Question about HP Compaq nc6320 Notebook
MY Compaq 6910p Laptop powers on for about 3 seconds and then powers off when the battery is installed. With AC power this sequence continues nonstop. I have check the battery and the power supply with another computer and they appear to work fine. Sid007
  • 2,567 Answers
There might be a possibility that the charging circuitry on the laptop's motherboard is defective & needs servicing. In order to do this, the laptop needs to be disassembled & the motherboard checked for defective/burned out components in the area near the DC jack. Any defective/burned out components found should be replaced, or you might need to replace the laptop's motherboard altogether.
Posted on Oct 08, 2010
I have hp compaq 6910p laptop, which worked at its best for several weeks after it was bought. but few days back it started freezing, taking too much time in startup and to run programs aswel. I was t
Instructions
Plug one end of the VGA connection cable into the VGA port on the external display. Tighten the knobs on the VGA connector to secure the cable to the monitor.
Plug the other end of the VGA connection cable into the VGA port on the on your Compaq 6910P. The VGA port is located on the back of the device. Tighten the knobs on the VGA connector to secure the cable to the laptop.
Plug the external display's power cord into a wall outlet. Power on the device by clicking its "Power" button.
Boot your Compaq 6910P.
5
Click on the "Start" button in your task menu.
6
Select "Control Panel," then click "Appearance and Personalization."
7
Click "Personalization" in the window that appears.
8
Select "Display Settings."
9
Select "Mirrored" from the New Display Detected dialog box to have your displays mirror each other.
10
Select "Extended" from the New Display Detected dialog box to have your display function like one, large workspace.
11
Select "External Display Only" from the New Display Detected dialog box to use only your external monitor.
12
Click the "OK" button to keep the changes and exit the setup.
Jan 10, 2013 | HP Compaq 6910p Notebook PC PC Notebook
How can I tell if my battery is dead in my hp 6910p? I tried taking it out and then using just the power cord and I get nothing. When the battery is in and I turn on the power button I get an orange...
If nothing happens when you plug in your laptop, battery removed, you have a potentailly bad power adapter or DC power jack. Most likely it is the power adapter which is relatively inexpensive to replace (about $10). Click HERE to go to a listing of adapters for your model.
Apr 16, 2011 | HP Compaq 6910p Notebook PC PC Notebook
Hp 6910p laptop wont turn off. Fan running. what gives?
Something is keeping it from shutting down. This could be caused by a faulty application or driver. My suggestion is to hold the power button down until the unit completely shuts down. Take out the battery, unplug the ac-adapter, attempt to power it on and then put the battery back in. Attempt to restart the computer.
Good Luck!
Mar 29, 2011 | HP Compaq Business Notebook 6910p - laptop...
I Need Help Unlocking My Hp Compaq 6910p Every Time I Turn It On A Blue Screen Pop Up And It Say POWER ON PASSWORD .... PLEASE ANYONE HELP ME UNLOCK MY LAPTOP!!!!
Unfortunately HP says: "If you forget the power-on password, the computer must be reset at an HP-certified repair center. Please contact HP to schedule a repair. The Drive Lock password cannot be reset. If you lose or forget the Drive Lock password, the hard drive must be replaced. Please contact HP to order a new hard drive. These services are not covered by the warranty."
Sep 13, 2010 | HP Compaq 6910p Notebook PC PC Notebook
I have a laptop hp Compaq 6910p, and by mistake I ...
Its too risky for a user to open the laptop, access the mainboard and reset to its factory setting..
Very dangerous for the hardware too..
My suggestion is to bring your laptop to a credible technician to open your laptop, reset the cmos to its factory, and return the cover properly..
Hope you understand.
Much appreciated if you rate this help.. thanks
May 20, 2010 | HP Business Notebook 6910p Notebook
I have an hp compaq 6910p lap top which a friend has password it in the setup and i am finding it difficult to use it. what should i do to clear the password in the setup. eric
You can try to open your computer and disconnect the cmos battery for 10 minutes. this is a small battery that keep the changes saved. When you disconnect it, All changes will be lost. So also the password. This is the sequence:
1: take off the accu
2: open up the laptop
3: take the cmos (small flat round battery) out
4: Wait 10 minutes
5: plug in you adapter and boot the laptop
6: when you see that the password is gone, power off the laptop
7: plug everything back in.
8: You are done! :)
Apr 20, 2010 | HP Configurable- HP Compaq 6910p Notebook...
Problems with the ac smart adapter Hp Compaq 6910p
You could possibly have a loose dc jack.Being able to wiggle it around and getting it to work tells me that the jack is probally going out.That wiggling your doing can cause an arc on your system board,which can short out your board.Stop wiggling your power supply adapter in your dc jack and take your computer to certified repair shop and have your jack checked.Best to rule this out first ,so no damage is done to your board.If you jack test good ,then replace you power supply....Good luck
Apr 08, 2010 | HP Smart Buy- HP Compaq 6910p Notebook PC...
Used my 6910 with battery power. It evetually dies. When I got home I plugged it in and it won't turn on. Took the battery out and it still won't turn on. Get green lighting bolt but won't power up. Help
Disconnect the AC adaptor and remove the battery pack from the computer, then press and hold the power button for 30 seconds.
Second, remove the RAM module, clean the slots then reseat it.
Now, turn on the Computer by connecting the AC adaptor and with the battery out of the Computer.
Nov 20, 2009 | HP Compaq 6910p Notebook PC PC Notebook
Hp compaq 6910p BIOS Bypass
I removed the keyboard, unplugged the bios battery, holded down the power button about 30 secs, plugged back the bios battery, assembled the computer, didn't plug the battery and instead of that just plugged the ac adaptor and the bios passwd was gone =)
Oct 29, 2008 | HP Compaq Business Notebook 6910p - Core 2...
Power
Try this:
With the AC adapter and battery installed and it will not power up remove the adapter and the battery. Then plug in the
AC adapter after both have been removed for 30 seconds and let the laptop set for 30 seconds and then unplug the AC adapter and then slide in the batter within 15 seconds and try to start the laptop.
Nov 24, 2007 | Compaq Presario 900 /1500 Series EVO...
HP Compaq nc6320 Notebook Logo
109 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
