Question about Dishwashers
I have a maytag Performa pdb2600aw dishwasher and the dishes aren't coming clean. I tried vinegar, rinse agent etc. But there seems to be a film on things. I took the glasses out and cleaned them individually but as soon as I washed them again this film reappeared. i
  • Dishwashers Master
  • 43,501 Answers
Hi, I have an older dishwasher also and recently my wife alsocomplained about it not cleaning right... so me being the man I am tried invain to clean the things... Bought new spray arms online and installed them inminutes...now the thing works like new... However I have also found that if theheating element goes bad then that also can mess things up bad... So I wouldbuy new spray arms, and also check out the heating element to make sure it isworking... Here is a tip that will help you with the online buying...
Dishwasher Spray Arms not Spinning
How to Buy Appliance Parts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and seehowsimple it was. thanks Ronnie " - ronnieshomes
Posted on Oct 08, 2010
Washer doesn't get dishes clean
Try to rinse with vinegar.
Jul 06, 2015 | Viking Dishwashers
The dishwasher works fine but the jet dry doesn't seem to release to clear dishes. I have cleaned it out and put new liquid in. It always seems to be a the same level and never needs refill. Glasses are...
Hi
White film deposits are observed if water is hard or when you are using more detergent than needed, try filling detergent cup half way. Try using white vinegar after the wash cycle is complete, run a complete cycle. Also turn down the heat on the hot water fed to the dishwasher. Try using water softener for better results.
You can also add vinegar in the final rinse cycle. Make sure that your soap dispenser drawer is opening and closing fine.
Hope this helps... Please post back if more information is required.
Daniel
Apr 02, 2011 | Maytag Dishwashers
Dish soaps do not clean. Leaves a hazy film thats hard to remove. Have tried vinegar ib washer.
Are you using a rinsing agent? What is your water supply? Is it well water or public water?
Please check to make sure that you are using a rinsing agent and that your hot water is hot enough for your Dishwasher to function properly.
The newer dishtabs have both cleaner and rinsing agent in a balanced formula and work very well.
Is this a new problem? Or is it a new dishwasher? Did your manual say that it was okay to use vinegar in your dishwasher?
Good luck to you. If you do not have your manual, you can download one at
http://shared.whirlpoolcorp.com/product_literature/search_results.jsp?searchTerm=Gu3200XTP&siteCd=WHRCOM&userType=Consumer
You will need to use your entire model number as it seems there are several submodels to your number.
If these suggestions do not help you please reply to this answer for another look at the problem.
Good luck to you and thank you for using FixYa.
Jan 07, 2011 | Whirlpool 24 in. GU3200XTP Built-in...
My dishes are filled with white residue from the hard water. I've tried vinegar to cut it and new rinsing agents but nothing works. Is there a filter to clean out any hard water deposits? Do I need to...
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Oct 18, 2010 | Jenn-Air 24 in. JDB1100AWS Built-in...
My maytag dishwasher doesn't seem to be rinsing
The problem is hard water. Go to www.dishwasherfilter.com. They have a new product out that solves this problem once and for all. It filters the water entering your dishwasher and removes the hard minerals that cause these spots. Very affordable and guaranteed to leave your dishes looking amazing every time.
Oct 25, 2009 | Maytag 24 in. MDB8600AW Jetclean II...
My dishes come out with cloudy film on them.
From Whirlpool:
*Film is due to either etching or silica film. Silica film is a milky, rainbow-colored deposit and etching is a cloudy film. Sometimes there is a water/chemical reaction with certain types of glassware.
o Silica film and etching are permanent and cannot be removed. Both can occur in any automatic dish washing machine and result from a water/chemical reaction with certain types of glassware. They are caused by some combination of:
+Soft or softened water.
+Alkaline washing solution.
+Insufficient rinsing.
+Dishwasher overloading.
+Heat of drying.
+Long/hot cycles.
To slow the down this process:
*Use a minimum amount of detergent but not less than 1 tablespoon per load.
*Use a liquid rinse aid.
*Under load the dishwasher to allow thorough rinsing.
*Do not use heated drying.
*Wash glasses by hand.
Do the following:
1. do you use a rinse agent
2. clean out the drain.
3. if you have a food disposal, run hot water through it and turn it on to clear it out before you turn on the dishwasher. The dishwasher drains into that sink. If you notice food or dirty water backing up into you sink when the dishwasher is draining, then the sink could have a minor clog and is backing up and being re-sprayed onto your dishes.
Source(s):
Use SANIVAC to clean lime deposits and extend the life of your dishwasher. If you have heavy water.
Run your dishwasher empty and pour in a cup of bleach and a cup of white vinegar to get the residue out.....run a regular cycle.......How hot is your hot water tank set on? The hotter the water the better a dishwasher washes and rinses, be careful it's not to hot as your shower and other sinks also will get this hot water......cut your dish soap down and make sure to use a Jet Rinse Aid. Again, be sure to use a liquid soap, and rinse agent, powders will cause a caustic reaction. Hope this helps. Let me know if there is anything else I can help you with.
JimmyC
Sep 30, 2009 | Bosch Dishwashers
A white nasty film on the dishes after washing
Check to make sure there are no bits or trash or paper around the bottom parts of your dishwasher. Place a bowl of vinegar on the bottom rack of your empty dishwasher. Run your dishwasher through a complete cycle.
Mar 23, 2009 | Dishwashers
My dishes are coming out with a thick cloudy film
Most dishwasher detergents now have some sort of rinse agent already in them. If this is the case don't add it to your dispenser once it runs out. Too much rinse agent can cause clouding.
Feb 18, 2009 | Kenmore 24 in. 16283 Built-in Dishwasher
Food particles are on dishes after washing
Try adding bicarb of soda/baking soda and vinegar in the detergent dispenser. Bicarb fizzes off hardened particles and vinegar strips off grease and aids rinsing.
Jan 26, 2009 | Maytag 24 in. PDB1420 Built-in Dishwasher
Dishwashers Logo
243 people viewed this question
Top Dishwashers Experts
