Question about Whirlpool Duet GHW9150P Front Load Washer
I cleaned the trap but the empeller sounds as is it hitting sometheing but I was not able to feel anyhing around the empeller. pump motor seems to be running hot and smells as if it burning
My kenmore elite HE3T Front loader; Drain Issues. after cleaning out the drain tray, which had nothing in it, I noticed impeller was way out. I pulled the motor off. impeller was way out. I pushed it back in. machine work fine on drain and spin.
So I ran another load. F02 again at first drain. turned machine off for 20 minutes then back on drain pump water out fine till next drain. Each time shaft and peller is pulled out and no trash causing this. Is there away to temperaley glue/jb weld that haft in til I can replace pump motor?
Posted on Jul 31, 2011
  • 5,911 Answers
Replace your drain pump. It does not take much to damage these small drain pumps. If anything was lodged in the pump reservoir for any significant period of time it could have damaged the impeller blades, impeller shaft, or pump motor. So, if the impeller or motor become damaged, and the pump does not pull water at the correct volume, you may experience drain error codes if the drain cycle exceeds 8 minutes. If this occurs, you will have to replace the pump in order to get any errors to clear, or the washer will not complete any cycles. The following link explains how to replace the pump:
http://www.fixya.com/support/r3574350-replacing_the_drain_pump_in_a_front_load
A replacement can be purchased at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
Prices vary between sites, so shop and compare. The first three sites listed also have helpful exploded view parts illustrations to assist you with locating and properly identifying the parts you may need. If the model number is correct, the part number is 280187. The pump comes as a complete assembly and parts cannot be purchased separately.
NOTE: For a full explanation of all the error codes, each one of these appliances come with a technical data sheet inside.
To access, you will need to remove the lower toe panel under the door. The access screws are located under the bottom front edge of the panel. You may have to prop the two front fett of the washer up for better access ( a 2x4 works well for this). With the screws removed, the panel should drop down, then come off. If the tech sheet isn't directly behind the panel, it will be affixed to one of the interior cabinet walls.
The tech sheet lists all error code definitions, troubleshooting data, diagnostics procedures and wiring diagrams. I mention the tech sheet because you may need it to troubleshoot this error code.
Read through the information provided, and if you require additional assistance, please post back and let me know.. I hope you find this information helpful.
Posted on Oct 08, 2010
My washer just came to the end of the wash cycle and started making a loud grinding noise when it is time to drain. It won't drain.
from your description , there is something interfering with the impeller in the water pump
could be button, coin , hair clip, bra wire that has damaged the impeller blades
Rather than mess around trying to repair I would just get a new unit as the same time and difficulty is for both operations
Dec 10, 2015 | Washing Machines
Suds, F02, clicking sound from drain pump/motor
Hello & Welcome to FixYa
F02 is a drain error in your Kenmore washer, if the unit is unable to drain then after 4 minutes it will display suds and then F02. The first thing that should be done is cleaning the drain hose and the drain pump filter, you can take out three torx screws from the bottom front panel and then clean the area completely, lift up the cap to clean the filter. If the error returns then check the drain pump if it is not working then replacing the pump is recommended repair. Please get back to me if you have any other questions.
Kevin
Nov 24, 2011 | Kenmore Elite 45986 Front Load Washer
Kenmore He3t, doesn't consistently drain. Sometimes no problems other times problems during the cycle. When there is a problem you can hear clicking coming from the pump and eventually an error...
Hello, you should definetly try to clean the filter again. You should also remove the line that goes to the pump as well and assure that there is nothing trapped in the drain line that goes to the pump. If you do not find anything clogged in this line then you would remove the other end of the line that connects to the bottom of the tub as well. Many times when I remove this line I also assure that there is nothing stuck on the inside of the tub or blocking the water exit port that comes off the tub. I have found many items such as drill bits, pens, pencils, brazier wires etc.... If you remove the filter as well as the drain line and find there is nothing clogging this area then message me back for further diagnosis. If you have any questions as well please message me back those as well. Also please remember as well when our chat has fully concluded to rank how this opinion has helped in your appliance situation it allows me to continue helping others in similar situations in the future.
Thank you,
Rick
Sep 24, 2011 | Kenmore Elite 45986 Front Load Washer
Front loading washer, kenmore 417.42052100 won't completely drain and leaves a tub full of water. Has been getting worse over the last week and now won't drain at all. Took off front panel to try...
The drain filter/coin trap is blocked or the pump is no longer working. The filter/trap is located inside the big black hose that runs from the bottom of the tub to the pump and hence the name tub-to-pump hose. Clean the filter and inspect the pump impeller for damage or restriction.
Disconnect power then remove the screws attaching the bottom front panel to the cabinet then pull the panel down and off. Once the panel is off, you can now loosen the clamps securing the tub-to-pump hose to the bottom of the tub and the pump's inlet then take the hose out and clean the filter/trap.
You should find foreign objects such as coins, toothpicks, hairpins and the likes blocking the filter. Clear the filter from the foreign objects and inspect the pump impeller by turning it with your finger. The impeller may be restricted or damaged resulting in the water not being pumped out properly or none at all. Replace the pump if the impeller is broken or restricted and doesn't turn freely or if the pump is no longer operational. You can tell the pump is no longer operational if all are clean and the impeller is in good shape and turning freely. Reassemble the machine by following the steps above in reverse order.
When installing the filter in the coin trap, the top ring of the filter MUST be seated in the 3rd convolution from the bottom.
Jun 20, 2011 | Washing Machines
Hi - 2000 alero temp gague it maxing out at hot then it drops - but car is not smoking ? I filled it w water instead of coolant to top it off - I dont see any fluids leaking - now there seems to be a...
if the system was low it may have air trapped. look for a bleeder screw around the thermostat housing.open bleeder with engine running until all air is out.
on some modles there is a 2nd bleeder around water pump area
Jun 13, 2011 | 2000 Oldsmobile Alero
How do you take the empeller off the shaft to put it on the new m
Take the back of the motor off, just a cover, you should find a flat spot on the shaft to fit a wrench, hold the shaft and spin off the Impeller.
Feb 20, 2010 | Emerson THREADED SHAFT UP RATED - 1.00 HP...
Loud "squalling" noise during spin cycle
absolutely! As a matter of fact I own a laundry mat and have to clean out the pumps on a regular schedule and you would not beileve what i pull out of those things
Aug 23, 2009 | Maytag Performa PAV2200
Noisy when spining
It is possible, but it involves a strip down, which I would not recommend,
the only other way you might retrieve a foriegn object is by removing one of the drum lifters inside the drum.
Grasp one of the lifters and pull it firmly towards you, this should then lift out ,and you can feel around to see if you can locate anyhing.
to replace lifter, insert it into the slots, and push it firmly towards the rear, you should feel it click into place.
Plz rate my solution.
Thanks.
Dec 02, 2008 | Hotpoint WMA64 Front Load Washer
Motor noise
it could be something caught in motor empeller IE. a bit of glass, or motor could be faulty
Nov 27, 2007 | Admiral 24 in. DDB1501AWW Free-Standing...
Whirlpool Duet GHW9150P Front Load Washer Logo
74 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
