Question about Maytag Ovens
Maytag electric oven CWE9000 and am getting a F1and F5 code what does it mean
  • 5 Answers
SOURCE: The F5 error code?
Check here, Sharyl: http://www.repairclinic.com/0078.asp#Whirlpool1 F5 Check door/latch switch Replace switch if defective (or) F5 Pushbutton stuck Check for binding of pushbuttons and control panel glass. If OK, replace touch panel Depending on your model... -j.
Posted on Jun 19, 2007
SOURCE: Error Code F5 E5
The repair on this issue will be one of either of these parts.
It is a common issue with Kitchenaid wall ovens.
9759242 THERMAL FUSE/THERMOSTAT/THERMAL T.O.D.
W10175596 THERMAL OVEN FUSE/THERMOSTAT
Posted on Jan 16, 2009
SOURCE: Whirlpool Gold Electric Oven F5 E1 code on bar code
For some reason I get the same error code every time we have a power outage. If you push and hold the "lower off" button for about ten or 15 seconds it will unlock and reset. Hope this helps.
Posted on May 29, 2009
GodBlessU
  • 3513 Answers
SOURCE: My GE oven gives error code of F3 and F5
Thank you for contacting Fixya.
It's possible it could be the senser, just two screws hold it on and the wires unplug with a connector.
As to understand it in details whether the sesor is the bad part you can use a ohm meter to test the sensor, it should read about 1100 ohms at room temperature, if so, then your oven sensor is good.
You can get a cheap ohm meter at Radio Shack or any hardware store. If your oven sensor tests good, then your control board would need to be replaced.
That would help to resolve the issue.
God Bless.
Posted on Jul 13, 2009
mgprice
  • 744 Answers
SOURCE: Maytag oven beeping the message is F5 oven needs to be turned off
Hello, the oven can be turned off from the breaker panel, the Error message F5 refers to your electronic oven control is bad. You can try to reset it by turning the breaker off for 20 minutes and reseting the breaker..if this fails to work you will need to replace the EOC. Hope this helps, if you have any further questions please feel free to comment again..Good Luck!!!
Posted on Jul 14, 2009
Ge oven jkp27 code f5
Hello Donald,
The F5 error code means that the control board has detecteda error within it self and theirfore the control(also called clock or EOC) needs to be replaced. The F5 error code can be cleared by pushing the cancel/off button and if it returns a short time later their is defiently a malfunction inside of the clock and it would need to be replaced.
GENE
Sep 28, 2011 | GE JKP27 Electric Double Oven
Maytag 24 " wall oven gas trouble code F5
Hi ngwhite,
The trouble code F5 is a Watchdog and hardware conflict. You need to replace the clock (ERC).
Hope it helps.
Thank you for using FixYa.
Aug 02, 2010 | Maytag 24" Built-In Single Gas Wall Oven -...
Oven door is locked after trying to clean and getting error code E1 F5
E1 F5 means your unit is having a problem with the door latch and lock assemble turn the power off for 10 min. and after turning the power back on wait another 10 min. before opening
Apr 05, 2010 | Whirlpool GMC305PD Electric Single Oven
My maytag oven has a function error. F5 and F3
Hi sorianocynth,
Maytag error F5 and F3 do have different indications. Error F5 means watchdog and hardware conflict. The only way to resolve this is to replace clock (ERC). On the other hnd, F3 means you have shorted or open oven temperature sensor (RTD). Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok.
For replacement part you may contact Sears at 1-800-252-1698; M-F 6:30 AM-10:30 PM - Sat 7:00 AM-9:30 PM - Sun 7:30 AM-9:30 PM - All times Central. When they send out the part detailed instruction will be provided.
Hope this helps.
Jan 19, 2010 | Maytag 30 in. Electric Single Wall Oven...
I am getting an F2, then an F5 followed by sometimes an f7 error code and inconstant temps.
the f 2 code is ( oven too hot ) the f 5 ( watchdog circuits disagree / and f7 ( function key shorted or stuck button .. / the clock ( erc ) may have a warped face . ..I would first replace the tempt sensor in oven . if you still have problem repl clock. and problem over .. thank mm ..
Dec 02, 2009 | Maytag CWE5800A Electric Double Oven
We have a gas maytag gas wall oven that is getting f3 and f5 error codes
F3
Shorted or open oven temperature sensor (RTD)
F5
Replace clock (ERC).
Jul 17, 2009 | Maytag 24" Built-In Single Gas Wall Oven -...
Whirlpool accubake oven door will not open e1 f5 and e0 f5 error codes
F5 fault codes are latch mechanism problems. One means the latch won't lock, the other means the latch won't unlock. Odd you're getting both...
Feb 09, 2009 | Whirlpool RBS305PDS Electric Single Oven
F2,F5,F7 message
MAYTAG
Range/Stove/Oven Fault Codes Failure
Code
Condition Check/Repair F1 Defective touch pad or membrane Replace touch pad or membrane (usually the touch pad)* F1 Watchdog on board Replace touch pad or clock assembly (also called the ERC) F2 Oven too hot Replace relay board (if present) or bad oven temperature sensor F3 or F4 Open or shorted oven temperature sensor Replace oven temperature sensor F5 Hardware and watchdog circuits disagree Replace clock assembly (also called the ERC) F6 Missing AC signal Check for proper voltage F7 Function key shorted or stuck button Replace touch pad or clock assembly (also called the ERC) or un-stick button F8 Analog/Digital supervisory Replace clock assembly (also called the ERC) F9 Door latch supervisory Check door lock circuit or replace clock assembly (also called the ERC) F0 Function key stuck Replace touch pad or clock assembly (also called the ERC)
Feb 07, 2009 | Maytag MEW5527B Electric Single Oven
Ovens Logo
97 people viewed this question
Top Maytag Ovens Experts
Oloyede Monsuru
Mack Baxter
Craig Butler
Craig Butler
Are you a Maytag Oven Expert? Answer questions, earn points and help others
