Question about Toshiba 50HP66 50 in. Plasma Television
Part # for a Y Sustain Board Cable Ribbon
Board = LG 6871QYH039B
Model = 50HP66 Plasma TV
need to replace the cable ribbon connecting the Y Sustain board and the Top Y Drv board. For reference, the connection location on the Y Sus board is labeled P3. Does anyone have that cable ribbon part number?
  • Anonymous Mar 27, 2014
    intermittently have a 1" X 12" black bar that appears at top middle of screen. could this be a PCB assembly problem or only a ribbon cable connection problem
Why are you replacing it? what went wrong? mine just stopped lst nite and jsut ties to turn on. email res116@comcast.net
Posted on Jun 18, 2008
Hi guys,how to fix a Ghost picture on Lg 42lf20fr-afb LCD tv?
Ghost imaging is usually caused by a lose connection on the LCD. You need to remove the front bezel and push on the ribbon cables till you find the defective cable. I put a piece of rubber surgical tube type object and put it on the defective cable and have the bezel hold it in place.. You can replace the LCD screen as well.. It's probably cheaper to replace the TV then the LCD. This worked for me several times. YouTube has videos about it too.
https://www.youtube.com/watch?v=H4sro4FMq18
Good Luck
Feb 02, 2018 | LG Televison & Video
Vizio 50" plasma tv has picture but 1/3 of right side screen is black
there are 3-4 boards at the bottom of the tv. most brands call them z sustain boards you either have a bad one or the ribbon cable needs to be reset. be careful with those ribbon cables as they are fuzzed to the panel and cannot be fixed. the board usually cost 20-30 dollars.Good luck!!!
May 30, 2017 | Vizio Televison & Video
Comment: my plasma tv model pn50b550t2f change y sustain or main buffer board after that notice the lower cooper ribbon cable that goes into panel is ripped and now have no video at all.
Your'e talking about the COF {Chip On Film} strips; I assume. You can replace it. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
May 07, 2015 | Televison & Video
LG plasma screen tv has vertical lines down middle of the screen (changes colors).
All Plasma and LCD TV have boards that control vertical and horizontal output to their respective areas. They are connected to the screen by ribbon cables. If one of these boards fails all together, has a failed chip, a bad connection, or a bad ground somewhere it will result in a black line in the area of that board. A bad ribbon cable connection on the bottom will result in a vertical black bar though the screen. Many times resetting the connection will fix it, if the ribbon cable has been nicked there could be a severed connection. They an sometimes be fixed, but it is a pain. An yes I have done it, but the bar is gone. The same will happen if the chip that outputs to that area opens. The connectors are the first place to look paying close attention to the cable, they are extremely delicate so great care must be taken if you decide to tinker with em, the usually have lift locks that release them.
I believe this will help in solving the problem....
Aug 08, 2011 | LG Televison & Video
I have a black bar in the middle of my LG 50pg20 plasma what could be the problem can I fix this.
it might be one of two things , it is either a buffer board that has gone or the ribbon cable going from the screen to the buffer board. If it is the buffer board it can be fixed by simply replacing the board with a new one, if its the ribbon cable from the screen then it cannot be repaired sorry.
if you found this info useful please vote for me
Apr 10, 2011 | LG 50PG20 50 in. Plasma HDTV
Left half of screen has vertical color bars of different colors
Hi
This will be your screen controller board that has failed also known as the ldv's board, With the back removed from your TV it will sit below your power supply and be connected via a ribbon cable to your Y Sustain board on the left.
Remove it and take the part number of the board then Google or Ebay for a replacement.
Take a look at the below link so you know what you are looking for.
Hope this helps
http://cgi.ebay.co.uk/LG-42-Plasma-Tv-part-LOGIC-CONTROL-Board-EAX36952701_W0QQitemZ350341474285QQcmdZViewItemQQptZLH_DefaultDomain_3?hash=item5191faa7ed
Apr 21, 2010 | LG DU-42PX12XC 42 in. Plasma HDTV
Plasma tv has sound but no picture
Check all the cable connections at the back, if you are using an external receiver , then check the Video cable, eventually try a replacement one.
Try leaving the TV set unplugged for a couple of hours, this will drain power completely and, if there is no real fault , this can fix the problem.
If that does not fix it, then thereis an internal fault.
Common faults that cause audio but no picture concern, digital board, controller board, sustain boards, Plasma screen ribbon cables, and plasma display.
Call the number listed on the owner manual to get assistance.
If the warraty is expired no longer than three years, ask the price fod r a warranty extension calling same number in the manual.
Nov 22, 2008 | Televison & Video
My Sony Plasma Display
It sounds like you have a bad connection from either the X sustain or Y sustain boards to the panel itself. After the set warms up, the connection completes and the line goes away. First remember there are DANGEROUS HIGH VOLTAGES IN THE SET AND YOU CAN BE SERIOUSLY HARMED OR KILLED IF YOU TOUCH THE WRONG THING SO BE CAREFUL!. I would get a non conductive probe of plastic or wood and, with the set on and the back off, push on the ribbon cables which connect from the sustain boards to the panel. Once you determine which ribbon cable is the problem, disconnect the power, wait AT LEAST 30 MINUTES FOR THE VOLTAGES TO DRAIN OFF and then carefully resolder the ribbon cable connections at the sustain board in question. If the problem is at the panel end of the cable, I wouldn't recommend you try soldering there as it is very easy to damage the panel connections. You may try simply repositioning the ribbon cable to see if you can find a spot with a better connection. Please be sure to rate this solution. Thanks!
Nov 09, 2008 | Sony PFM-42V1A/S High Altitude 42 in....
Plasma Television
you need to be more specific ie Make and Model of set.
more than likely it is 'y' SUSTAIN BOARD OR PANEL DRIVER IC OR POOR SEATED FLAT RIBBON CABLE
Jun 11, 2008 | Televison & Video
Toshiba 50HP66 50 in. Plasma Television Logo
753 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
