Question about Frigidaire FMV156D Microwave Oven
Hi my Frigidaire fan won't turn off. How can I fix this??? I turned the breaker off but it didn't fix anything
The interior light and fan will not turn off on My Frigidaire microwave model FGMV175QF. It looks and sounds as if it is still cooking, but is isn't. Anything I can do to reset it or fix this?
Their is nothing to reset. Most common problem is a defective door switches. If you know electronics you can pull the covers read the diagrams and check the door switches.
Nov 09, 2015 | Frigidaire Microwave Ovens
My frigidaire microwave fan turned on by it self. Won't turn off. Blowing air above Microwave
Try unplugging it for a few seconds or turning off the circut breaker to it. This usually resets the unit.
Jan 03, 2015 | Microwave Ovens
Fan & Surface Light not working on Frigadaire Microwave Oven. Model PLMV168CC1
Hi J W, thank you for your post! Let's try resetting the microwave by either unplugging it or flipping the household circuit breaker off. It is important to wait roughly ten minutes and then turn the unit on. If both the fan and light continues to be inoperable, then there is a possibility that the control board is experiencing a communication error, a wiring failure or loose connection to the light socket. I would recommend reaching out to a qualified technician or alternatively, visit the manufacturer website for a comprehensive listing of appliance techs in your area that can further assist you.
Aug 26, 2013 | Frigidaire PLMV169DC Microwave Oven
Frigidaire microwave plate won't turn
The motor for the rotator is bad. It has to be replaced.
May 06, 2013 | Frigidaire Microwave Ovens
I have a microwave oven over the range ,brand Frigidaire , model CFMV156DC purchased in 2006 and stopped working , even the lights on the front panel are on when I press the start button it happened just a...
I have exactly the same problem. Everything works perfectly even fan, except microwave table won't turn. I just found out what's the problem... The door for some reason is sitting too low now, even though it is not obvious at all. It looks leveled with everything else, but it's not. Set your Microwave to let's say 30 seconds and turn it on. It will not do anything... but you just gently lift the door (while closed of course) few millimeters and your Microwave will start running like new. There is something wrong with those latches on the door, not touching the microswitches inside the Microwave. Doors must be properly closed in order for Microwave to work. This is due to poorly design. I yet have to figure out how to fix that permanently.
Apr 15, 2011 | Frigidaire FMV156DC Microwave Oven
The microwave won't stop.
You probably have a bad door switch or door switch mount. See this file.
May 05, 2010 | Frigidaire Built-In Microwave
Frigidaire Microwave Fan won't shut off plmv169dcd
Had the same issue, leave Microwave unplugged for 30 minutes and then plug back in. My fax stopped blowing and now fucntions 100% normal again HI/LO / OFF
Best of Luck!!! :)
Jan 17, 2010 | Frigidaire PLMV169DC Microwave Oven
My Frigidaire PLMV 169 DCD has stopped working. The turn table rotates slowly, lights are lit but no cooking being done. The fan is off and no sound at all from within. What could have happened?
HI, have the power sector tested. test the HV capacitor for its operational value. this may be the actual issue but, testing is needed to confirm. there is a running diode as well on the noise filter board. have it tested as well. replace both componets if found to be defective.
Jun 28, 2009 | Frigidaire PLMV169DC Microwave Oven
Frigidaire FMV156D Microwave Oven Logo
71 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
