Question about John Deere 420,1020,2010,2020,2510,2520 Tractor Float
JOHN DEERE 2240 --PTO STAYS ENGAGED. THE LEVER DOES NOTHING WHEN SHIFTED FROM PTO IN/OUT. THE LEVER SEEMED TO SNAP THE LAST TIME IT WAS USED AND NOW HAS NO EFFECT ON THE PTO SHAFT. IS THERE POSSIBLY A SPRING OR SNAP RING THAT HAS BROKEN OR IS THE PROBLEM MORE COMPLEX?
  • 11 Answers
SOURCE: john deere 2010 tractor. pto grinds and wont engage
The PTO usually has a clutch that has to be engaged so that you can select the PTO rotation setting. I had a problem like that on my tractor and all it needed was a little adjustment on the PTO clutch lever, so it could disengage the PTO gearbox properly.
Posted on Mar 11, 2009
SOURCE: Belt change on a hydrostatic 265 John Deere
Instructions for changing main drive belt on John Deere model 265
HELP !!!!!!!!!!!!!!!!!!
Posted on Aug 28, 2009
mowerman1857
  • 389 Answers
SOURCE: How do I remove the PTO clutch from a John Deere
Locate and disconnect the power supply cord from the clutch. Remove the bolt, washer and retainer from the center of the clutch, It should now slide off the end of the crankshaft provided you have previously removed anything such as body parts or braces that would be in the way. In some instances penetrating oil must be used to help free it up. When you reassemble it, it is a good idea to use a little bit of anti-seize on the engine shaft in case you have to remove it in the future.
Posted on Oct 30, 2009
nova2nv
  • 197 Answers
SOURCE: Engine dies when engaging PTO switch on a John
Check and adjust your RIO switch{reverse implement option}near the trans if so equipped.What happens when you press forward pedal then engage blades?Would also check the lower bearing on your pto clutch to see if its seized up.
Posted on Nov 14, 2009
wireguy212
  • 1627 Answers
SOURCE: Intermittent PTO Problem on John Deer 6400
You likely need the speed sensor replaced in the rear of the tractor,either above or below the pto shaft.There is also a pto relay module beside the fuse panel that may need to be replace(only on the early 6000 series tractors,later it was replaced by the bcu).If you can get the codes from the bcu and relay the info to me i can likely tell you for sure what you need to do if none of the above works.
Posted on Jun 05, 2010
Blades won't engage on John Deere x540.
I would remove the PTO switch and have a Deere dealer test it. Also on the 500 series the PTO operates through the ignition control module which is under the dash, you can see it when you raise the hood. It is black and about 2" wide x 3" long and 1" thick.
Jul 29, 2017 | John Deere Garden
8130 John Deere pto code 1883.01
Rear PTO Underspeed. Make sure correct shaft is installed. Restart vehicle and select proper PTO engagement rate in the CommandCenter. If code returns, have your John Deere dealer repair as soon as possible.
OMAR259982 8130 8230 8330 8430 and 8530 Tractors Block File OURX935...
Last website shows to me what appears to be a sensor just to the right of the icon A pointer, identifying the snap ring, in the top right photo. http://manuals.deere.com/omview/OMAR259982_19/gif/RW55322A.gif
Best of luck.
Dec 16, 2015 | John Deere Garden
John Deere L110 Mower wont engage
Depending on which type of PTO you have the problem could be simple to diagnose... if you have an electric PTO, you may be dealing with a bad switch... if electric, you should have good tension on the belt at all times. If it is a lever that you push/pull to engage the blades, then it would seem that the tensioner pulley is not applying the required tension on the belt... could be a broken spring or a worn/slipping belt (not enough tension)... hope that gives you somewhere to look into...
May 21, 2013 | John Deere Garden
John Deere x520 pto issue
not trying to insult your intelligence, but did you make sure the belts were installed properly.it does happen to the best of us..good luck
Apr 03, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Jd 3020 power shift pto turns all the time. if lever not engaged a heavy load can stop it. otherwise it works ok
The pto brake is either worn out or you have no presure to it when the pto is turned off,most likely the pto brake is worn out.
Nov 03, 2009 | John Deere 3010,3020 Tractor Basic...
PTO CONTROLS. How do you engage and disengage PTO.
The tractor is not a 6300 is it.If it' not you need to adjust the cable for the p.t.o. until it will stay down.Don't turn the turnbuckle too much at a time because there is a fine line between the won't engage and the won,t disengage adjustment.
Sep 06, 2009 | John Deere 6300,6300l,6400,6400l Tractor...
John deere 2010 tractor. pto grinds and wont engage
Mar 11, 2009 | John Deere 420,1020,2010,2020,2510,2520...
John Deere 420,1020,2010,2020,2510,2520 Tractor Float Logo
444 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
