Fisher-Paykel washer, about 8 years old, leaving specks of something on clothes. If the "specks" are intact I can lift them off clothes with toothbrush; however if load spins fast, then I get streaks that are hard to clean/remove from clothes. I really don't think it's lint.
  • Washing Mach... Master
  • 713 Answers
Hi just read your posting.Now you mentioned that the specks are not lint.In my service manual it states that if you use fabric softener then this can build up in the bowl and leave black flakes on the clothes.Try filling machine on a hot wash and pour into bowl 1 or 2 cups of automatic dish washing power and leave the machine to soak overnight.In the morning restart cycle and let it go all the way throe.Please reply on how this worked and for further advice.Looking forward to your reply.
Posted on Oct 08, 2010
  • lhanderso110 Nov 12, 2010
    I followed your recommendation...the situation with the black flakes has improved, but not totally resolved. However, just to clarify on the automatic dish washing powder...do you mean something like "Cascade?" That's what I used, but was afraid to use 2 cups.
Why does it leak, even when machine is not running?
Small leak/drip with Fisher & Paykel GWL11 Washer (with ...
ths.gardenweb.com > Home Forums > Laundry Room
May 6, 2008 - Got a small drip/leak with my GWL11 washer..... The washer is ...Small leak/drip with Fisher & Paykel GWL11 Washer (with pictures) ..... New project for a new year: Light a fire under plans for an outdoor oven and claim the best pizza in town ... Speed Queen Front Load AFN50 Washer Review - Long Post.
Fisher and Paykel GWL11 Top Loading Washer
Mar 5, 2008 - My GWL11 Top loading washer has had nothing but problems! ... I have a Fisher Paykel GWL11 that I purchased new and have loved until this problem started. ... The machine fills with a small amount of water to saturate the clothes ...... Fault 36 is related to water leaking, but is *not* the kind of leaking from ...
Fisher and Paykel GWL11 Top Load Washer - faqqq
www.faqqq.com/.../fisher-paykel-gwl11-washer-leaking-and-squealing-fish...
Question Product: Fisher and Paykel GWL11 Top Load Washer Question Details:Fisher Paykel ... Small leak/drip with Fisher & Paykel GWL11 Washer (with .
Dec 12, 2015 | Fisher and Paykel GWL11 Top Load Washer
Sewer smell in clothes
The tub is probably pretty dirty. Try cleaning the washer with CLR.
Visit this information:
http://www.ehow.com/info_8053120_clr-clean-washing-machines.html
Mar 19, 2014 | Fisher and Paykel GWL11 Top Load Washer
IWL16 leaves black specs on clothes
there could be something stuck in the machine between the two bowls. lifting the lid, removing the ring, agitator and inner bowl will easily check this. if the machine has become loud on spin, and the leak is actually from the bottom (more likely) then it could need seals and bearings replaced. don't run it too much more while leaking, electricity and water don't mix XD
Nov 10, 2013 | Fisher Paykel EcoSmart GWL15
Top load washer about 8 years old- Problem 1 = during the finial rinse/spin the tub will not fulling drain and leaves clothes very wet...had a service call replaced the pump, however stills does not drain...
most likely its the electronic board, easy to change. if you can use a second hand one out of a known working machine- see how that goes- it will probably cure the noise problem
Sep 24, 2010 | Fisher and Paykel GWL11 Top Load Washer
My fisher paykel washer stopped in the middle of a wash leaving the clothes soaking wet and now the power button does not work
Either the computer board is dead OR the pump was on it's way out & took the board with it.If your lucky the pump is just dead & therefore not providing power up to the board,thats the cheaper way to go first.Or you may be up for both.It was probably pumping out at the time when it stopped.
May 20, 2010 | Fisher and Paykel GWL11 Top Load Washer
Becomes unbalanced very easily recently
There is a small spiral spring between the bowl and the cabinet, which help hold the bowl away from the out of balance switch.....OOB switch is at the back RHS of the machine, the spring is situated diagonally opposite (LHS Front). Lift lid, remoce 2 round plugs and loosen screws. Carefully lift hob and check the spring!.....I hope this helps...good luck...Nomess
May 17, 2010 | Fisher Paykel EcoSmart GWL15
Dirt left in creases after washing clothes. Clothes never look clean
Too many clothes in the load , if it says 5lb then that is the maximum you should fill it with otherwise the clothes do not seperate as they are being agitated
Also
Not enough detergent (Try the old powder types)
Hard Water area (Use a small amount of Washing Soda)
Water level too low , use add water button if fitted
May 21, 2009 | Fisher and Paykel GWL11 Top Load Washer
Blocked filter in Fisher & Paykel washing machine top loader
Fisher & Paykel washers do not have lint filters inside the tubs as they are designed to drain away any debris from the wash during the drain cycle.
Mar 10, 2009 | Fisher and Paykel IWL12 Top Load Washer
Fisher and Paykel Washer Leaking
For those with water on floor after wash, check my post on "eco smart won't drain, smells hot". It could be something clogging drainage area at very bottom of the tub. I couldn't see the sock that was stuck in my FP's drain when I looked from the top between the white outer tub and the wash tub--everything looked fine. Then I removed the black motor/white plastic housing piece--Tip back washer and you should see this black electric motor/white housing on bottom. see my post for how to remove and check for plugged drain. it's really pretty easy.
don't know about outer tub holes, but glad i don't have that problem.
i hate my fisher paykel washer/dryer. i can't wait to sell this house--i will leave them here and get a new front load Duette for my next house!
May 31, 2008 | Fisher Paykel EcoSmart GWL15
Washing Machines Logo
206 people viewed this question
Top Washing Machines Experts
