Question about Kenmore HE2 Plus Front Load Washer
The washer is leaking from the bottom back corner. How can this be fixed?
  • 447 Answers
This type of leak usually comes from the impeller housing. Just like on a car, the weep hole lets you know it's time to change it.
Posted on Oct 08, 2010
I HAVE A LEAK FROM RIGHT BOTTOM OF A SAMSUNG WF448AAP/XXA-000 FROMT LOAD WASHER ONLY HAPPENS DURING RINSE CYLCE
Hello Harlan;
My name is Peter. I am a retired field service appliance technician.
Your drain hose is in the back on the right hand side. This is a rubber hose. After a time the rubber may be dry rotted and leak or become partly clogged with soap residue.
Once completing the wash cycle the soapy water may have not completely drained due to a partly clogged drain hose by the time the rinse cycle is complete flooding the washer drain pan.
You do not have water in the bottom of the washer because your pump removed it all, but at a slower rate
Ok, Lets fix this ourselves:
1.) On the bottom right front of your washed is a leveling leg.
turn the leveling leg one full turn clockwise. The right front may be pitched down, causing the drain pan level on this corner to be high. Your washer through vibration may have moved slightly. This is not going to solve the problem.
2.) Pull your washing machine out so you can see the drain hose. Run some laundry on heavy load. Observe to see if your drain hose is leaking. Your hose clamps may be loose and require tightening. If it is leaking it needs to be replaced.
3.) Even if your drain hose is not leaking it must be obstructed, flooding the bottom of your unit. This is easily replaced.
The part number for your drain hose is DC97-12534D. It cast about $24.00.
Nov 24, 2014 | Samsung Washing Machines
I have model # WCSR417ODAWW. It is leaking from the bottom back corner under the waste water outlet. coming from inside the machine. The back panel doesnt seem to come off. I want to see if i can fix it..
You probably need to replace the hose to the waste drain on the wall. You may have to remove the back panel on the washer to see where the leak is.
Good Luck
Jun 30, 2011 | GE Washing Machines
Leaking water on spincycle
I have the same problem with my washer. The problem just began a few weeks ago. It is splashing out the front left corner of the tub and running down the inside of washer and then leaking out the bottom of the frame. It is just enough water to be annoying. The washer is about 6 years old.
Model: FAV6800AWW
Serial: 11277017EG
Any ideas??? Help!
Jul 27, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Washing machine leaks at bottom left corner. Water still machine after drain/spin cycyle
My GE washing machine leaks while filling up in the first cycle in the left back corner. Need help!
Jun 16, 2010 | GE Profile WPRE6100G Top Load Washer
Kenmore oasis He 27062 it is leaking out the back bottom rt corner. The hoses are connected what could be the cause
Hello,two Philips screws on the back or front corners
remove those and roll the control board up and over
you will see two clips on the each corner in back
pop those off,,,,, remember how they are positioned
once those are off you will see a two wire connector
unplug that, and the top part jump with a piece of wire
no you can roll the cabinet forward and off,
now roll the control back and turn the machine on.
Thanks
May 21, 2010 | Kenmore Oasis HE 27082 Top Load Washer
My Ultimate Care II washer starts leaking from the bottom front of the washer as soon as it starts to fill with water.
Good day,
That's almost always a bad pump. It is located in the front middle of the machine, at the bottom.
I'm enclosing a tutorial that is not limited to changing the pump, but it will get you there.
Note: The screws for the top console are located in 3 different locations. Both bottom corners, both bottom corners but hidden by two plastic end caps, and lastly, on the back.
http://www.youtube.com/watch?v=WLPGs2UMUJc&eurl=http%3A%2F%2Fappliancejunk.com%2Fforums%2Findex.php%3Ftopic%3D67.0&feature=player_embedded#t=15
Feb 09, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Getting a leak from the bottom
most likely a loose or damaged hose, pop off the top and check all hoese and connections, rarely there is a crack in the housings
Jun 14, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Maytag top loader slight leak from bottom left corner
Thank you for responding. Yes we fixed the problem. After taking off the front cover noticed the hose from the liquid bleach dispenser (which I never use) was not connected. Evidently when using the extra large load a little water would splash into the bleach dispenser, hence the small amount at bottom front left corner where dispenser is located. So simple! Glad I didn't pay for someone to attach the hose. Thanks again for your timely response. Lynn
Mar 30, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Error Code F33 after new bellow put in. How can I fix it?
Just fixed my F33 error code for GHW9400. This code is for the pressure switch HOSE. Mine had a small pin hole. Cost:: the dealer gave me a free new hose. Remove the top and back. In the top right hand corner (at the back of machine) you will see a small hose attached to the pressure switch box. It is small black& 3/8" and about 2 1/2 ft long coming out of the bottom.. Mine was not attached with anything. Pull off at the top and bottom. Look for even the tiniest hole. Hose probably can't cost a couple of dollers.
Replace and just finished my first error free load. It may be causing your leak too.
Jan 10, 2009 | Whirlpool GHW9400 Front Load Washer
Washer top
HERES A LINK TO SHOW YOU HOW
Nov 06, 2008 | Washing Machines
Kenmore HE2 Plus Front Load Washer Logo
223 people viewed this question
Sal DeAngelo
fordexpert
 Brian Main
Brian Main
