Question about Frigidaire ATF6000ES Front Load Washer
F5 code comes up and the washer is now halting mid cycle. Washer is 5 yrs old
    Master:
  • 400 Answers
Frigidaire has a website that contains the "function codes" for all of their appliances. Go online and using the model number of your machine, see what SUPPORT they offer for your product/model#. It may be halting because of a timer malfunction or "solenoid" malfunction which would be a problem determined by a qualified repair agent.
Frigidaire is a good company with customer service questions. Number is:1 (800) 374-4432 Monday - Friday
9:00 am - 5:30 pm (EST)
Posted on Oct 08, 2010
Sears front load washer quit mid spin cycle
hi, visit the link below, it has the information you require
http://www.shopyourway.com/questions/1083064
Jun 15, 2015 | Ovens
Kenmore he4t washer codes
The control for the washer likely detected a problem. The failure code will not be displayed on all models of washers. You can recall the error code by using this procedure:
  1. Select the "Drain/Spin" cycle.
  2. Select No Spin.
  3. Press the "Prewash" options and hold this button for 5 seconds.
  • Immediately after those 5 seconds the last stored failure code is displayed for 4 seconds.
  • After those 4 seconds the display switches automatically back to the selection mode
NOTE: If your washer does not have the Pre-Wash option. Then use the 2nd Rinse button (called Extra Rinse). The failure code should stay in the memory so that it can be recalled as often as necessary and as long as it is the youngest failure Code.
Nov 30, 2012 | Kenmore 3.8 cu. ft. HE4t Front Load Washer
I have an LG front load washer (model# wm1814cw). The machine stops mid cycle but gives no error code. I have to almost unload the washer entirely and then restart the cylce. If I try to begin the
Replaced the sensor and it rocks again. I was about to buy a new washer.
1. Remove the back panel
2. Remove the center bolt that hold the cap which covers the motor coil.
3. Pull the cover out.
4. Remove all the bolts that hold the motor coil. Be carefull not to drop the coil when you take the last bolt out.
5. Remove the old sensor and replace the new one.
6. Put back every thing and it will rock again.
Jul 22, 2012 | LG WM1814CW Front Load Washer
My maytag washer (about 4 yrs old) quits during rinsing cycle. I took the top off where the wires are to see what I could see. ;) The "buzzer non-adjust" zapped me when I touched it. Could this be what...
any time you touch live wires you will get an electric shock
always make sure you turn your power off before making any repairs.
more than likly the answer to your question is no that is not the reason why your washer stops mid cycle
it would either ne your lid switch causeing this and or if you can manually advance your timer to the next step. it is your timer that is failing.
please be careful
Aug 24, 2010 | Maytag Washing Machines
My washer will not spin out, it is not flashing
intersting when mine did this it was the pump... maqy i ask how you checked your pump? and can they be cleaned i just had to replace mine and its only 2 yrs old, i dont want to have to replace every 2 yrs
Dec 30, 2009 | Frigidaire Affinity ATF7000E Front Load...
Whirlpool frontload duet washer F 6 problem
hello cjkcp
Welcome to Fixya
You said, your washer (now 4 yrs old) occasionally stops mid cycle flashing F 6 code. Is this something we can fix or do I have to call a repair man?
F/06 Drive Motor Tachometer Error
The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin, the door will be unlocked after 3 minutes.
  • Check wire harness connections between the Drive Motor/Tachometer and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
  • Check the Drive Motor
  • Check the MCU
  • Check the Wire Harness
I believe this needs a hands on tech to daignose this. Unless you feel you undrstand the problem your self?
Thank you for using our service for advice.
Please remember to leave a rating!
Huuum
Oct 08, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Door wont lock so it's not spinning
replace the doorlock instructions come in kit
Dec 13, 2007 | Maytag Neptune MAH5500B Front Load Washer
Washer doesn't complete cycles
Sounds like an electronics problem. Get a Bosch repair person to look at it. Hopefully, they can reset the computer inside. Otherwise, it's a part that costs more than $200, as I recall, plus too much to do the work. Bosch's 1-800 person once advised me to unplug my washer - a model 2401 - for a half-hour as a way to reset the electronics. You might try that. Pray to the appliance gods. Maybe your machine is still under warranty. Trouble is, you'll probably have to wait for days until an authorized, over-priced repair person comes to visit. Bosch is way behind in service levels here in the U.S. They know it, but it's not worth their time or money to fix, it seems. A long story ....
Sep 19, 2007 | Bosch WFK 2401
Frigidaire ATF6000ES Front Load Washer Logo
42 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
