Question about Kenmore 47722 / 47724 / 47729 Electric Double Oven
Code FO is showing in the display - Kenmore 47722 / 47724 / 47729 Electric Double Oven
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Error code F0 means failed thermistor/transistor in control and to resolve this issue you'll have to replace the Electronic range control (ERC). Please rate the solution if the issue is resolved or post a comment for further assistance.
Thanks Rylee
Posted on Oct 08, 2010
How do I clear an error code FO on my GE oven
it usually means the touch pad or the oven control is defective.
Dec 05, 2015 | GE Ovens
I have a Jenn-Air double oven drop-in prior to 1997 with a FO trouble light showing. What is the usual repair for the failure?
The FO error codes means that a button on the touchpad has shorted out and teh touchpad needs to be replaced. In some cases you will get that error code because the ribbon cable on the touchpad hasa loose connection at the clock. check that the connection is tight.
The error code can be cleared by pushing the clear/off button,if it returns the touchpad will need to be replaced.
GENE
Sep 05, 2011 | Jenn-Air Ovens
My oven has code Fo displayed. It began with a beeping. We turned off the breaker and turned it on again. The beeping continued. After several attempt the beeping has stopped but the code remains...
Hello, I had the same FO error. It turned out that the ribbon cable from the front panel was not making good contact where it mated with the circuit board. Remove ribbon cable and clean contacts on ribbon cable. Replace cable and problem should resolve.
Thanks
Jul 14, 2010 | GE JGRP17 Gas Single Oven
GE Profile oven beeps and displays FO
Your electronic oven control(clock) is bad and must be replaced.
Sep 02, 2009 | GE Ovens
Ariston oven error code F8E0
solved by rotate the temperature knob!!!
maybe would be a problem of the potentiometer or knobe of temperature
Jun 28, 2009 | Ariston Technologies Ovens
The oven controls are not working. then FO shows
If your appliance is newer than 1996 F0 error code is a stuck key pad .
To verify turn off power and access the control panel and remove the ribbon connector that goes from key pad to control board .
Now restore power.
If the F0 code goes away you'll have to replace the key pad .
If it stays it means the control board is bad.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Jun 11, 2009 | GE 30" Built-In Single Electric Convection...
Touch pad does not work and flashed FO
FO- the touch pad is faulty. replace the eoc(electronic oven control)
May 17, 2009 | Kenmore Ovens
JTP56 Double Oven Beeping and Display FO Code
http://www.fixya.com/howto/h155060-dreaded_f7_error
May 18, 2008 | GE Profile JTP56 Electric Double Oven
Fo function error code
The F0 usually means that there is a problem with the keypad.
My solution for the F7 problem may help. You will find my solution at the following link.
http://www.fixya.com/howto/h155050-dreaded_f7_error
I have now shared my fix with over 1600 folks and most report success. I hope that it works for you too. Please let me know at:
hutchipop@yahoo.com
Charlie Popeck, P.E.
Consulting Engineer
Mar 07, 2008 | GE Profile JKP56 Electric Double Oven
Kenmore 47722 / 47724 / 47729 Electric Double Oven Logo
144 people viewed this question
Top Kenmore Ovens Experts
Dan Webster
Dan Webster
Are you a Kenmore Oven Expert? Answer questions, earn points and help others
