Question about General Electric GE SmartWater Household Water Filtration System - GNWH38F
I have a GE smart water heater model GG40T6A. the pilot light will not stay lit. what can i do?
  • 395 Answers
The pilot light jet may have got a little bit of dirt or grit in it which is preventing it from keeping alight. Try probing the jet with a fine piece of wire to see it the blockage can be dislodged. You may have to unscrew the jet to clear it by blowing air through it. Make sure gas is turned off first before removing any parts.
The pilot light also has a thermocouple that allows gas to the pilot light while the flame is burning. If flame goes out it shuts gas off to the pilot jet. The thermocouple is bypassed by a switch during the initial ignition and once the thermocouple warms up after a minute or two of holding in the bypass switch, it should maintain the pilot. If, after cleaning, the pilot light keeps going out, it would seem that your thermocouple is faulty and needs to be replaced
Posted on Oct 08, 2010
Does the pilot light always stay lit on this water
Many water heaters today are pilotless.
Call manufacturer with model and serial number
Gene.
Sep 04, 2013 | RTO W4 A.O Smith Gas Hot Water Heater...
Pilot light will not stay lit on GE 40 gal. gas water heater tank
You have tank-type gas water heater:
Gas water heaters need working thermocouple, adequate incoming fresh combustion air with no trace amounts of chemical, open vent to outside that drafts poison combustion product upward, clean burner tubes and combustion parts, correct gas pressure with no air in line, working gas control valve thermostat, no lockout condition such as tripped ECO caused by runaway heating and dirty combustion parts, and no lockout condition such as exposure to flammable vapors.
Open following links for troubleshoot resources:
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
http://waterheatertimer.org/pdf/Pilot-light-will-not-stay-lit.pdf
http://waterheatertimer.org/pdf/Attic-Ventilation-and-Pilot-Outage-in-Gas%20Water-Heaters.pdf
http://waterheatertimer.org/images/Water-heater-in-attic-800.jpg
http://waterheatertimer.org/images/Test-water-heater-vent-1400.jpg
Jul 30, 2011 | General Electric Water Heaters
I have a 40 galon GE Smart shield water heater, Model: SH40T12AVH00, Serial # GELN0805V13908. The pilot light is lit but the burner will not stay on for more than 2 secods and then shuts-off.
I believe this unit does not have a standing pilot light and lights each time? Have you reinstalled all doors back into the heater? It sounds like the main burner is blowing the pilot off the thermocouple. You might try replacing the thermocouple. You can download a manual here: http://products.geappliances.com/ApplProducts/Dispatcher?REQUEST=SpecPage&Sku=SG40T12AVH00
Aug 02, 2010 | General Electric GE SmartWater Household...
Pilot won't stay lit
What color is the pilot flame? Yellow/orange or blue? Look at the tip of the thermocouple where the pilot flame is heating. It should be a smooth round tip. If the tip is partially burn't off or ridgid, replace the thermocouple. After the pilot is initially lit, does the burner come on too? Take a flashlight and look up inside the water heater above the burner. Do you see a lot of soot build-up? Light a match at the top of the water heater at the draft diverter (it attaches the venting to the water heater) and blow it out and see if the smoke gets sucked into the diverter or blown out. It should get sucked in. If not you may have vent blockage or soot build-up.
May 15, 2010 | General Electric GE SmartWater Household...
Natural gas hot water heater not stying lit
Probably a bad solenoid in the gas valve. Higher voltage of a new thermocouple keeps it open longer but it still fails over a period of time. Look into a new gas valve for the water heater.
Dec 17, 2009 | General Electric GE SmartWater Household...
GE Smartwater Heater model# GG40T6A won't stay lit
Look and see if your pilots flame is touching the themocoupling ,if it isnt then cleane your pilot orfice.If that dosnt work replace thethermocoupler.I would also check the draw. Hold alit match or a cigerett up to the draft diverter (the air space between your heater and the vent. If it dosent draw the smoke up the vent it meanes your vent is stoped up or you need to raise it.
Dec 02, 2009 | General Electric GE SmartWater Household...
The pilot light & will stay lit. untill the burner cycles on/off
MAKE SURE THE BURNER TUBE AND ORIFICES ARE CLEAN. MAKE SURE YOU HAVE THE PROPER LP PRESSURE.
Oct 05, 2009 | RTO Atwood Water Heater - 6 Gal LP
Pilot Light will not remain lit
Try this, turn the black gas ****, on top of the control box, to the Pilot position. Set the temp. control on the front of the box to the desired temp. Then, hold a match or whatever else you use to light it, next to the end of the pilot, then, while holding the match to the pilot, press the reset button on top. When the pilot lights, continue to hold the reset button down for about 1 minute. Then, after a minute, turn the gas **** to the ON position, then it should remain on.
Jan 20, 2009 | Water Heaters
General Electric GE SmartWater Household Water Filtration System - GNWH38F Logo
1,531 people viewed this question
Top General Electric Water Heaters Experts
Paul Carew
Are you a General Electric Water Heater Expert? Answer questions, earn points and help others
