Question about Fujitsu fi-5120C
Fi 5120c will not scan sheets that have different color entries
We have a fi 5120c and it works great but my understanding it is a color scanner and it will not scan anything with color entries on the sheet. We have the color default set and it still only scans to black/gray. Any help with this is greatly appreciated.
  • woodsidhe Jul 31, 2008
    I have the same problem. Mine is hooked up to a USB connection. It can't be the OS, this PC was just imaged the other day.
  • 490 Answers
Check the software settings in the scanning software. Try running scandisk in the OS. Check if the scanner is working with any other comp. If it works, may be your OS is corrupted.
S. Mohan, Chennai
Posted on May 30, 2008
Fujitsu fi5120c scanning every other page
hi, it sounds like the scanner is multifeeding, and as you have it set to A4 once that length is scanned, its just getting rid of the rest and starting the new page. Try cleaning or replacing the separation pad, or to prove the fault, hold the 2nd sheet until the 1st is scanned and its trying to pick thyen 2nd.
hope that helps, let me know how you get on.
Jan 18, 2012 | Fujitsu fi-5120C
Fi 5120c scanner - Vertical Line left of Center
It is the GLASS. Line up your paper to see where the lines came from (check front side and back side). Open the scanner by pushing the Blue Button on the right. Look for the glasses at the bottom of the scanner at the spots making the lines. Clean it and re-scan.
Oct 11, 2011 | Fujitsu ScanPartner fi-5120C Pass-Through...
Hi a vertical line is in image scanned please tell me how to solve this problem thanks
The lines are due to dirty scanner mirror. The printer/ scanner design is based Sheet-Fed Scanner. Open/Lift the scanner top (by pullung it near the area where you feed the paper to scan). Look out for the horizontal mirror and use a soft, damp, lint-free cloth to gently clean the scanner mirror, rollers etc. and enjoy clear scanning!
Good Luck!
Hope this helps! Dont forget to appreciate the solution!!
CreativeTECH
Feb 14, 2011 | Fujitsu fi-5120C
The fisrt page is always black, if you scan more than one page.
If the first page output is black, it could be because of insufficient light (assuming other outputs are okay). May be the light takes more time to get 'on'. Keep the scanner in 'on' position for some time and try if the first page is black. The light has some life and check the user manual if it requires replacement.
S. Mohan, Chennai, India
Oct 15, 2009 | Fujitsu fi-5120C
Scanner keeps grabbing 2 to 3 sheets at a time when scanning
You need to clean the rubber rollers with a damp cloth thoroughly.
S. Mohan
Jul 29, 2009 | Fujitsu fi-5120C
Fuitsu 5120c
Please clean the glass with Isopropyl alcohol. Dont use solvents. S. Mohan, India
Jun 06, 2009 | Fujitsu ScanPartner fi-5120C Pass-Through...
Fi=5120c conflict with another scanner
Kindly reply back immediately once you get my email.
Nov 04, 2008 | Fujitsu ScanPartner fi-5120C Pass-Through...
Multi scan
it is only made and set up for a single scan at a time. i thought the same thing when i had one.
Jun 27, 2008 | Fujitsu fi-5120C
How to scanning double sided document in fujitsu 5120c scanner
You may want to try using Laser Fiche. This scanning software allows you to select "Duplex" which allows you to scan double sided document
Oct 23, 2007 | Fujitsu fi-5120C
Fujitsu fi-5120C Logo
151 people viewed this question
Top Fujitsu Office Equipment & Supplies Experts
Electro Med Services...
Are you a Fujitsu Office Equipment and Supply Expert? Answer questions, earn points and help others
