Hi I have a Kleenmaid KFL 850 washing machine, and all of the led lights are on simultaneously. What I need is to know how to reprogram the machine to fix this problem
4 Suggested Answers
  • 3 Answers
SOURCE: need part for electrical mother board
You can now order Kleenmaid service parts at www.edis.com.au. Login to their online shop with the user name "retail"and password as given on the login page. Search for the parts you are looking for.
I successfully purchased and received spare parts for a Kleenmaid dishwasher this way.
Posted on Aug 16, 2009
Daniel S
  • 4323 Answers
SOURCE: I have a kleenmaid KFL
Hi
Error 5 in your Kleenmaid is displayed when there is no communication between electronic timer and Inverter. If the machine is washing and communication between the motor control module and main board fails, the machine will pause for one minute. The machine will try to start three more times. On the fourth attempt it will stop immediately. If the temperature of the water in the tub is higher than 60 degrees the machine will fill cold for 30 seconds then pump out for two minutes and the failure will be displayed. To solve this issue you'll have to check the motor control board and the main board, the part that is bad should be replaced. Hope this helps...please post back for further assistance.
Daniel
Posted on Jan 03, 2011
seddy29732
  • 147 Answers
SOURCE: Kleenmaid kfl 1506 manual required
You can view and download your manual in PDF format at this address.
http://www.kleenmaid-appliances.com.au/use&care/WM/kleenmaid/KFL1506_660448en.pdf
just copy and paste it into your address bar.
Posted on Apr 30, 2011
I have a kleenmaid washing machine its about 30 yrs old and still runs well but it is now leaking oil from under the adjitator how do i fix it.
Sounds like the seal for the transmission is leaking oil through the seal. You will need to remove the tub or turn the machine upside down to remove the transmission and replace the seal. That is if the seal is still made.
Nov 17, 2015 | Washing Machines
Apr 30, 2011 | Washing Machines
What causes "Error 4" to
Hi, googled this problem myself and found this page. Doesn't help much though. Will still have to get someone out to look at it.
http://kleenmaid-appliances.com.au/TSPM/WM/Kleenmaid/KFL1600_Fault_Codes%2040220415.pdf
Good luck, we'll need it now our warranties are useless.
Dec 04, 2010 | Washing Machines
Kleenmaid top loader replace timer
Kleenmaid timers do fail from time to time. Reconditioned timers are a viable remedy and not as expensive as new ones. Depending on where in oz you are, a tech will have to sight the faulty timer to ensure the correct replacement unit. You can't rely on model number alone........Nomess
Apr 07, 2010 | Washing Machines
Material chord lodged around agitator of kleenmaid KAW393 washer
sorry to saybut you would probley need to stripp down most of the unit...to remove chord.
Dec 30, 2009 | Maytag Neptune MAH5500B Front Load Washer
My kleenmaid brandt 5kg washing machine has had a new motor and now has a bumpy sound or knocking sound when washing what could be the trouble? regards Dyan
hi dyan, are you based in australia? whome did you get to fix your machine? have you solved the issue now?
my mum has the same machine (which she loves) and hers has just stopped working and she was interested to know more about your post and issues you have experienced.
cheers
kelly
Dec 08, 2009 | Brandt WFH1176 Front Load Washer
I have a KLEENMAID Model LWK24 washing machine and I need to replace AGITATOR. How can I remove AGITATOR
I wish someone would answer your question because i would also like to know how to get the agitator off.
Oct 20, 2009 | Washing Machines
Need part for electrical mother board
Apr 29, 2009 | Washing Machines
Washing Machines Logo
102 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
