Question about GPX MW3837 MP3 Player
Recharge battery I just got this mp3 MW38371 GB player. I do not know how to recharge the battery.Could you please help me? Thank you Jodi
Ok,your mp3 player probably came with a cord.plug the big side into your computer and plug the skinny side into the mp3.If you need more help E-mail me at kaylabearpeachbear@yahoo.com.
Posted on Jun 04, 2008
How to install a new battery
Viola, Take it into the source and they may change battery for you just for you purchasing a new battery from them. I will post links to help on how to change rechargeable battery,
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
RCA S2001 Battery S2002 Jet 2 GB Digital Player
RCA S2001 Manuals Support and Troubleshooting MP3 Players
RCA Support
How to replace battery MP3 Player Creative Zen Plus total reset
Mar 03, 2016 | Audiovox Rca S2001 Jet Series Sports Mp3...
How to change the battery ? where is it ? MP3 SMPK2312
Your MP3 Player has a Lithium Polymer battery that powers your device. I don't know if there's a battery compartment you can take off to change your battery, but I'm pretty sure there's a battery compartment either on the side or the back of your device. I can explain to you how to recharge your battery, but I don't know if these directions apply to your device, as this solution is the best possible solution I can give you. To recharge your battery, you need to make sure that the ON/OFF switch is switched to ON. If you have a charger, connect the smaller end to the MP3 Player and the larger end to a wall or surge protector outlet. A light beside the ON/OFF switch should turn on. Another light next to the earphone terminal (port or socket, however you want to call it) should light up too. This indicates the charging status, as this light will go off when charging is finish. I hope this solution helps and my instructions are related to your product's model number.
Mar 21, 2011 | Sylvania SMPK2312 (2 GB) MP3 Player
Unable to charge the MP3 player. I pluug it into the computer but it doesn,t charge.
The ilo 2GB mp3 only uses AAA batteries and will not recharge them. It is not designed to recharge the battery.
Nov 27, 2009 | iLO (2 GB) MP3 Player
Battery recharge problem
Make sure the hold/lock switch is not engaged
Jan 06, 2009 | Philips GOGEAR SA6045 MP3 Player
I garra problem with my mp3 player sansa 250
It sounds like the device battery could be defective..what you need to do is to replace the battery and your device should be up and running again..
I hope that helps
Please rate accordingly
Thank You
Computerrep
Oct 15, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Charging the battery on a sansa mp3 player
recharge it by plugging it in to the USB port. your sansa should have come with a USB cable and the ports are pretty easy to find.
almost all types of earbuds or earphones are compatible with the sansa system, so if you just go out and buy some you should be fine.
May 18, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
SanDisk Sansa c200 2Gb won't turn on
It sounds your device batteries is bad...what I will recommend you to do is to contact sandisk to see if they can RMA the device for you...Sandisk number is 1-866-726-3475..
I hope this helps...
Thank You
Computerrep
Feb 05, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
STMP3500 driver for PhilipsGogear 1 gb
The rechargable battery is dead, and unless you can replace it, you have a useless paperweight. Generally, when the battery is fully discharged it comes up with the missing STM3500 message. When it recharges in the usb port, the message will go away after uninstalling the MP3 player. When it won't recharge, it is gone without a new battery.
Dec 04, 2007 | Philips GoGear SA178 MP3 Player
44 people viewed this question
Top GPX Audio Players & Recorders Experts
Are you a GPX Audio Player and Recorder Expert? Answer questions, earn points and help others
