Question about Kenmore 44102 Front Load Washer
My washer will not drain or spin my clothes. It buzzes and when I go down my clothes are sitting in four inches of water. Sometimes I can finagle it into draining and spinning! I really don't want to have to have a repair person out!
    Master:
  • 413 Answers
There's not a choice but to have a repair man see about this problem. It is generally caused by one of four possibilities, but it requires the rear panel to be removed, the lower panel removed and access to the back of the timer mechanism and down where the motor and clutch assembly are located to fix. Not an easy job for most handymen or ladies unless you have the tools and the "lift" to get the machine up in the air to test and inspect the necessary components.
Posted on Oct 08, 2010
Got an F02 code on my Kenmore ELite HE3 washer. How do I unlock the door to get the water out?
Try pushing the start/pau botton several times,this causes the drain to start drining, when it stops and starts flashing again,push the botton again.The water needs to come down a level and sometimes it may start to spin.I've had several problems with this type of washer,But all machines do this.After you get the clothes to spin,remove them and put,draino-max gel or Rooto-rooter drain opener in drum and let it sit 1-3hrs.then run machine heavy-duty hot-water no clothes,you may have to run it several times to get all the cleaner out.the pump may be clogged with animal-hair or strings from clothes.good luck
Jul 10, 2010 | Kenmore Elite 45986 Front Load Washer
Washer does not spin out all of the water & we
The symptoms you have are constant with a clogged drain hose or drain pump.
Try draining as much water from the washer as possible. Then take the drain hose off the machine take it outside and run water through it. If this is clear, tip the machine up and take the drain hose off that is inside and do the same, this drain hose connects directly to the pump in front. When you have the hose off look to see if something is in side the pump like a sock.
Jun 14, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Won't empty
It won't drain If your washer won't drain, check these: It spins, but doesn't pump It doesn't spin or pump It pumps, but the water returns It spins, but doesn't pump If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out. To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port. Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job. If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump. It doesn't spin or pump If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. It pumps, but the water returns If the water that pumps out of the machine goes back into the machine after the spin cycle, your washer may be siphoning the water from a laundry tub that has a slow drain, back into the washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck in the drain?) Also, check for these problems: If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess. If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Jan 01, 2010 | Washing Machines
I have a Kenmore N2. What would make my front load washer fill back up with some water after the drain and spin cycle is complete?? IF I let the washer go until it's done and go downstairs to take out,...
first, run a rinse,drain & spin cycle. after it finishes filling, shut the water supply (taps) off. If water enters the washer after the drain, it has to be sifoning back in from the DRAIN hose. Check to see if the drain hose is not going up above the washer more than a few inches
Dec 03, 2009 | Kenmore Washing Machines
Clothes are too wet after spin cycle.
There is a tube which runs from the side or bottom of the outer tub to the water level switch. Most likely, this has become a bit plugged up with (for lack of a better term) goop, right where it connects to the tub. Take it off and clean it out, or just cut off the last inch and reattach. What is happening is that the air inside is not able to escape as the water is pumped out of the tub, and the washer then thinks the tub is not empty, and thus it will not spin. After it sits awhile, enough air escapes back out the tube so that the machine knows the tub is empty, and it will allow the machine to then spin.
Aug 31, 2009 | Washing Machines
FTW445ges2 Washer won't drain, buzzes during drain cycle
Hi...
You need to check this parts.
Inspect the drain hose for kinks
Test the timer control
Test the lid switch(some models)
Inspect the water pump
Inspect the driver belt(belt drive only)
Inspect the motor coupler
  • If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess.
  • If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Hope it will help you.
Regards
ICmanServer
Aug 01, 2009 | Frigidaire GLTF2940ES Front Load Washer
Washer won't drain.
Apr 01, 2009 | LG Washing Machines
Will not drain
It spins, but doesn't pumpIf your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out.
Nov 30, 2008 | Kenmore Energy Star 44092 Front Load...
Asko D3100 dishwasher wont drain completely
I think I see the problem based on "futureloginn"'s highly rated solution. You have a dishwasher. You need to stop washing clothes in it.
Oct 27, 2008 | Asko 24 in. D3112 Free-Standing Dishwasher
Kenmore 44102 Front Load Washer Logo
27 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
