Question about Amana ACF3325 Gas Kitchen Range
Amana ACF3325AB, Digital oven control not working knob pop out, pushed and cracked the panel, need to replace whole panel, easy to replace or do I need to call for service
Buffalo12980
  • 625 Answers
SOURCE: Amana ARGS7650SS problem
try this site - repairclinic dot com. there are some helps about where the screws are to remove the control panel.
Posted on Aug 21, 2007
SOURCE: amana oven not working and boiler also
how do you check the oven sensor? the self cleaning works properly when the oven door is closed and locked securely,the seld clean mode selectored the boiler comes on , the oven does not , this works normal, the stove top works fine , all 4 burners light up fine, i am stuck! anybody can help me out please i must get this stove going for chrismas dinner or I am will be thrown out of the house!
Posted on Dec 22, 2007
  • 3 Answers
SOURCE: AMANA ACS3350AS - NEVER BUY AMANA!!!
I have the same problem with faulty hinges creating heat that fries the control panel on my Amana range. I checked with the Amana-authorized repair guy and he estimated that a repair would cost about $475 in parts and labor. So here's what I did:
  • I called Amana customer service (866-616-2664) and explained that I had a dilemma -- my 5-year range has faulty hinges and no longer works. I am not in a position to replace it, but I know from online research that because this is a product defect, the $475 repair can only be expected to last for about a year.
  • When the rep said there is no record of a defect, I told her -- very politely -- that Amana-authorized repair person, himself, had pointed me to the websites.
  • When the rep said she hadn't heard anything about that, I told her -- again, very graciously -- that there is actually a class-action suit in Florida against Amana (see http://ovendoorlatchsettlement.com/pdfs/MTM_NOT_080103.pdf) because the panels become so hot that they are dangerous.
  • I asked if, given the above and my dilemma, if it would be possible for Amana to cover the cost of parts.
  • After checking with a supervisor, Amana agreed to pay for the parts.
I think this is an excellent compromise solution as the parts probably cost Amana very little but with the mark-up would cost me a lot. The key here though is BEING VERY KIND TO THE REP. They are trained to be inflexible. If that is going to push your buttons, you might want to ask someone else to make the call for you.
Posted on Jan 16, 2009
SOURCE: amana ACS3350AS stove temp in oven stays at 100
We had the same problem and it turned out to be a burned out lower heating element. Only the top one was heating and I could never get it over about 150deg or so.
Posted on Mar 24, 2009
  • 323 Answers
SOURCE: bad electronic contral panel on Amana gas range
On the Amana: Several Ebay stores carry panels like this. Problem is, once you open electronics they usually are hard to send back.
The stove is ten years old. You'll likely spend more than it is worth finding the right part and repairing it. It might be a good time to consider buying a new stove and selling this one for parts or scrap.
Posted on May 11, 2009
Amana counter top gas stove when plugged in start making clicking noise and you can smell gas .
on most, your push down and turn to hi to open gas valve and turn on piezio to light burner. it sounds like you have a knob already turned on . the control under the knob may need replacing. kinda an easy replacement if you get new part. check out repairclinic.com for video(maybe) but for parts for sure. be careful. gas is explosive.
Mar 16, 2015 | Amana Cooktops
Hello need help on my armani oven #arg7300LL oven and broiler do not go on?
Ok yes, it may be the thermostat.(It is the control and the tube that runs down inside the oven.) Give a few minutes and I'll post back....
Dec 22, 2007 | Amana RanARG7302 Gas Kitchen Range
We have to replace the control panel on our Amana AOES3030E wall oven. We have the part but how do we access the area where the new part needs to go? I'm not seeing how in the user manuals I looked...
To replace the control panel, the wall oven needs to be pulled out about 10-12 inches to access the conrtol panel..it has screws on the side AND in the back of control panel taht have to come off to get into panel...typically it can be pulled out fairly easy a couple of feet without it tipping and falling out of cabinet but only pull out as little as necessary
Aug 25, 2011 | Amana AOES3030 Electric Single Oven
I have an Amana ACS3350AS Gas range and the Control panel cover has cracked due to heat.After much searching on the web I found a replacement but I can't seam to find any manuals on how to dismantle it...
hello, this unit should only have screws under the control panel when you open the oven door. some of them have a side screw on each side when you pull out the oven an inch or two. hope this helps
Jun 08, 2011 | Amana ACS3350AS Gas Kitchen Range
Fitted new mainoven thermostat to Stoves Newhome built-in oven & grill Model No. 444445062 Serial No.41209452 other data on plate EFa900h need a wiring diagram,couple wires can adrift. Every thing...
I can only speak for the 720. If you want a circuit/wiring diagram for this one, then I need an email address. I will then register this on my BT Digital Vault and you can the download the whole manual.
Looking at the diagrams, the neon for the main oven has white and black wires.
The white wire from the main oven neon goes onto the same connector on the thermostat block as the white wire to the oven element. The black wire from the neon goes to a common terminal on the top oven neon, which then goes onto P6 of the top oven switch (still black wire).
If you need any more info, then let me know.
Apr 01, 2010 | Stoves 720EF Electric Double Oven
Amana ARGS7650 Keypad has no power
I had the same problem, same model. The electronic panel has to be replaced. This part is ~$215 before tax and shipping. With labor, I was looking at over $400. I bought a 4 yr old used GE gas oven for $75. That was my solution.
I believe the part to replace is labeled Erciii, gas
Part Number: AP4041311 made by WHIRLPOOL
This would have taken at least a week to ship (no one seems to have them in stock).
From now on, I will never own a range in which the oven or stovetop controls are electronic. Knobs and associated mechanics can be replaced MUCH more easily and cheaply!
Dec 01, 2008 | Amana ARGS7650SS Gas Kitchen Range
Kenmore electric built-in oven control panel beeping
We had the same problem. F7 error code and beeping. We turned off at the breaker- left it off for hours turned it back on and still f7 and beeping. We call repairman to come out and he removed the cover on control panel (3 screws on bottom of controll panel and it pops off). He unplugged the ribbon keypad connection - Cleaned the ends with a pencil eraser and said it is fixed and we would not have a problem.
Well, that was a fast way to spend 60 bucks but it has been a week and the oven has been great. No more beeps or error codes. SAVE YOUR MONEY DO IT YOURSELF!
Oct 08, 2007 | Ovens
Aug 21, 2007 | Amana ARGS7650SS Gas Kitchen Range
Amana ACF3325 Gas Kitchen Range Logo
104 people viewed this question
Top Amana Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Sal De
Are you an Amana Kitchen Range Expert? Answer questions, earn points and help others
