Question about Brother CS6000i Computerized Sewing Machine
I had to take my bobbin case out because it seemed to have come loose and now i can't get it back in correctly or maybe something is broken. I can't tell. i need a diagram or directions to put the bobbin case back in correctly so that it spins my bobbin.
    Genius:
  • 1,788 Answers
Your manual is available for free to download at www.brother-usa.com under support and you can make the diagrams really large to see exactly what you are doing.
Posted on Oct 08, 2010
Bobbin thread breaks off once i start sewing
Hmm, sounds like maybe there is a rough spot on the bobbin case or hook that is snagging the thread. Could also be the bobbin tension is too tight or it is broken. Also, check to make sure the bobbin is loaded the correct direction in the bobbin case and threaded through the bobbin tension properly.
Feb 28, 2016 | Sewing Machines
My Bernina Bernette 65 has a problem with the thread bunching up every 10-15 stiches on the bottom. Some of the thread stitches on the bottom of the fabric are in a straight line, and then the thread will...
try a new needle--one that is for the fabric being sewed
then try to adjust the top thread tension again, if the stitches remain loose and the tension won't adjust then the tension knob needs to be checked to see if there is something wrong with it.
also check to make sure the bobbin is inserted correctly into the bobbin case, if the bobbin is not turned the right way in the bobbin case the sewing machine will not stitch correctly.
Aug 05, 2013 | Bernina BERNETTE 65 Mechanical Sewing...
I volunteer at a women's prison in their sewing class and we have model 385-16231301. The bobbin thread does not pick up. The bobin case seems to sit in their properly, but when I turn it manually...
check the needle to make sure that it's inserted correctly, the flat side of the needle goes to the back of the machine,, and make sure the needle goes all the way up into the needle cavity .
make sure the bobbin is correctly inserted
clean under the needle plate area & in bobbin area for loose threads or lint
if none of the above work & the needle is still hitting something then it 's a great possibility it's out of time & needs to be serviced, cause the needle should not be hitting anything when it goes down.
Aug 26, 2011 | Kenmore Sewing Machines
I cannot get the sewing machine bobbin casing back into the machine. When I put the bobbin in, the casing pops out. Can you help me? I have a 9410 Singer Sewing Machine.
Do you think that it is broken? You can go to www.sewingpartsonline.com and find a new case for $11.99-$13.99. The reason I say this, is because I faced a similar problem a few years ago, I was shocked to find out it was not something I was doing wrong but that it was broken. Take alook at this site and you will see each part for the bobbin case and maybe you can determine if this is the problem
Sep 04, 2010 | Sewing Machines
Re-curring loose bobbin case
According to the manual, this is a drop-in bobbin.
If the bobbin case came loose, the needle would probably hit it and brake.
Take the bobbin out.
Turn of the power and remove the needle plate (under the presser foot).
Raise the needle to it's highest position and lift out and reset the bobbin case into the shuttle. This should be in the maintenance section of the manual. The bobbin case should fit snug.
Make sure the thread is feeding from the bobbin, counter-clockwise and through the guides on the bobbin case.
For a rotary bobbin with a metal bobbin case.
Remove the bobbin case. Make sure the thread is feeding clock-wise and through the guide on the side of the bobbin case.
Raise the needle to it's highest position - this puts the hook at the lower left. Left the tab on the back of the bobbin case and slip the bobbin case back into the shuttle with the "arm" straight up. You may have to move the bobbin case a bit to the left or right for it to snap into place.
If the problem persits, take the machine back to the dealer - there should not be a charge for fixing this as it is brand new - keep your receipt and warranty information at hand.
Apr 24, 2010 | Singer 7442 Mechanical Sewing Machine
Can't put the plastic bobbin holder back into position
make sure the needle is all the way up and the bobbin is in the case the right way. check to be sure there is no lint or dirt impeding the case. you may have to take out the piece the case fits into to do this. i have found this to be the problem more times than not.
May 11, 2009 | Yamata FY700 Mechanical Sewing Machine
Singer 9410 Bobbin
Update:  Today I took my machine in to get serviced - they replaced the metal bobbin I was using with a plastic one, that was a little less rattley inside the bobbin case, replaced the needle with a new, universal one, and changed out the thread with something a little higher quality.  They also adjusted the spring holding the bobbin case slightly, and now it seems to work fine.  I'm not sure how long it will last, but for now I'm good.
Oct 02, 2008 | Sewing Machines
Singer 9410 Bobbin
I had the same problem and after looking on here and finding no answer I went back to my machine and found out what the problem was...ok, where the bobbin case sets in,the metal plate beside it needs to be fitted right close to the bobbin case, so loosen the screws(just two of them) that are in the plate(DO NOT REMOVE JUST LOOSEN) and slide the metal plate over some just enough to fit snug...NOT TOO TIGHT... if its seems to sew too tight loosen it a bit It worked for me, GOOD LUCK
Nov 11, 2007 | Yamata FY700 Mechanical Sewing Machine
Brother CS6000i Computerized Sewing Machine Logo
177 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
