Need to know full low voltage wiring information to thermostat
    Scholar:
  • 80 Answers
Usually the Red wire provides 24v and connects to the R termenal-
Next the Green wire is to the indoor blower motor and connects to G terminal-
Next the Yellow wire is to the outdoor unit to call for cooling and will engage power to the contactor solenoid to pass 240v power to compressor and power to Start/Run capacitor and fan! It will connect to the Y terminal-
Next is the White wire an it calls for Hea and is connected to the W terminal-
If you have an Orange wire it is for the reversing valve of a heat pump system.
Remember the red feeds 24v to each of these colored wires to complete a connection and pass power to the device being called into action.
BLue or Black wire will be ground if the thermostat needs power instead of batteries.
Red wire is the only hot 24v wire going to the thermostat period! And it comes from the Transformer!
Posted on Oct 08, 2010
Would like to know if I will be able to install a Honeywell RTH7500D1031 with my gravity furnace. I have upload pictures of my current thermostat and furnace. Please let me know if you need more...
yes if there are only two wires they should be a red wire and a white whire the red wire goes on the new stat where there is a R and the white wire goes where there is a W thats it put the batteries in the new stat and set the time and date and turn it to heat and turn it up to 80 it should work if the wires are not color coded just put one of them to the R and the other to the W dont worry you can't shocked it is low voltage good luck
Dec 04, 2012 | Honeywell Universal 7-Day Programmable...
New package unit, Start up procedure, Used old
You had a direct short. One of the wires shouldn't have been where it was. Tell me the color of the wires and the hook up.
rule of thumb from thermostat
red to R
White to W
Green to G
Yellow or Blue to Y
no comm hook up from t-stat
now the control for the ac is the Y terminal
and the only wire left to Common. Generally speaking. Let me know the wire colors? ken
May 09, 2010 | Heating & Cooling
How to connect a thermostat to heat source. bought thermostat to work in a homemade incubator. i can power in unit but when i connect heat source(light bulb) it wont switch it on when temperature is below...
get yourself a RIB (relay in a box) relay that is rated at 24/120. Also purchase a 24 volt door bell transformer. Wire 2 24 volt thermostat from one side of the transformer to the low voltage side of the relay then to the 24 volt thermostat than back to the other low voltage wire of the transformer. On the high voltage side, from your light bulb cut the wire going to the center lug of the light. Run one side of the wire to one side of the high voltage side of the relay, then run a wire from the other side of the relay (again high voltage side) to the the other side of the wire you cut on the light.
Mar 08, 2010 | Heating & Cooling
I replaced the 50A51-495 two stage automatic interrupted ignition control and must have not correctly connected the low voltage wires. The furnice fires ok but the fan doesn't start. The LED light flashes...
The white wires are neutral. The low voltage wires are used on the thermostat terminal and the 12 pin connector. The high voltage wire uses the spade terminals. Trace back the wires to each component and you will know which connection goes where.
Dec 02, 2009 | Honeywell Electronic Programmable...
To check thermostats do you just check continuity?
Yes, thermostats vary on what the thermostats control if it is just heat you will need two less wires. Do not always go by color go by manufactures wiring diagram. You need to find out your common wire normally it will be marked with a C on most cases find out through manual what letter marking it is then use a ohm meter to check your common to each wire there should be continuity.
The only time a ohms setting should be met are on contact that you use low voltage to switch on 110 voltage or transformers that turn high voltage to low voltage which should also be specified in manual.
Oct 22, 2009 | Frigidaire FER231A Electric Dryer
Need to know how to wire a thermostate to a hanging emerson heate
If this is an electric heater without a relay, you'll need a high voltage (electric heater) thermostat.
Is this a new installation? Give me some more info and we can get this job done...
Charlie
Aug 21, 2009 | Heating & Cooling
Heatpump A/C not working
First,Turn on the heat cycle (Not Emergency)and see if the outside unit come on,If not,and you don't have low voltage outside,Go to the inside unit and test the transformer,If you have low voltage from the transformer but not outside,It is the low voltage wires,If you don't have low voltage from the transformer,It's the transformer.If you have low voltage outside when in heat mode,but the unit won't come on,It's the contactor.Let me know if you need more help.
Please take time to rate this fixya
May 13, 2009 | Goodman CLQ36AR49 Air Conditioner
Low voltage wire
Because these are low voltage go ahead and connect them. If it doesn't work, then reverse them.
May 01, 2009 | Heating & Cooling
Heating & Cooling Logo
32 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
