Question about Traulsen 69.1 cu. ft. / 1957 liter Commercial Freezer G31310
Not pulling down to temperture - Traulsen 69.1 cu. ft. / 1957 liter Commercial Freezer G31310
    Sergeant:
    Novelist:
  • 193 Answers
The most common problem is low refrigerant (freon). If you don't have gauges to check the pressure of your refrigerant, do this: the compressor has one small line running to the coils on the top of the freezer. That small line should be hot enough to burn your finger if you touch it when the compressor is running. Also the big copper tube running into the compressor should be cold to the touch, almost freezing. If not you are probably low on refrigerant. Without gauges and the ability to buy freon, you will need to hire a refrigeration repair service to find the leak in your system, repair it and then gas it up. But there are a couple of other things to check first. Near the compressor is a radiator like set of coils in front of a fan. If the compressor is running that fan should be running too. if not, the unit won't cool. Also the radiator coils may be covered with dust or grease. You must have a good flow of air through these coils to dissapate the heat put out by the compressor.If it is stopped up, brush the dust from the front of the coils. Look inside the freezer as well and make sure the inside coils are not frozen over. Is so unplug the unit and let the frost melt off. If that is happening you may need a new timer on your drfrost system.
Posted on Oct 08, 2010
Temperture not control
you should call the fixer because it should be damaged all section gradually.
Mar 09, 2013 | Freezers
I need an online manual for proline freezer CF6 37P see drection for temperture control
there a alarme light showing on my chest frezzer what dose it mean
Aug 02, 2011 | General Freezers
What temperture should a chest freezer be set at
In the middle, 0-5 = 2 and a half 1-10 = 5, adjustment shuold not be far off that, if it is, the unit has a fault.
Hope that helps. Russ
May 17, 2011 | Kenmore Freezers
The freezer is geting high temperture, it could be set down.
find the adjustment knob, set it to a desired tempreture and allow 24 hours for adjustments
Mar 02, 2011 | Electrolux 21.0 Cu. Ft. Upright Freezer -...
What are the temperture control setting 1 2 3 4 5 6 7 temperature
7 being the coldest then going down from there usuallly you keep it around 5
Aug 18, 2010 | Frigidaire 9 cu. ft. / 255 liter Chest...
My freezer stop freezing , but the temperture lite keep flashing at 8 degree. What's wrong?
You may have an issue with the "temperature control assembly". Contact an appliance service company.
Feb 16, 2010 | Kenmore Freezers
My subzero 650 freezer is at -20 degrees and i cant get the temperature to change. it is too cold
adjust temperture control to a lower setting........temp control may be sticking,replace it
Aug 27, 2009 | Freezers
FREEZER TEMPERTURE
From 0 to 10 degrees. Ice cream should stay very solidly frozen.
Jul 07, 2008 | Freezers
Freezer will Not Go Below 8 degrees and Alarm keeps sounding
Our manual says it can take our freezer up to 48 hours to get back to the correct temperature. I found that to be the case when we loaded it fully for the first time.
Jun 15, 2008 | Frigidaire Freezers
Traulsen 69.1 cu. ft. / 1957 liter Commercial Freezer G31310 Logo
167 people viewed this question
Top Traulsen Freezers Experts
Dennis Boxerman
AJMAL KHAN
John Tripp
John Tripp
Are you a Traulsen Freezer Expert? Answer questions, earn points and help others
