Question about Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator
Ice maker doesn't work
Hi, I'am having the same problem rootbeergirl was having. I changed my water filter at the bottom of the refer and about two days later I ran out of ice. And how there's know water going to the Ice machine. I checked the water supply and the water line and all looks good. If I buy and Ice maker and it's not the problem can it be returned?
  • ctbk Jun 15, 2008
    I jumped the T and H terminals and the only thing that happened was the ice machine got hot. the machine didn't do anything else. Is it shot?
  • 770 Answers
Not really you can test cycle the icemaker with a jumper wire between the T and H terminal leave the jumper in for about 10 sec then remove it should start the im cycle once the fingers hit the 12 o'clock position then the fill should occur
Posted on May 30, 2008
  • Gary Davd
    Gary Davd Jun 15, 2008
    yes just replace it it runs about $115
Electrolux Ref. 3yrs old. ice maker will not make ice, water dispencer will work. I have replaced filter.Ice maker goes through the motion but, no water. can you help me?
either your fill tube is clogged or the water valve in the back of the refer has failed. Go to the back of the unit, if my memory is correct the yellow hose is for the ice maker, at the water valve disconnect the 1/4 hose from the valve to the ice maker only, place valve in a bowl, cycle ice maker. If you get water, fill tube is obstructed, if not water the valve has failed and needs to be replaced.
Good Luck
Oct 28, 2013 | Electrolux EI28BS56IS (278 cu ft) Bottom...
Ice maker doesn't work. changed filter. light on ice maker door still on.
You need probably to change the dispenser solenoids which swith water on dispenser
Apr 05, 2008 | Jenn-Air JCD2389G Side by Side...
No water no ice
Change the=> 67006531 Water Inlet Valve I believe the side of your 67006531 Water Inlet Valve that controls water flow to the ice maker has weakened and cannot open properly. Replace the water valves and I believe the ice maker will work fine, Sea Breeze
Jun 07, 2012 | Whirlpool GX5FHTXVA Bottom Freezer French...
Built-in side by side. The in-freezer ice maker is not working properly. makes one row of ice every 10-2 hours. i have checked temp, water filter and water line...all is fine. had the ice maker replaced...
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects theb you need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
If its leaking same part needs replaced.The water valve at the bottom rear of fridge.
Thank you for using fixya
Leo Ponder
Please rate me if this helped.
Jul 24, 2011 | Kitchen Ranges
Ice maker is not making ice? Is their a problem with the water? Do I need a new ice maker?
Check to see if water is entering the ice maker.
Be sure the water valve is working and it is not clogged
Have you recently changed the filter ?
Oct 13, 2010 | Amana ARB1905C Bottom Freezer Refrigerator
Our ice maker stopped working. there is water
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
hfdjdfh
May 29, 2010 | Maytag MFD2560HES Bottom Freezer French...
My refrig stop making ice after I changed the water filter. I had the filter out for about 3 hrs, would this cause the problem?
Hi, first , pour about 2/3 cup of water into the ice maker . If if freezes , and dumps , replace the water valve. If it does not dump the cubes , replace the ice maker. After pouring the water into the ice maker , remove the bottom kick panel , and clean the bottom coils , of dust , lint , pet hair , etc , as this will raise the freezer temp . An ice maker has to be 5 degrees , to operate , correctly . If ice maker starts working , after cleaning the coils , GREAT ! ( it does happen ) .
Take care
May 28, 2010 | Maytag Ice2O 24.9 Cu. Ft. Side-by-Side...
Not making ice
Hi: Change or just remove the water filter first. As your water dispensing slowed that is a clue. If the water filter is that clogged it will cause a problem with the ice maker. Plus the water you drink is not filtered anymore. City water is being run through 2 years of crud. If you don't replace it just remove it. I hope this helps, Jeff
Jun 03, 2009 | Frigidaire FRS3R5EMB Side by Side...
Bad water & ice cube taste
the feed line of the water source is bad replace it you will also need to clean the ice makers insides to remove the rest of the contamination
and 2 more suggestions:1) change the filter - older refers have the filter in the water line serving the ice maker - newer refers have the water filter in the refer (it looks much like an auto oil filter); 2) do not store ice for extended periods when ice use is not high e.g. during cooler months. Unless you use a full basket of ice over say a few weeks you should dump all and start over periodically.
thanks.
Sep 16, 2008 | Refrigerators
My whirlpool refride #GD5RHAXNQOO is not releasing water to the ice maker fill line
you need to check the water valve in the back of the unit it is a daul valve you can switch the wires to test should have 120v
May 25, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Whirlpool Gold White-on-White 21.9 cu. ft. Conquest Side-By-Side Refrigerator with Ice and Water GD2SHAXLQ Side by Side Refrigerator Logo
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
