Question about JVC Televison & Video
I bought a 20gb hdd camcorder on eBay. It powers on and I can run through the menu, but I nothing is coming through the lens. On the lcd are nine black squares that would show the scenes if there were any on the hard drive. When I try to record (MPG) is entered above the squares, but nothing is ever recorded. Solutions? I've pushed the reset button and nothing happens. I've removed the battery and put it back on and I get a communicating message, but then I immediately am taken back to the nine screens.
  • 2 more comments
  • ideas May 29, 2008
    GZ-MG21U
    I have already looked over the manual and the troubleshooting information. If it was that simple I wouldn't have had to ask. The lens is not covered and the LCD brightness has nothing to do with the solution since I already explained that what I see on the screen is nine black squares.
    You write "Press / to select [YES], then press 49 to recover the video management file." I have no idea what you are talking about. Where do I find the / and select [YES] to get to 49?
  • ideas May 30, 2008
    Anytime I touch the button on the left side of the LCD all I get is a message stating "No Video Files Stored!" this comes up over the nine squares for a few seconds and then goes away.
  • 2,334 Answers
Download the user guide from this website and go to the troubleshooting section.
If you try to playback, connect the camera to the TV and see if you get any video.
Also check and make sure the lens is not covered and the LCD brightness is adjusted as well.
Posted on May 29, 2008
  • Jaime Hernandez May 29, 2008
    Have you tried this?
    The video management file is broken. Recovery is
    required to record or play back video files. Press / to
    management file. If the desired video file is not displayed
    on the video index screen in spite of the file recovery, the
    file has been moved to the [EXTMOV] folder. Press the
    REC/SNAP
    button on the index screen to display [MPG],
    and then select the desired file.
    Press the "reverse skip" and "forward skip" button found on the left side of the LCD screen.
    President:
  • 1,944 Answers
What is the exact model of the camera?
I have JVC everio 60gb HDD, how do I save videos and pictures to the micro SD card?
Did it come with a browser for uploading from your camcorder? My JVC did and I used that to burn to disc then to my computer. Then I copied/pasted to sd card/usb
Mar 24, 2012 | JVC Everio 25x/20GB Hard Disk Drive...
I see black when trying to record anything whether it be out of the viewfinder or the lcd screen. I have tried to adjust the brightness and everthing else that I can think of. It records my voice but no...
If you still have access to the menu options on your LCD then the
problem is probably your Lens iris. Somtimes fixed with a light tap on the side of your camcorder. Gentle tap please. May require lens replacement.
If you don't have access to the menu options on your LCD then the
problem is probably your LCD. May require LCD replacement
Jan 23, 2011 | Canon ES8600 Camcorder
JVC everio 20gb HDD will only show a blank white screen when turned on. Do I need to reload the firmware, or is this beyond?
Sounds like a bad lcd panel. Does the camera show a picture when connected to the tv? If it has a picture on the tv and not on the camera itself its definitely gonna be in the lcd panel or lcd panel cable area, and yes it can be fixed and worth it. I hope this helps
Sep 05, 2010 | JVC Everio 25x/20GB Hard Disk Drive...
I have the Everio 30BG and have downloaded all the files onto my computer, however there is a message showing 'insufficient space' when I try to record, and yet there are not files. HELP>
Are you saving to the micro SD card or to the HDD? You need to go into your menu options to ensure that you are saving to the HDD automatically. Sometimes I used to save to the SD for pics and the HDD for video (set up in the menu). Maybe you are deleting the HDD files but automatically recording to the full SD card?! Check
Aug 05, 2010 | JVC Everio 25x/20GB Hard Disk Drive...
The hourglass stays on my camera (Everio JVC) and freezes, any help please?
okay i solved this by myself. before you turn your camera on switch video mode to photo mode then go on menu and go on basic settings and scroll down to format hdd do that and then switch to video mode and it should work :D
Sep 15, 2009 | JVC Everio 25x/20GB Hard Disk Drive...
MY SONY DCR-SR190 HDD CAMCORDER LCD SCREEN KEEPS CUTTING OUT, IT
mine started like yours then stopped working at all .It's a flex wire that connecting LCD with camcorder. it's very common. I did by miself, bought it in repair shop. works like new. mine is DCR-SR32 wire is 1-871-457-11 known as 1-871-457-21
good luck.
Meggita
Aug 16, 2009 | Sony Handycam DCR-SR85E HDD Camcorder
JVC GR-X5e camcorder, lens cap message. Does not show a picture.
It shows all menus, numbers and graphics on LCD, but seems like there's no picture coming through the lens. In both modes, video and still. It seems like it can not see anything as if the lens cap was on all the time.
Could this be a problem with sensor.. CCDs? Lens? Something else?
Feb 19, 2009 | JVC GR-X5 Mini DV Digital Camcorder
JVC HDD Camcorder won't record or playback
Depending on what model number it is? My JVC had a snap shot feature to it as well as video. Make sure that this is not an option for your camera. There could be a possibility that you did record but you have it in this camera setting, it could be taking snapshots of what you recorded.
Feb 05, 2009 | JVC Everio GZ-MG360 HDD Camcorder
Regarding on battery .
Along with supplying power many camcorder batteries exchange data with the camcorder. If this data is not read by the camcorder it will power up but give you a power error message.
Quite often the problem is caused by a foreign material on the contacts. Try cleaning the contacts on the battery and the camcorder with alcohol and a Q tip.
Another possibility is you have a defective new battery.
Jan 10, 2008 | JVC Everio 25x/20GB Hard Disk Drive...
Televison & Video Logo
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
