Question about Dell ? SP2009W 20" Widescreen Flat Panel Monitor With Webcam R14SP2009WAU
My monitor is not turning on at all. No standby light comes on after plugging it in.... i have tried two cords and still no luck
  • 11,361 Answers
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed DELL monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Replacement board: http://www.lcdrepair.us
Posted on Oct 08, 2010
  • daniellawin Oct 08, 2010
    I just found out my warranty is non-existent... How am I going to open this thing up. It looks like it has some sort of lock
  • Bud Martin
    Bud Martin Oct 08, 2010
    There are installation video where you can get the replacement boards for DELL http://www.lcdrepair.us
Samsung 931bf
A surge may have fried it if you didn't have it on a UPS (Uninterruptible Power Supply).
Here's some tricks I would try. Something here, might help...
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or orange or flashing, but nothing displays, or the display is incorrect, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
7. Also, you could try your monitor on a friend's computer. If it doesn't work, your monitor probably needs replaced. If it works properly on your friends computer, the problem may be with your computers video output port, motherboard video chip (or video card, if you have one), or drivers.
Good luck.
Aug 04, 2014 | Computers & Internet
Have emachines monitor which is not coming on power button fast flicker
Which power button is flickering (your computer, or your monitor).
Here's some tricks I would try...
7. Also, you could try your display on a friend's computer. If it doesn't work, your monitor probably needs replaced. If it works properly on your friends computer, the problem may be with your computers video output port, motherboard video chip (or video card, if you have one), or drivers.
Good luck.
Aug 02, 2014 | eMachines Computers & Internet
It display every thing for few second and get off display itself but not power when i switch off on then it come back then again get off
Good luck.
Jul 18, 2014 | Computers & Internet
My samsung P2050 screen keeps coming on and then turns right off does anybody know what that might be
Good luck.
Jul 12, 2014 | Computers & Internet
My hp turns on but no pictuer on monitor
Ensure the monitor cable is firmly plugged in and screwed at both ends.
Check if monitor comes on at all (standby light / power light / any kind of writing on scree.
Test monitor and cable with another computer.
Test your computer with another monitor.
Find out for sure which parts of your system are defnitly workng.
Good luck and post back on your troubleshooting progress.
Jan 24, 2011 | HP Pavilion a1340n PC Desktop
Kdl-52xbr4 5 blinking standby lights
The Standby/Power light of the TV blinks when there is any internal malfunction in the TV.
The self-diagnostic function of the projection TV will cause the STANDBY light to blink or flash when the television detects an issue. The number of times the STANDBY light flashes corresponds to a specific issue. As per the two examples below, some of the issues may be resolved without the need for service.
If the STANDBY light flashes three times in sequence, the lamp cover is not securely attached. Reattach the lamp cover to resolve this issue.
If the STANDBY light flashes four times in sequence, the TV may be overheating. To resolve this issue, ensure that the back of the TV is well ventilated.
If the flash sequence is not listed above or the light continues to flash, follow the steps below to perform a power reset:
Try the following steps to check if the issue can be resolved.
Turn off the television.
Unplug the television power cord from the electrical outlet.
Let the television remain without power for 60 seconds.
Plug the power cord back into the electrical outlet.
If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
If the issue continues to occur, service may be required.
Thanks for using Fixya.
Dec 15, 2010 | Sony KDL-52XBR4 LCD Monitor
I have a sony wegs lcd tv with a seperate monitor and media centre. when I turn the media centre on the monitor lights up green on the stand by light and then afetr a couple of seconds the monitor switches...
The STANDBY light will flash if the television detects an issue within the television. Some of these issues can be resolved simply by following the steps below to reset the television.
If the issue is still unresolved after following all of the troubleshooting steps, service may be required. Please note the number of times the STANDBY light flashes and relay that information to the service center.
  1. Turn off the television. Unplug the television power cord from the electrical outlet.
  2. Let the television remain without power for 60 seconds.
  3. Plug the power cord back into the electrical outlet. NOTE: If the television is plugged into a power strip or surge protector, remove it from the power strip or surge protector and plug it directly into the wall outlet. If the issue is resolved, the problem is with the power strip or surge protector and not the television.
  4. Turn on the television.
Sep 21, 2009 | Sony FD Trinitron WEGA KV-36XBR800 36" TV
Plasma screen not coming on at all
IF it is not an adaptor-powered screen, try to exchange the tripol-power cord and try again.
Else you may have to rely on warranty/ return it to where you purchased it or ask electronics dealer for support.
If adaptor powered, buying a new one should be the last option, else you may end up with a broke monitor and two working adaptors!
Good luck
Aug 04, 2009 | Computers & Internet
Monitor will not turn on
1 check plug & socket 2 check for cord 3 power supply in monitor to br checked 4 if it is ok check for horizontal section. if you are not tech person get the help. good luck
Sep 28, 2007 | Kogi l7eh-ta ko 17" Flat Panel LCD Monitor
Monitor switching to standby - CV735 monitor with Presario 5000 series desktop
my compaq crt monitor not showing color. its shows only blue, green colors . u please tell me. what is the problem in.how to solve it.
is the monitor fault or any other.
Oct 30, 2006 | Compaq CV735 17" CRT Monitor
Dell ? SP2009W 20" Widescreen Flat Panel Monitor With Webcam R14SP2009WAU Logo
127 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
