I need txt files transfered from diskette to CD
Does bestbuy provide service to copy 3 files from 3.5 inch diskette to cd?
    Genius:
  • 3,587 Answers
Not that I'm aware of you'll need to find a service providor nearby that's in that business..
Posted on May 29, 2008
I want to transfer Data from Diskette to my computer
What sort of diskette ?
cd , floppy, dvd ?
First make a folder in your Kingston Driveclick start all programs accessories My Documents you will see your drive open then right click select new folder and name it which ever appropriate for an easy location find.
Example on how to copy data and download and save it to C: drive
Click start click on computer to open you should see your drives C: and your other drives cd dvd and your usb drive E: or F:
from there you select the files right click on the file/s right click copy navigate back to the drive right click select paste or hold the mouse cursor the file/s drag them drop them in to your C: drive usually My Documents where you have a New Folder Named.
If you need more help with this post a reply.
Jan 13, 2014 | Computers & Internet
Tip
How to Flash a System Bios using a diskette or a CD
Not all PC models have the option of flashing the bios under the windows Graphical User Interface (GUI) environment. There are some that their manufacturers only give diskette option which will involve using the DOS (Disk Operating System) environment. Recently, the CD drive is also given as an alternative since most PCs now do not have diskette drives. Well in both cases, it will involve creating a bootable diskette or CD. Here's how to go about it:
First, you would have to visit the manufacturer's website and carefully check and download the latest driver files for your system model. Also, you would have to save the instructions for reference when necessary. If you are downloading for a diskette, you would have to download the driver files for diskette (they are smaller than that of the CD). Now, the next thing is to create a bootable diskette so you can copy the downloaded files to the diskette. The easiest way of creating an MS-DOS bootable diskette is by visiting www.bootdisk.com/bootdisk.htm, download an image (you can select 'Windows ME, Custom, No Ramdrive'), and follow the instructions to create your own bootable diskette. If the bios files you downloaded are zipped, you would have to unzip first so you can have access to the actual files and copy them to the bootable diskette. If you are downloading for CD, then you would have to select the one for CD if available. Normally, with the CD, an application is added to automatically burn the bootable CD. You would have to be sure your CD drive is a burner or writer. Take note of your drive letter (whether E:, F:, A: etc). Now you are ready to lunch.
If you are using a laptop, be sure to have your battery and adapter connected and if it is a desktop, then be sure to have a backup power like a UPS. Restart your PC and be sure to set your PC to boot from Floppy or CD depending on which one you are using. Now the PC will boot into a DOS environment. If the main application does not lunch automatically, you would have to lunch it yourself. In this case, you will see a drive letter and a blinking cursor. If the letter showing is not that of your drive, then you would have to enter your drive. This is an example of what to type if say we want to enter drive 'E';
c:\>e: (then hit the enter key)
e:\>
In this case, we were in drive C: and we moved from C: to E: by typing 'e:'. From the instructions, you will know the main file to lunch. This is an example of lunching a file with the name 'bios.exe' in drive 'A';
a:\>bios.exe (then hit the enter key)
In this case, we were using drive 'A'(normally the case with diskette). If it were to be drive 'E', it would have been;
e:\>bios.exe (then hit the enter key)
When this is done, you follow the instructions step by step to successfully complete the procedure. When done, you can check your bios settings if necessary.
Hope this was helpful and all the best.
on Feb 19, 2010 | Computers & Internet
Unable to boot and hard disk prob
Dear Amit Sinha
First verify that no floppy diskette or CD is in the computer, unless you are attempting to boot from a diskette.
If not then it seems that your windows boot file got corrupted. all you have to do is try using your notebooks recovery CD if you dont have a recovery CD then you have to use the windows installer CD
1 Insert the Windows XP bootable CD into the computer.
2 When prompted to press any key to boot from the CD, press any key.
3 Once in the Windows XP setup menu press the "R" key to repair Windows.
4 Log into your Windows installation by pressing the "1" key and pressing enter.
5 You will then be prompted for your administrator password, enter that password.
6 Copy the below two files to the root directory of the primary hard disk. In the below example we are copying these files from the CD-ROM drive letter, which in this case is "e." This letter may be different on your computer.
copy e:\i386\ntldr c:\
copy e:\i386\ntdetect.com c:\
7 Once both of these files have been successfully copied, remove the CD from the computer and reboot.
Else you have to format your computer and reinstall windows again
Thanks
Gagan Gupta
Is that helpful
Mar 17, 2011 | Excel MERIDIAN DATASHARE X2 CD/DVD SERVER...
My m250 netbook won't boot up syas missing boot file
Dear Friend
Many times this error is caused when the computer is attempting to boot from a non-bootable floppy disk or CD-ROM. First verify that no floppy diskette or CD is in the computer, unless you are attempting to boot from a diskette.
Thanks
Gagan Gupta
Is that helpful
Mar 17, 2011 | E-Machines M2350 Notebook
Samsung corby txt has a data cable??????
to transfer pc suite is needed u got an cd with pack and install it on computer and u r ready
Jun 01, 2010 | Samsung SGH-E251 Mobile Phone - Black
How to find windows xp product key on windows xp cd
1) Insert Windows XP cd into a working computer.
2) Exit the Autorun introduction.
3) Open "My Computer"
4) Right Click on the Windows XP cd-rom drive and select explore.
5) Open the USWXP32P_ZX folder.
6) Open the sysprep folder.
7) Open unattend.txt
Your CD's product key is contained within the unattend.txt file.
Note: On some system disks, USWXP32P_ZX is a hidden folder. If you cannot locate the folder, you may also search for unattend.txt and mark "Search Hidden Files".
Aug 10, 2009 | Microsoft Windows XP Professional SP2 Full...
Output A:\GHOSTERR.TXT?
Try cleaning the cd, if no luck; use a friends pc and burn a new copy of the restore cd.
Jul 23, 2009 | E-Machines eMachines Desktop PC
Hello,pls I am having problem with my laptop IBM R30. Whenever I turn it on,It displays NTLDR file missing.MY mail is abincojay@yahoo.com
Windows 2000 users If your computer is using Microsoft Windows 2000 and you are encountering the NTLDR error. Create the below boot.ini file on the floppy diskette drive. [boot loader] timeout=30 default=multi(0)disk(0)rdisk(0)partition(1)\WINNT [operating systems] multi(0)disk(0)rdisk(0)partition(1)\WINNT="Microsoft Windows 2000 Professional" /fastdetect Copy the NTLDR and NTDETECT.COM files from another computer using the same operating system. Both of these files are located in the root directory of the primary hard disk drive. For example, C:\NTLDR and C:\NTDETECT.COM should be the locations of these files on many computers. Please keep in mind that these files are hidden system files, if you need additional help with viewing hidden files in Windows please see document CH000516. Once these files have been copied to a floppy diskette reboot the computer and copy the NTLDR and NTDETECT.COM files to the root directory of the primary hard disk drive. Below is an example of what commonly should be performed from the A:\> drive. copy ntldr c: copy ntdetect.com c: After the above two files have been copied, remove the floppy diskette and reboot the computer. Windows XP users Insert the Windows XP bootable CD into the computer. When prompted to press any key to boot from the CD, press any key. Once in the Windows XP setup menu press the "R" key to repair Windows. Log into your Windows installation by pressing the "1" key and pressing enter. You will then be prompted for your administrator password, enter that password. Copy the below two files to the root directory of the primary hard disk. In the below example we are copying these files from the CD-ROM drive letter, which in this case is "e." This letter may be different on your computer. copy e:\i386\ntldr c:\ copy e:\i386\ntdetect.com c:\ Once both of these files have been successfully copied, remove the CD from the computer and reboot.
Jun 05, 2009 | IBM Computers & Internet
How to create a bootable xp service pack 2 cd
To create bootable disk follow the steps: 1)Enter floppy disk or cd in your dvd/cd drive. 2)You can create boot disk by using Nero CD Burning software or other software with which you burn your cd or dvd. 3) to create with windows xp go to http://www.microsoft.com/downloads/details.aspx?displaylang=en&FamilyID=FBE5E4FC-695F-43E5-AF05-719F45C382A4 Or carry out the following steps: Using Windows XP, place a blank floppy in drive A and format the disk. Navigate to the root folder of the system (in most cases this will be C:\) and copy the following files to the floppy disk. Boot.ini NTLDR Ntdetect.com If you can't see the files, click [Tools] and [Folder Options...] in the Menu Bar of Windows Explorer. Click the [View] tab and click the radio button next to [Show Hidden Files and Folders]. Remove the check mark next to [Hide Protected Operating System Files (Recommended)] then click [Apply] and [OK]. The files should now be visible in Windows Explorer. If the files still cannot be copied, right click each file, click [Properties] and remove the checkmark from the Read-Only attributes. Reset whatever attributes were unchecked after the copy procedure is completed. In addition to the files listed above, check the same directory for bootsect.dos and ntbootdd.sys files. If they are present on your system, copy them to the same floppy diskette. The disk is used as any other boot disk, inserting it into the floppy drive (A:\) and initiating a cold boot. Make sure the BIOS is set so that the A:\ drive is first in the boot sequence.
Sep 28, 2007 | Microsoft Windows XP Professional With...
Computers & Internet Logo
23 people viewed this question
David Payne
David Payne
