Question about Maytag Washing Machines
DRUM OUT OFF BALANCE IN HI SPEED /ENTY OR FULL
    Genius:
  • 1,122 Answers
CHECK TO SEE IF A TUB SPRING IS OFF,SOME WASHER TUB SIT IN A V,PULL UP AND TURN TO SEE IF YOU CAN GET IT BACK IN THE V,ALSO MAKE SURE LEVEL AND YOUR CLOTHS ARE EVEN IN THE TUB,THANKS-MIKE
Posted on May 29, 2008
Spin cycle is slow
Are you using the correct setting? Some settings only spin slowly (for delicates for example) and other settings spin at various speeds. When the load is off balance it doesn't get up to full speed either.
If it used to work at full speed, is your belt loose and slipping when spinning? Motor could be going at full speed but the drum is not. Is there an unusual or different sound? Possible smell of rubber as it slips?
Aug 19, 2015 | Washing Machines
My maytag neptune mah3000aww spins slowly then reverses, then spins slowly. will not reach regular spinning speed. What is the problem?
it could be a balance problem. Most machines are programmed to abort fast spin if the drum is unbalanced. This can be caused by too much in there, or possible the contents have clumped together somehow. Try a spin cycle only with an empty machine and see if it reaches full spin
Feb 18, 2015 | Maytag Neptune Washer Door Mah3000aww
Washer out ballance
Hi Joe
Check lower balance springs, remove front panel to view there are 6-8 of these, to gain access and remove the front cover, insert a knife or thin blade approx. 4" in the from each side in between the seam on the front panel, this will release the top cover clips and the top cover can be hinged up and back. undo the two top screws to remove the front panel. Also check drum is rotating at full speed when spinning, if not spinning at full speed check and replace drive belt.
Dec 03, 2013 | Admiral Washing Machines
Admiral model lnc6762b71 tub dosen't center itself
Check balance springs at the bottom of the tub/drum. To gain access and remove front panel insert a knife or thin blade approx. 4" in the from each side in between the front seam on the front panel, this will release the lid clips, lift and hinge back the lid panel, remove the two screws securing the front panel and remove, there are 6-8 springs at the bottom, check all are intact.
Also check drum is rotating at full speed, if not check and replace drive belt below the machine, tilt machine back to gain access, flip belt off the pulleys and replace same way.
Nov 30, 2013 | Admiral Washing Machines
Going out of balance
could be the springs are wearing out. some haier models I have seen start the spin at full motor speed, which could be part of the problem.
Nov 20, 2013 | Haier Washing Machines
My GE profile WPDH8800J doesn't hit high speed
Your belt may be slipping and not spinning the drum to full speed to rid most of the water in clothes.
Sep 09, 2017 | General Electric WPDH8800J Front Load...
Washing machine noisey when drum turning
Hi, Try these out:
  1. Balance the load
  2. Level the machine
  3. Inspect the water pump for a blockage
  4. Inspect the coupling
  5. Inspect the transmission
  6. Adjust the drive belt tension
  7. Check the motor bearings
  8. Check the drum brakes
please rate my suggestion...
May 18, 2009 | GE WJSE3110A Top Load Washer
Hotpoint WF321 during rinse and spin, will not go into full spin as machine keeps filling with water.
you should check your pressure switch hose for a pin hole or better still just replace the hose and it should sort your problem out good luck hamstel
Nov 05, 2008 | Washing Machines
With only 1 item in Drum my new Bosch WAE24363 will not perform a spin cycle, yet adding more item into the drum then the machine will perform a full spin cycle. Why will the machine only do a full spin...
most modern machines have an out of balance detector to prevent the machine being damaged with a badly balanced load.
with a single item in drum, load will not balance and out of balance detector comes into action and prevents spin
Sep 09, 2008 | Bosch Washing Machines
Washer turns slow loaded or not
front load machines will normaly spin slow on first part of spin cycle this helps distribute load evenly before hi speed spin also if load is extermely off balance ..a large towel with load of light fabrics will never spin to full speed due to off balance produced by wet towel hi speed spin is normaly acheived in last 3-4 min of spin cycle
May 11, 2008 | GE WBVH6240F Front Load Washer
Washing Machines Logo
74 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
