The bottom area of all dishwashers have the drain holes and pump which evacuate the water and debris. Remove the bottom tray and reach in and feel around. You may discover that some small items like corncob holders have fallen into the drain holes...If the drain holes are not blocked or clogged, the pump may be weak or defective. Check for debris first, if you find nothing blocking the little drain holes, call a repair agent who may need to get under the wash basin area by removing the washer from the cabinetry.
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
