Question about Toshiba Satellite 2250XCDS Notebook
Installing ram what is involved in putting the 128 mb ram chip in the notebook. i have no problems doing this with a pc. never done it on a laptop
  • dragonfly109 Jul 25, 2008
    I have a 2250xcds/cdt and there is no small area to unscrew, it looks like the whole bottom has to come off. Can this old laptop be upgraded? It has always worked until recently, an erorr message pops up in a dialog box stating that there's not enough virtual memory. Isn't that a RAM problem?
NO, no, no. Just the keybaord and you'll be fine
Posted on Sep 01, 2008
All you have to do is take the keyboard off and then pull the winmodem. the ram goes under the modem. not hard after i figured it out. no problem. its easy just like i said.
Posted on Aug 13, 2008
The entire bottom has got to be unscrewed then you must carefully lift up keyboard. It is a major pain in the ****
Posted on Aug 12, 2008
  • 458 Answers
Flip the laptop over so that the bottom side is face up... you will need a Small Phillips head screwdriver ... Unscrew the cap to the RAM .. (it is the one that is generally the same size as the stick of ram going in it...).. slide it into the slot at an angle... about a 45 degree angle. then push the end downward towards the board until the latches lock it in place...rescrew the cap on the case ...
Posted on Jun 04, 2008
Can i still get ram for that laptop?
Maximum RAM that you can install in your laptop is 512 MB, so if you only have 128 installed in your laptop now YES you can still upgrade your laptop to 512MB.
RAM Specs: InstalledSize: 128.0 MB Maximum RAM: 512 MB Technology: SDRAM - 100.0 MHz FormFactor: SODIMM 144-pin
Feb 11, 2011 | Toshiba Satellite 1800-S253 Notebook
RAM chip sets
It is OK to mix chip (SODIMM) capacities in the 2 slots in your notebook.
The best system performance will be when you have 2 x 512MB but for now if you install 1 x 512MB, you could even leave the old chip in the other slot, it'll be fine.
Oct 19, 2007 | IBM ThinkPad R31 2656 Notebook
I have an Acer TravelMate 514T PC Notebook running with only 64MB RAM, and I want to put in a 256 MB RAM. How do I make the notebook recognize the 256 MB RAM card?
Mostly what I came across this models they only can detect until 128 mb and they do run a little faster than having 64 mb.And see if the card is pc100. and it is also dependent on what is your operating system is.If your notebook memory slot is two get two 128mb and you'll have 256mb.
Oct 31, 2010 | Acer TravelMate 514T Notebook
Is it easy to install memory on my toshiba satellite pro 4600
Memory Upgrade for Toshiba Satellite Pro 4600 800 Laptop, the Toshiba Satellite Pro 4600 800 Laptop takes the PC100 SDRAM SODIMMs. 256MB module must be 1" in height or less Memory Type, and comes installed with 128 MB (removable) of Memory. You can upgrade your Toshiba Satellite Pro 4600 800 Laptop to up to a maximum of 512 MB Memory, the system has 2 sockets to install Memory, already with 128 MB (removable) standard Memory installed. For best Laptop performance use the maximum amount of allowed Memory per slot for your Laptop.
You can obtain your models service manual with instructions for how to replace and upgrade memory from this link. http://www.givemefile.net/smanuals/notebooks/toshiba/file/31033.html
Hope this helps FixYa! If you find this information helpful, please give us a rating and share your experience in a testimonial!
Thank you for using FixYa.com
May 13, 2010 | Toshiba Satellite Pro 4600 Notebook
Does Toshiba Portege 3490CT ram can be bigger than 128. If so adv availability & selling outlet please.
The motherboard has 128 MB memory (soldered on board). However there is still empty slot for further upgrade. You can install another 128 MB PC100 SDRAM memory to get maximum of 256 MB.
CompQ
May 09, 2010 | Toshiba Portege 3490CT Notebook
I would like to nwom how much of memory this laptop support
The Thinkpad is installed with 128 MB SDRAM is standard, and is expandable to 512 MB
There are two memory slots, to expand it to 512 Mb you need two 256 Mb RAM modules and throw away the 128 Mb RAM module, but if you don't throw away this module and you insert a 256 Mb RAM module in the 2nd memory slot then your total memory would be 384 Mb.
Nov 20, 2009 | IBM ThinkPad T20 2647 Notebook
I want to put ram in my laptop evo 1020v, but he recognize only 512MB how can I do. thanks you
When you say that it only recognizes 512 MB, I am assuming that this is after you installed the RAM?  - How much did you have before you installed it?  And how much did you install?
Sometimes it is as simple as making sure that the RAM chip is pushed in far enough.  Make sure the chip is pushed in securely.  Sometimes you will hear a click when it is in far enough. If it is not, the laptop will not recognize it.
Hope that helps.
Mar 09, 2009 | Compaq Evo N1020V PC Notebook
Installing ram
Laptop RAM modules are usually in a removable panel on the underneath of the laptop.
Alternatively, it might be under the keyboard, where there might be a couple of screws underneath to remove, then maybe some clips on the keyboard. Sometimes you will need to remove the panel above the keyboard (should pop out of its clips) and there will be screws underneath.
I'm not too familiar with this model, so I couldn't say for sure.
But once you see the ram, its similar to removing desktop ram, just use your thumbs to pry back the tabs holding it in.
Dec 15, 2008 | Computers & Internet
Hard drive and memory
the laptop should pick up a 20gb or 60gb ide hard drive with no problem
Memory Upgrade for Toshiba Satellite 2775XDVD Laptop, the Toshiba Satellite 2775XDVD Laptop takes the PC100 SDRAM SODIMMs Memory Type, and comes installed with 64 MB (non-removable) of Memory. You can upgrade your Toshiba Satellite 2775XDVD Laptop to up to a maximum of 192 MB Memory, the system has 1 socket to install Memory, already with 64 MB (non-removable) standard Memory installed. For best Laptop performance use the maximum amount of allowed Memory per slot for your Laptop.
Choose the following Memory Upgrade for Toshiba Satellite 2775XDVD Laptop
Dec 01, 2008 | Toshiba Satellite 2775XDVD Notebook
How to upgrade a Dell Latitude CPX - Intel P3 500-650 laptop
I have a CPX H500GT. To get it to run XP Pro to run right, max out the ram. And get a larger harddrive. Xp uses a substantial amount of space.
Sep 22, 2008 | Dell Latitude CPX Notebook
Toshiba Satellite 2250XCDS Notebook Logo
104 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
