Question about Maytag Neptune MAH5500B Front Load Washer
My washing machine smells where is the filter does it have a filter all other machines do
    Master:
  • 413 Answers
Run a tub filled with a couple of quarts of white vinegar thru the cycles. It generally reduces smell of mildew and bacterial odor. Clorox works too. Run rags or other "throw-away" laundry during these cleaning methods.
Posted on Oct 08, 2010
What do I put in the machine for the tub clean cycle?
john low temperatures washing can cause the machine to smell
if it was me i would set the machine to it's hottest wash and use a descaller or bleach and washing liquid ,after wash has finished give it an extra rince cycle./ scrum around rubber seal behind door before starting wash. check pump filter is clean,
Sep 22, 2016 | LG WM1814CW Front Load Washer
Low water level
Clean the intake filter and drain pipes
Pour the vinegar into a measuring cup and head over to your washing machine.
  1. Add the baking soda mixture to the detergent container of your machine and pour the vinegar into the drum. ...
  2. Use a clean scrubber to rub around the opening of the washing machine, removing stubborn mold or residue.
How to Clean the Inside of Washing Machine
Sep 10, 2016 | Washing Machines
Where are the filters
as you stand in front of it look to the bottom right it is behind the flap
Jan 30, 2014 | Bosch Washing Machines
The clothes smell when they come out of the washing machine. Is it the machine, is there a filter somewhere, is it the water???
its the water .run the hot water in the house till the smell gos away.washer has no filter
Sep 18, 2011 | Washing Machines
Horible smell comingfromthe drum, took the filter out to clean it, now it is leaking, what can I do? ps smell still there, have tried 1 95o wash with no joy
For the pump try taking filter back out and putting back again for smell clean out the rubber door seal with soapy water after the door seal is clean clean the despencer draw fully by taking it out. When you washed the seal and draw get washing machine clean for local super market and do a 95oc wash it should smell nice now if not could be drains hope this helps.
Jul 29, 2011 | Hotpoint Aquarius WF220 Front Load Washer
The washing machine smells!!
Run a load of just water and chlorine bleach. Run it HOT. After that, use bleach to clean the door seal and seat.
Apr 10, 2010 | Zanussi ZWF1640 Front Load Washer
Trinity Bendix 1000- inside smells of drains
are you using gel casules that go into the machine instead of powder if so stop using them and go to powder also put a small cap full of bleach in machine and put machine on a hot wash no clothes in.let machine rinse through
Jun 23, 2009 | Tricity Bendix WDR1040W Front Load Washer...
Machine smells mouldy- washing stinks!
Find out where your filter is; it is at the end of the thick hose coming down from the bottom of your tub; open up and clean out. Another possibility is there could be something stuck in your drum, feel if you could locate it. Next clean out the hoses in machine. After all this flush out with a hot wash, without clothes. People shd ask the service man where the filter is. If he knows that is.......................It gives you the biggest problem if you dont check.
Mar 19, 2009 | Whirlpool Washing Machines
Hi, I have a Baumatic Washing Machine (not sure of the model) and cannot find the filter. The machine gives off an awful smell which I am trying to fix
you should find the filter but that is not what is causing the smell. common causes of smell are:
using liquid detergent - this smells like drains if used for a long period and leaves a horrid sludge in the tub. put on a boil wash with no clothers and use powder detergent
plumbed in under the sink and there is also a waste disposal unit. these pong!
no water barrier between the drain of the washer and the house drains
Jul 10, 2008 | Baumatic Washing Machines
Cant find my filter o a hotpoint first edition
i cant find the filter on my aquarius either, but i just read somewhere that this egg smell is probably caused by u mostly running the machine on cool washes i.e 40' ? so its suggests u run the machine on a 95' empty wash using ure normal detergent 2-3 times a year as the smell is a build up of bacteria because your washes arent hot enuff to kill it. If ure egg smell is bad, i'd do the empty hot wash thing a couple of times to make sure ! hope this makes sense?! :)
Apr 30, 2008 | Washing Machines
Maytag Neptune MAH5500B Front Load Washer Logo
115 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
