1: changing the format set up from ms-dos to MAC 2: There are certain files I cannot transfer across, even though they are smaller than most. The file types are indicated as DV PAL ( Little endian) same as others files, not sure why they wont go?
  • froggit2 Jun 02, 2008
    still unable to transfer some files across!! its a mystery as I have transfered across similar files, with same codec and set ups?
    It seems every now and then it just will not perform operation, I did not quite understand the solution, as the system isnt using any files, and I dont know how to re-start the system in save mode
     Anyway, thanks for trying! Appreciate that
    Scholar:
  • 139 Answers
The system may be using these files yu want to copy so i suggest yu restart yr system in save mode then try copying it again
thank uj
Posted on May 30, 2008
Mac reformatted
MP3 players expect an MS-DOS (or FAT) format.
They do not read Mac formatted memory.
Reformat the MP3 player to MS-DOS format (your files will be deleted, so back them up if necessary) and the player should read the memory once more.
Dec 10, 2013 | RCA M4204 MP3 Player
I have a 1.5 GB external hard drive with 105 GB of free disk space. I want to transfer some files from my laptop to this device (6GB each) but it says the destination drive is full. please help, can i...
More than likely you are receiving that message because your 1.5gb drive is formatted as MS-DOS (FAT32) It can only accept files that are 4gb and smaller. You can partition the drive so that the 100gb left is FAT32 but you could lose everything.
If I were you I would transfer everything off the drive (that I want to save) format it NTFS or Journeled Case Sensitive (if you have a Mac) then copy everything back over including the other 6gb files.
Hope this info helps, if you have more questions or advice just ask.
Mar 24, 2011 | Acer (A2200HD60) Hard Drive
I have Lacie Rikiki Go 500GB, when the first format I set it with Mac user. Now I want to use for both Mac/Window. Pls advise. Thanks
the easiest way to allow you to share data from the same partition between MAC and PC is to format your drive as MS-DOS (FAT 32) with Disk Utility, but you will be limited to files of 4GB or smaller.
Another way to do it is to format your drive as NTFS with Windows disk manager and to install an add on on your MAC that allows you to write to NTFS partitions (without add on, you will only be able to read NTFS partitions)
Regards,
Jan 05, 2011 | LaCie Design by F. A. Porsche 160 GB Hard...
I work with OS X (mac) , I can not copy a file bigger that 4 GB into my WD my book. I 've tried to change the format, but i can just chose between : Mac OS Extended ( Journaled) ,Mac OS Extended, case-...
Although Macs are designed to Read NTFS, they aren't designed to write to them and therefor cannot format a windows drive. If you are simply moving files onto the Mac from a windows PC you can format the drive using a PC and the Mac will be able to read and copy the files from the drive. If your goal is to have both windows and Mac read and write to the drive, your best bet is to use Mac OS Extended, then to buy and install Macdisk on your Windows PC. This will allow both to fully utilize the drive.
Any file size limitations you're running into at that point would have to be dealt with through compression or you may need to set up a NAS server that uses either NTFS or Linux format and copy files across the network rather than through a direct port like USB or FireWire.
Feel free to respond back and pick my brain if this advice only gets you half way solved.
Hope this helps FixYa,
Chris
Dec 23, 2010 | Western Digital My Book Essential Edition...
I have a 230 gb FreeAgent Go external drive.
I think the solution that meeknotweak gave is a little bit twisted. First and foremost you can not be able to format a 230gb hard drive as a FAT or even FAT32 simply because that FAT and FAT32 is only set to be used and can be used only if your drive is less than 40gb. If your drive is larger than 40gb then the only option is to format it using NTFS.
Second you can be able to format and set the volume format of the drive under the ERASE tab of the DiscUtility on Mac. Not in "RAID" tab.
This is the right way to do it......
If you plan to use the external HD into a PC or Mac, you should first plug it into a Mac Computer and format it using the Disc Utility. Choose the Erase Tab and select Volume Fomat. Make sure that you choose MS DOS. Only Mac OS can format a drive of any size to a FAT file system. If you have already formatted it you can now be able to use it vice versa.
One more thing if the HD is formatted as NTFS, Mac OS can read it but can't write on the drive. So that's why you need to make it as a FAT so that it would be readable and writable to both OS. Also make sure that the folders and files that you're transferring into the HD doesn't contain special characters. Mac OS can recognize those special characters on a file but windows can't.
I hope this clarifies everything.
Aug 28, 2009 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
Got a new imac moved ms office file to my book -
Try to change the File system of the hard drive to FAT. It is currently in NTFS. Mac recognizes NTFS file system as read only. You must use the disc utility and format it with a volume format of MS DOS.
By changing it to MS DOS (FAT) you can use it with Mac and PC. Readable and writable.
Aug 04, 2009 | Western Digital My Book Essential Edition...
Maxtor Basics portable 320gb Mac to pc compatability problems
Hi Tys,
I had a similar issue with my Maxtor Basics portable 500GB drive. I hadn't formatted mine yet, but had heard there were issues, so decided to find out before I start. I even saw your post here looking for an answer. Finally, one of my friends told me the following solution, which worked fine for me:
Don't format the drive as any of the Mac OS Extended options, simply reformat it as MS-DOS (it should be one of the options in Disk Utilities when you choose Erase and go to the Volume Format dropdown list).
Your Mac should be able to recognise and use the drive in this format and it works for PCs. Transferring files between the two shouldn't be a problem.
A thing to note, though, is that these Maxtor drives apparently come ready-formatted as MS-DOS (mine did). But while my Mac recognised the drive, I couldn't copy files on to it. If this happens, erase this MS-DOS formatting with... MS-DOS. Don't ask me why this works, I'm not a Mac Genius, but now my Maxtor is trouble-free and can transfer files from PC to Mac and back again.
Hope this works out for ya!
K
Apr 27, 2009 | Maxtor Basics Personal Storage 3200 Hard...
Iomega 500 gb hard drive: large file transfers
The default format for the IOMega drive is FAT32. This format will work on all versions of Windows, as well as Mac OS9 and above. Unfortunately, FAT32 can't handle files larger than 4gigs. If you want to use larger files, you're going to have to remove all the files from your IOMega drive and use your computer to format it to NTFS (Windows 2000/XP/Vista) or HFS+ (Mac OS9/X).
Consult your owner's manual for specific details.
Sep 12, 2008 | Iomega (33654) Limited Edition 500 GB USB...
Mac user with sandisk cruzer, no room & no way to format.
you guys have to empty the trash can or
1. open applications
2. open utilities
3. click on disk utility
4. locate the drive, left hand side
5. select the drive
6. click on erase
7. select file system, either MS-DOS or Mac OS extended.
have fun =D.
Jul 24, 2008 | SanDisk Cruzer Titanium 2GB USB 2.0 Flash...
Maxtor access (pc and MAC)
Yes, formatting included erasing the drive and renewing the partition. If you want the drive legible on pc, but will be working in both environments, then you can do 1 of 2 things....
easiest, purchase MACDRIVE, it will allow a pc computer to see and use Mac items on the drive.
You could also transfer the content to another drive temporarily, format the drive in question to MS-DOS, then transfer all that content back over...using a MAC to do so.....
keep me posted..
Oct 28, 2007 | Maxtor Personal Storage 3200 (U01E200) 200...
Computers & Internet Logo
47 people viewed this question
David Payne
David Payne
