Question about Singer 7436 - INGENUITY
Hello when i manualy turn the hand wheel to bring bobbin thread up it does not work. the machine was working fine until it jammed and i noticed the timing was off and so i thought i fixed it because needle was no longer hitting bottom plate as it moved up and down during stitching but, the machine now does not actually stitch. it will do the motion like it is fine but no stitches are created. what is the correct way to fix the machine when the needle is hitting the bottom plate while sewing{i paid for a singer place to fix the timing once before because my receipt was to damaged to show proof of purchase and so my warranty non existent. i noticed that the machine is making the same sound and operates the same way it did when it needed to be fixed the last time i took it in. i turned the metal plate underneath the bobbin thread holder to keep the needle from hitting but still no complete stitch the two are not meeting each other some how please help me it is so important i finish my child's halloween costume for his school play tomorrow evening. thank you so very much
    Genius:
  • 1,788 Answers
I would call Singer at 1-800-4singer and explain this problem because it sounds like the timing again for you, I am sorry to say. You may have messed up the timing when it jammed. Just on the off chance did you put a new 80/12 needle in? I read somewhere when they try to fix the timing they use this size needle to test it. How old is your machine? Who did you buy it from, did you use your credit card? If, so the store you bought from should be able to help you out. It looks like a really nice machine and it is a shame that you have to put up with the problems. You may be able to get an answer from this site better but I am answering you for free and all I have is 50 yrs experience in sewing. Please call Singer and don't take no for an answer.
Posted on Oct 08, 2010
Thread jammed in the bobbin area and unable to move the needle
Switch off machine. Snip as much thread away as possible, take tweezers and pull out all loose thread; remove bobbin case if possible; remove needle plate and work from the top; turn crank wheel by hand gently to move needle up and down. It should shift in time if you work carefully to remove all jammed threads.
Mar 10, 2015 | Sewing Machines
The bobbin thread will not raise with the needle
1. REPLACE NEEDLE W/FLAT PART AWAY FROM YOU.
2. MAKE SURE THE TOP THREAD IS PROPERLY THREADED.
3. INSURE BOTTOM BOBBIN IS ROTATING RIGHT DIRECTION. (USUALLY COUNTERCLOCKWISE) ALLOW THREE INCHES OF THREAD PULLED AWAY.
4. HOLD TOP THREAD W/LEFT HAND AND ROTATE HAND WHEEL TOWARDS YOURSELF. DOES IT BRING THE BOBBIN THREAD UP?
5. IF THE BOBBIN CARRIER IS INSTALLED PROPERLY THE HOOK (POINTED OBJECT) UNDER THE BOBBIN SHOULD "HOOK" THE TOP THREAD AND BRING THE THREAD AROUND THE BOBBIN THREAD. THE NEEDLE AND TOP THREAD SHOULD BE PULLING THE BOBBIN THREAD UPWARDS. IF THE HOOK DIDN'T "HOOK" THE NEEDLE THREAD THE PROBLEM IS THE DISTANCE OF THE NEEDLE AND HOOK APART OR THE TIMING. YOU MAY TRY TO MOVE THE NEEDLE TO THE LEFT SIDE AND AGAIN TRY ROTATING THE HAND WHEEL. IF IT DOESN'T WORK THEN TRY TO MOVE THE NEEDLE ALL THE WAY TO THE RIGHT AND ROTATE THE HAND WHEEL. IF IT BRINGS THE BOBBIN THREAD UPWARDS IN EITHER CASE IT WILL SHOW A PROBLEM WITH TIMING. THIS WILL NEED TO BE ADJUSTED BY A PROFESSIONAL.
6. REMEMBER TO PUT ONE DROP OF OIL ON THE RACE TRACK BEFORE YOU PUT THE BOBBIN CARRIER IN.
Jan 13, 2015 | Singer HD-110 Mechanical Sewing Machine
Thread becomes jammed in reverse
Reverse can be tricky if the machine is not timed correctly. So try this. after you've stitched forward for a while, use the hand wheel to bring the needle all the way down into the fabric and let it come part way up. Then push your back button and take your back stitches. If that works for you then you know the machine should be checked for proper timing.
Oct 02, 2013 | Singer Sewing Machines
The thread hangs up inside the bobbin holder
A jammed machine is caused by thread being caught in the hook. Remove the upper thread and the bobbin case, turn the hand wheel towards you (counterclockwise) by hand and remove any thread in the bobbin case area. *Always turn the hand wheel towards you. Turning the hand wheel away from you (clockwise) can cause the machines timing to become unaligned and jam your machine. Also, always make sure the presser foot is in the down position before you start sewing. Sewing with the presser foot in the up position will jam your machine in the bobbin case.
Sep 26, 2010 | Singer 2517 Mechanical Sewing Machine
Machine is jamming
You need to remove the bobbin from the "race" by following the instructions in the manual. Give it a good clean and remove any bits of fluff and thread. Remove the upper thread also andmake sure that the tension wheel is clear of any broken threads and is on the correct setting. It may have been threaded wrong. The hand wheel not turning sounds like the bobbin area is jammed also.
Jun 10, 2009 | Singer 8280 Mechanical Sewing Machine
Sewing machine jammed wheel will not turn
Thread is caught in the hook...Remove the upper thread and bobbin case...turn the hand wheel backwards and forwards by hand and remove the thread remands. Good Luck
May 17, 2009 | Brother CS-8060 Computerized Sewing...
Brother ls2125 bobbin not picking up thread
OK...I have an old singer (from 1964) so I am not sure whether you can do this...
I thread the upper thread as directed.
I stick the bobbin in the bobbin assembly as directed.
LEAVING THE SLIDE DOOR OPEN...I, by hand turn the wheel on the right hand of the machine counter clockwise (towards me). I want the needle go down. The thread from the upper part will enter the bobbin area and will form a loop that goes OVER the top of your bobbin to catch the thread from the bottom.
I keep turning until the machine has complete a cycle where the needle has started from the highest point, dropped to the lowest point (thus forming the loop that passes over the bobbin) and returns back to the highest point).
At this point you will notice that the thread is coming for from the bottom of the machine..I use a scissor to pull the the ends of the thread through. To the top. There should be two ends, one from the top thread, one from the bottom. If you dont believe me..jsut use a bobbin with a different color of thread...you will see what I mean..there will be two threads...one the first color and one the second color.
Good luck!!
Jan 17, 2009 | Brother LS-2125 Mechanical Sewing Machine
Hand wheel won't turn
I continued to try to get the bobbin out. I finally decided to break it out. Once it was out I tried pulling the case out so I could see if anything was jammed underneath. It took a lot of work but it finally popped out like the manual said it should. I cleaned it out, nothing really dirty, no thread jams. When I went to put it back together I noticed that the way to put it back was not the way the case was sitting when I took it out. So I figure that my son must have jammed it and somehow knocked the bobbin case out of alignment. I put it back in correctly and it works just fine now!
Jul 06, 2008 | Brother CS-6000
Kenmore 385. 11607 needle jams into shuttle or shuttle race
I had the same problem with cleaning and jamming and this might sound silly, but when you're in the middle of trying to fix it remember to look up see that it is threaded up top. I did everything the pp's suggested and when they didn't work I realized the top thread wasn't still threaded around the tension thing anymore. After rethreading it, it worked fine. But I DID reduce the amount of thread on the bobbin at the same time as Drazil suggested.
Dec 17, 2007 | Kenmore Drop-In Bobbin 505S-21BH...
Bobbin problem: Huskystar by Husqvarna Viking E10 sewing machine
This has happened to me, even though I have been sewing for 30 yrs. When I take the bobbin holder out I realise what I have done wrong. When placing a bobbin into the bobbin holder the thread must be running around the bobbin CLOCKWISE. If incorrect take bobbin out of holder turn it over, so now the thread will run clockwise.If bobbin placed in holder and thread runs anti-clockwise, when you tried to turn wheel to bring bobbin thread up, it will either not do it at all or will make a huge tangle of the threads. Happy Sewing
Nov 17, 2007 | Sewing Machines
Singer 7436 - INGENUITY Logo
118 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Level 1 Expert
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
