Question about Maytag Neptune MAH5500B Front Load Washer
My soap tray is moldy, how do I clean it up? - Maytag Neptune MAH5500B Front Load Washer
    Master:
  • 413 Answers
Pour some clorox or liquid bleach into it. Also run a wash of rags with clorox and vinegar a time or two and odors should clear up.
Posted on Oct 08, 2010
How do i clean the mold in my soap dispensing on a HE5t steam washer
Open the drawer and there is a tab at the rear, press down on it and the drawer will come completely out where you can take it to a sink and clean it good with some Tilex and a toothbrush. To reinstall it just push it straight in.
Aug 03, 2014 | Kenmore Washing Machines
Zannussi fl884
Check that the water pressure if enough for this appliance.
Other thing, check that the soap tray is clean and clear.
You should be able to pull the soap tray forward and press the release clip to completely remove the tray.
I would advise giving this a good clean out and check if you have any soap build up inside the tray area.
Apr 03, 2014 | Washing Machines
Moldy rubber door gasket
clean it with a water bleach mixture and make sure the door boot drain in the bottom of the boot isn't plugged with lint,soap,etc and can fully drain
Nov 18, 2010 | Maytag Washing Machines
The clothes smell moldy after washed in our Samsung frontloader. How can I get that moldy smell out?
1/4 cup powdered DISHWASHING soap and 1 cup bleach straight into the wash tub with a squeeze of lemon on a dirty rag HOT water wash. You may have to do this 2 to three times the first time.
Make sure your using HE laundry soaps.
There are at least 2 products out there for HE washer cleaning cycles. Tide and Affresh. It is in the laundry soap section of most supermarkets. You should use one of these type products at least one a month.
Thanks for choosing FixYa.
Kelly
Aug 16, 2010 | Samsung WF337AA Front Load Washer
What does de mean on the display of the washing machine? Yesterday I ran a tub clean because my clothes have been smelling moldy. I have cleaned the rubber seal & leave the door open. Please help??
de means your door isn't closed completely.
The moldy smell is really common with this machine, and maybe all of them, but I have the LG TROMM and was ready to throw away all of my towels. Here's a solution I found that helped alot. First, Clorox makes a solution just for front-end loading machines. You run it through on a cycle with no clothes, that helps to clean it out.
I ran my towels through on the cotton/towel cycle on HOT, with nothing more than white vinegar filling the detergent dispenser. After that, I then ran them through again with just a bit of soap and fabric softener. They came out soft and smelling like new.
I read recently that we all use WAY too much soap in both our washers and dishwashers, even though that's what's recommended in the directions. Excess soap in clothes that doesn't get rinsed out will begin to smell moldy. So I now use about 1/4 of what the directions call for, and they come out fine. I have found, however, that I need to repeat the vinegar cycle once every few months. I think the problem is inherent in that model machine.
And that rubber seal? Disgusting! I clean it out regularly, but when it's full of water after every load of clothes, what do they think is going to happen??? You'll find that Clorox cycle will clean the seal pretty well, though. Good luck!
Apr 03, 2010 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
How to get rid moldy smell in LG Front loader washmachine?
There are several cleaners for front loading washers on the market, such as affresh, washer magic, smellywasher cleaner, whirlaway hot tub cleaner, and tide washer cleaner. Clean out the filter located behind the access door at the lower left front of the machine, then, if your model has a tub clean setting, use that with one of those cleaners, if not, use one of those cleaners with the longest, hottest cycle. If things were very bad, you may have to clean it twice. Now, after it is cleaned out,.....STOP USING SO MUCH SOAP ! Use only one tablespoon of HE laudry detergent per cycle, and only one teaspoon of fabric softener if you use that. (Note: Bath towels, used only to wipe off clean bodies, then tossed into the laundry are not dirty enough to require soap usage, and should never have softener used on them) The odors in your washer are caused by a build up of soap and fabric softeners on the inside of the washer's drum. Also, you may have a build up of soap or fabric softener on your clothes. Wash them again once with no soap or fab softener to rinse them out.
Mar 17, 2010 | LG WM-2277HW Front Load Washer
How do I get the mold out??
Without a proper model number I would say you need to clean your washer with a product called Affresh or Washerfresh. If you don't wipe the door dry and the boot dry, also dry inside the boot between the tub and front of machine. Also, when you finish washing, open the soap dispenser or better yet, take the soap dispenser drawer right out between washings to to let everything air dry and leave the door open. If the smell still persists you will have to change the door boot. Best off to call a reliable repair company such as Sears.
Jan 31, 2010 | Frigidaire ATF6000ES Front Load Washer
SOAP DISPENSING
The soap dispenser is intended for both liquid and powder detergents. If you have a problem with mildew, then you may need to clean it occasionally with bleach water.
Aug 07, 2008 | Hotpoint WMA50 Front Load Washer
Moldy smell
Turn it off, unplug it. Remove filter and check if filter and/or filter and pump housing are clogged with something "smelly". When you're at it check the drain pipe for too.
May 08, 2008 | Kenmore Elite 45986 Front Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
77 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
