Question about Kenmore 36 in. 33212 / 33214 / 33219 Gas Cooktop
Will not light - Kenmore 36 in. 33212 / 33214 / 33219 Gas Cooktop
    Master:
  • 413 Answers
Have you removed the burners covers and top to see if the PILOT LIGHTS may have blown out? Hold a stick match or fireplace match (long stick) down in the area of the circular burner after turning on some gas. The burner should light and the pilot light should stay on as well. You local gas company provides service for this type of problem. Call them and have a gas company representative make a home call (free service) in most areas.
Posted on Oct 08, 2010
Burners slow to light
clogged fuel lines
Mar 18, 2014 | DCS Cooktops
Cda gas hob Pilot light not sparking to light hob, can use a match to light burners no problem.
IS THE POWER TO THE HOB ON ?
IF SO IS THE FUSE OK ?
IS THE PLUG WIRED CORRECTLY ?
TRY THESE FIRST, IF NO JOY YOU CAN DOWNLOAD YOUR PRODUCT GUIDE FROM CDA ON LINE
Dec 27, 2013 | CDA 4X4SS Cooktop
My GE glass cooktop has a red light that goes on when in use (not theburner indicator light but a general light as soon as you turn one of the knobs. For some reason, today it is dimly on--even though...
I assume you are talking about general pilot light which illuminates when you turn any of the four hotplates on. This light gets its power supply from the hotplate contollers. The controllers generally have a pilot light circuit which links all 4 controllers to the pilot light. I haven't seen this problem before. Either a small amount of power is escaping across the pilot light contacts inside the controller or the pilot light is getting a feedback from another source/fault in the cooktop. The only solution is to dismantle the cooktop and use a voltmeter or similar to trace the fault. Unless you understand how the problem occurs it's probably best to call a repairman.
Feb 11, 2011 | GE Cooktops
My oven want light its gas and the the pilot light islit
Is this a standard gas cook-top there maybe some small particle blocking the area where the gas comes out and lighting with the pilot. If you feel comfortable try lighting it with a match. First make sure there is not a lot of gas build open, so if there is a window near the stove open that and make you have plenty of ventilation before striking said match.
Mar 13, 2010 | Kenmore 30 in. 32384 / 32385 / 32389 Gas...
The cooktop indicator light on my Whirlpool range, model RF265LXTY, won't go off, all of the knobs are in the OFF position. The hot surface light is off.
most cook tops the light that maches the burner is on if sw is on . if light doesnot fo off replace that sw . if only one light for all burners you will have to fint the shorted one.. good luck mm ..
Dec 12, 2009 | Whirlpool RCC3024 Electric Cooktop
Pilot lights
unplug the unit if the pilot ligth is electric.then u can use manualy.
Nov 19, 2008 | Cooktops
Indesit PI 640
i find your problem is short of desame line that why it remained lighting,try to hang the connection to that light,try to find it one by one , the principle of the lighting here is like in the rice cooker when warm the light is yellow when cook it turn to red when you going to see it ,it is one connection only.there is a thermal plate ,when it sense extreme heat it will move that to switch off ,,then when it warm its switch on. maybe there is short to thermal plate or the thermal plate not working even extreme heat it will not shrink...try to find this plate .if my solution help you to understand the problem please rate me FIXYA...
thank you in advance Stevecarr.....
Jun 25, 2008 | Cooktops
Burners won't light
remove hte buerner cap and with a nail file or emory clloth try cleaning the electrode(sparker), sometimes a build up of carbon onthem will prevent proper lighting, also lool for cracks in electrode itself,if ther cracked they wont be very effective and need replacing
Feb 27, 2008 | Kenmore 30 in. 33202 / 33204 / 33209 Gas...
On Light Won't go off on cooktop
I am asuming you mean a standard cook top stove.
you should probebly unplug the range because it looks like a short circuit.
!) a shorted or failing burner/control will light to ground
2) every burrner has a fuse, unscreww each burnner fuse till light goes out. that is the problem piece.
3) change heating elements with the element of the same size on the other side of the stove.
4)put fuse back in. if light off - bad elemet - if light on - bad control
bad control - I'm not sure you want to tackle that. but call me back :)
Jan 29, 2008 | Cooktops
High performance burner slow to light
Replace that ignitor on that burner only. Not drawing enough amps to spark properly.
Nov 26, 2006 | Jenn-Air JGC8536 Gas Cooktop
Kenmore 36 in. 33212 / 33214 / 33219 Gas Cooktop Logo
224 people viewed this question
Top Kenmore Cooktops Experts
Dan Webster
Dan Webster
jdthefixer
mcgsp
Level 1 Expert
Are you a Kenmore Cooktop Expert? Answer questions, earn points and help others
