Question about Goodman GPC1342H21A Air Conditioner
I turned my ac off yesterday. I turned it back on tonight and it would not turn on. I noticed it was flashing (Change batteries) so I put new ones in. I waited till the cool on stopped flashing and it still will not work. Can you help me?
    Sergeant:
  • 270 Answers
Hi, there is nothing more aggravating than having your household appliances not work.
Like a computer, the "thermostat" (it holds the batteries) retains the information you program (maybe the technician) to set the temperature controls.
The highs and lows can normally be bypassed with the push of a button.
Removing the batteries clears the memory. (Volatile memory).
When this happens, you must reprogram the thermostat so it knows what settings to operate at.
Can you get the instructions on how to program the thermostat? The instructions are usually on a paper on the thermostat lid.
(when changing batteries, remove one battery, then put a new one in its place before removing the next one. This keep some power to prevent the settings from being cleared.
Posted on Oct 08, 2010
2008 acura mdx won't start
First, have Autozone verify the battery is indeed good. THEN, The only way i have found battery loads when the car is off is to put an ampmeter in-line with the battery while the car is NOT running and the key is OFF. Be careful to not overload meter. no lights should be on. Yeah, that means the doors must be closed. If load is low, but in meter range, have someone look at meter while removing one fuse at a time. Put each fuse back in before going to the next one. Log amp reading for each fuse that makes the meter change. I would be looking for a load above 100ma or 0.1 amp.
Nov 27, 2013 | Acura Cars & Trucks
Acer aspire 5551-2036 wont come on..
I read your description carefully, there is no dought in my mind that the motherboard is the issue,acer is well known for problems in that area and unfortuneately there is nothing more you can do, generally I find they get to hot, cooling fans fail, and numerous other situations.
Mar 23, 2012 | Computers & Internet
I turned my ac off yesterday. I turned it back on tonight and it would not turn on. I noticed it was flashing (Change batteries) so I put new ones in. I waited till the cool on stopped flashing and it...
Turn the thermostat to fan only and insure you get air blowing through the registers or feel air pulling in at the return air. If YES then make sure you have the thermostat programmed correctly to call for cooling when set to auto! Also the start/run capacitor may be failed out side at the condensor unit. They are cheap to replace but dangerous to handle so becareful. If NO then you are not getting signal to the blower and may have a failed transformer that converts 120v to 24v for the thermostat controls. Also double check your breakers in your service panel to see if they tripped for some reason. A failing or weak breaker can cause this symptom aswell!
Oct 08, 2010 | Goodman GPC1342H21A Air Conditioner
Yesterday I started having problems turning the tv back on with my remote. I noticed the power indicator blinked 10x in a row then it would pause in the off position, then start blinking again. I ended up...
Take the tv aparts.The board where the power ac cord plug into it.That ur power supply board.Check all around the power supply board and it supporting boards for these dead parts call capacitors,they're alway bulges up on it tops or puff up on it tops,u know basic electronic's and do soldering replaced those dead bulges or puff up on it tops capacitors.Or tries websites like Shopjimmy.com,Ebay.com to buy a refurbishes power supply board and it supporting boards that have dead leakage capacitors.Ur tv should have power stable and work again.
Jun 10, 2010 | Panasonic Viera TH-46PZ85U Plasma TV
Hi I have a Mini One, yesterday and tonight when I
hi it sounds like the engines electric cooling fan has automatically come on as the engine has got hot enough for it to be cooled down
you may have never noticed it before .
check your coolant level and your oil level to be on the safe side and keep an eye on the temperature gauge the fan should come on when the gauge goes past normal running teperature if its coming on a lot there may be a problem but its probably working as normal
Mar 10, 2010 | 2003 Mini Cooper
Won't turn on
have you tried radio shack?
Oct 09, 2009 | Casio EXILIM EX-Z70 Digital Camera
Trucks battery dead Nothing when turning key, no signal or lights
most likely the headlight relay is stuck    replace relay.
Mar 23, 2009 | 1995 Dodge Dakota
Lens not going in & getting stuck
TIPS:
1.)NEVER PUSH THE LENS IN AFTER CAMERA DIES, BUY A NEW BATTERY IMMEDIATLY AND TURN IT BACK ON, CLOSING THE LENS!
2.)NEVER USE AN AC ADAPTER, USE A RECHARGEABLE BATTERY OR A REGULAR BATTERY!
..to fix this...
Do as i say..
1.) Remove battery
2.) Remove front plate (screw driver may be needed)
3.) Check all gears, make sure they are correctly fitted in place)
4.) Move the gear manually to make the lens come out.
5.) keep it out, put the front plate back together.
6.) reinsert the battery, turn it on.
or...
1.) Remove the battery.
2.) Wait about 6-8 hours.
3.) Reinsert the battery.
or...
2.) Try hooking it up through AC adapter, put correct voltage.
3.) Try turning it on.
4.) Remove AC adapter, reinsert battery.
5.) Turn it on.
If nothing happens just tell me..
Hope this may help;
Regards,
VOTIT
Oct 10, 2008 | Samsung S760 Digital Camera
Zoom lense going in and out when turned on
Try taking the batteries out and plugging it in. If it powers on, put fresh batteries in and try again off the AC. Once it's powered up from the AC, unplug it and see if it stays on. If it does, try restarting it. Good luck.
Aug 18, 2007 | Olympus FE-110 Digital Camera
Goodman GPC1342H21A Air Conditioner Logo
143 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
paulcarew
Brandon Berry
Brandon Berry
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
