracket,pull bracket as far down as you can then retighten bolt.This is also the point where you can level deck side to side.
Posted on May 05, 2010
How can I get a wiring diagram for a John Deere 620 tractor?
gotta be a JD Forum on the internet that can help.
Sep 08, 2015 | John Deere Garden
John deere lawn tractor. Had a dead battery. my son tried to jump it but cables got hooked up backwards, cranked 10 sec. Now turns over but wont start and smokes under the flywheel
Because he shorted out the alternator under the flywheel. There also maybe other damage as these are not protected from reversed voltage.
Apr 30, 2015 | John Deere Garden
Have john deere gator cx it won't start, I have
My older cx won't even turn over.. Totally dead..
lights work so ignition system ok..
battery is new and hot..
fuses all ok..
Stated and ran fine through two pastures.. Turned off to fix fence..
now not a peep..
Aug 18, 2013 | John Deere 420,1020,2010,2020,2510,2520...
John Deer L130 lawn tractor: Start with jumper on solenoid.
i would check the safety switches you can jump them and find the bad one
Mar 28, 2012 | John Deere Garden
Can I jump start a john deere?
Yes... just make sure that you have the battery voltages the same and that the Pos. and Neg. are lined up correctly...
heatman101
Aug 13, 2011 | John Deere 420,1020,2010,2020,2510,2520...
John deere 316 won't start
not sure but i think check the battery i am fighting the same problem and i jumped it from my truck and it runs fine i am looking for a battery tto dya
Apr 21, 2010 | John Deere 420,1020,2010,2020,2510,2520...
John deere 425 lawn tractor. it wont start but it has spark and fuel the starter engages and the fly wheel turns
If your tractor has an anti back fire solenoid in the front of the carburetor then it should start if you remove it and cap it off with a pipe plug.It should run if the solenoid is the problem,if so you really should replace it but if it is'nt prone to backfiring with it remove you don't have to.You may also have a bad seat switch,confirm this by jumping the plug with a piece of wire to temporarily test it.
Jan 14, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Tractor shuts off.
IF THE SEAT SWICH IS GOOD THAN THE BRAKE SWICH IS BAD
Oct 10, 2009 | John Deere Garden
John Deere Tractor 520, 530, 620, ITJD16 Logo
79 people viewed this question
Top John Deere Toys Experts
Jim Goldsmith
Jim Goldsmith
john h
Charles T Nevin
Charles T Nevin
Are you a John Deere Toy Expert? Answer questions, earn points and help others
