Question about Ovens
Dont know how to set clock on noble oven model: znf4cta/wh-fcd series: p60 can you help please. ray johnson
SOURCE: smeg oven SA392EB cannot reset clock
Turn off at mains, turn on again. 0:00 will flash press the manual op key ( on mine button on right) use +/- keys to set the time. Don't use buttons with wavy lines as they are for setting auto cooking time.
Posted on Dec 08, 2008
SOURCE: clock
Hi this is propably too late now but we moved in to our new house six months ago and have a Zanussi ZBF 360 oven, and had no idea how to set the timer / clock. After fiddling around with the oven clock for the last 6 months i managed to set the clock. It shouldn't be much different to the one you have. Hope this helps you and others in the future.
Click the middle button until the little red things on the screen moved round to the clock symbol, then press + or - to get to the correct time, once you have done this it will flash for a few seconds then it will stop flashing and the clock is set. The same goes for the timer to set it when you want to cook something for a period of time eg: ten mins.
As for getting the oven timer to turn it's self on and off I am still messing with it and when i have mastered it I will let people know.
Posted on Feb 01, 2009
SOURCE: Neff series 1 oven
press the two arrow buttons in at the same time as turning the pop out knob
Posted on Feb 12, 2009
SOURCE: I have an Ariston oven (model;208587057) but no manual
Hi
Press and hold the two buttons with the casserole dish on (one is crossed out) and use + or - to change the time.
Hope that helps.
Posted on Feb 22, 2010
  • 250 Answers
SOURCE: Simpson Apollo can't set clock so oven won't work
I don't know if this will help. For the 720ef , this is what you need to do.
There are five buttons on the clock panel and from left to right they are:- Minute Minder, Cook time, Ready Time, Plus and Minus.
TO SET THE TIME OF DAY
Press the Cook Time button and the Ready Time button simultaneously. Use the Plus and Minus buttons to set the time.(24hr clock).
TO SELECT AN ALARM TONE.
Press the Minus button to listen to the first tone. Release it and press it again to listen to the second tone etc (3 tones)
Releasing the button after the tone has sounded will automatically set that tone.
SETTING THE MINUTE MINDER.
Press the Minuter Minder button and either the Plus or Minus buttons simultaneously to set the time.
You can cancel the timer at any time by setting it back to 00.00 by using the Minus button.
After setting, the display will revert to the time of day, but by pressing the Minute Minder button again, the display will show the remaining time.
If you want all the information, then it is best if you supply a vaild email address and this will give you access to my BT Digital Vault, where you can have a complete copy of the handbook that I have scanned in.
Posted on May 29, 2010
I cannot set the clock on my candy oven and I dont know the model number
The model number is usually on the side or rear of the oven.
Instructions for the clock are here:
http://www.manualsdir.com/manuals/243352/candy-fdp-231-x-uk.html?page=11
Nov 22, 2014 | Candy FP855 Electric Single Oven
No name on the oven so presume it's a Europa same as the cooktop. It won't move off 0:00 with automatics on the lefthand side showing.
Hi -
I'm assuming this is an Omega/Creda Europa oven. All you need to do to make the oven work again is set the clock. The 0:00 and "AUTO" will stop flashing and the oven will work again. You didn't specify a model number, but you should be able to set the clock as follows:
1. Hold down the two buttons on the left-hand side under the clock display. One should have a symbol of a bell and the other, a symbol of a cookpot (not a cookpot and 'STOP').
2. While still holding both of these buttons, use the + and - buttons to set the clock to the correct time. The clock needs to be set in 24 hour format.
If this doesn't work, look for the buttons under the clock with the bell symbol and the cookpot symbol. Hold both of these buttons in and use the + and - buttons to set the clock.
If this doesn't work or your clock doesn't have these buttons, let me know and I'll check for other possible methods of setting the clock on Europa ovens. If you can find the model number it would assist me greatly. This should be on a sticker on the rim of the oven and can only be seen when the oven door is open - possibly at the bottom. The model number should be something like 40-1, 60-1 or 66-1.
If you can't find the model number, please let me know how many buttons there are in total below the clock and which symbols are written above each button and the order from left to right. I will then be able to provide the correct instructions for your oven.
Hope this helps.
Regards,
BElectric
Apr 18, 2011 | Ovens
Everything works on the oven except the oven , wh...
If you mean that the fan in the oven will not come on check that the clock just needs resetting.
Hope this helps.
May 20, 2010 | Ovens
F7 keep popping up on my wall oven
The fault code is for the ERC The ERC electronic Range Control has failed. If shutting off the breaker for at least 5 minutes does not clear the code you will need to replace the erc. This is the main control located behind the clock assembly. This is easy to replace but usually not to inexpensive. Enter your complete model # at www.appliancehelponline.com and you can pull up diagrams and illustrations of your specific model. All parts come with installation instructions.
May 12, 2010 | Kenmore 42161 / 42169 Electric Single Oven
The oven will not operate after I switched the mains power off. The clock is flashing 0. Any help appreciated !
I dont know your model but it seems like the clock needs resetting if you have a manual it will tell you in the book.if not just keep pushing buttons. normally holding the 2 on rhs then pressing other buttons can do it keep fan oven switched on as you try to reset
Hope this helps.
Good Luck.
Apr 11, 2010 | Ovens
How do I set the clock
Set the clock by following these steps: a). Touch TIME pad. b). Turn rotary knob clockwise until CLOCK appears. c). Touch TIME pad. d). Turn rotary knob in either direction. The time displayed will change in 10-minute increments and indicate AM or PM. Turn the knob in the opposite direction and the display will change in one-minute increments. e). Touch TIME pad. The clock is now set. in some units there is button instead of knob in that case the clock indicating button has to be pressed . This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Feb 06, 2010 | Bosch Appliances 27 in. Wall Oven Electric...
I have a Caloric Heritage Series gas stove in which the oven will not light but the broiler does work. This stove has a analog clock and we have no idea what the model is. Please help us. Thank you,...
We replaced the igniter which I bought from the appliance repair service. We now have a working oven.
Thankyou for responding to my email.
Cheryli
Dec 29, 2009 | Ovens
Glass outer oven door panel
check sears parts.
Phil
Jun 10, 2009 | Ovens
Electric stoves
if the model has a digital clock and when the power went of it may have fried the little computor.if you dont have trip switchs in fuse box
Nov 07, 2008 | GE JGRP17 Gas Single Oven
Neff series 1 oven
Aug 04, 2008 | Neff B1421 Electric Single Oven
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
