Question about Logitech Gaming Headset G330 Headset ( behindtheneck ) Headsets
My computer is not recognizing my microphone. I reinstalled the sound card. I enabled the mic in the control panel. What should I do to make it work? Help please.
2 Suggested Answers
SOURCE: no sound,no working mic...not even showing on my voice tab in control panel
No sound,no working mic...not even showing on my...
Posted on Dec 08, 2008
Hello there, i've recently bought a terratec aureon 5.1 pci sound card and the sound work fine but my mic doesn't. its not muted or anything and i enable the right mic aswell but it still doesnt...
depending on which operating system you are using this will vary
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it or select audio from the microphone drop down list make sure you have the right one selected and in the volume box make sure the microphone box has a tick in it or select the voice tab and make sure that you have the right media selected also select volume make sure the box for microphone has a tick in it or
click start control panel on the left select hardware and sound then select manage audio devices then recording you should see a microphone right click select enable windows 7
click start control panel on the left select hardware and sound then select manage audio devices then recording you should see a microphone right click select configure speech recognition then you will see earphones with a speaker among a list set up a microphone headset with microphone then next and next again you should see your earphones with microphone being configured
hope this help you
Aug 18, 2011 | TerraTec Electronic Aureon 5.1 PCI Sound...
Hi, Have Logitech USB Handheld Mic for PC/MAC. m/n E-UR20 MAC recognized it but there isn't any sound. Thank you!
Probably need to enable it in control panel
Using a microphone with computer
To use any microphone with your computer you will need to enable it in control panel. The following instructions are for Windows XP but are broadly similar for Vista and Win7
Click START, CONTROL PANEL, SOUNDS & AUDIO DEVICES
Click VOICE
In Sounds & Audio Devices Properties window locate SOUND PLAYBACK box. Click the VOLUME button. Make sure that there is not a check-mark in the MUTE box against microphone in the list of devices and that the volume slider is at the top of the scale.
Make sure the MUTE ALL box isn't checked before closing the window.
Now click the VOLUME button in the SOUND RECORDING BOX. Here SELECT microphone as an input source for recording (as opposed to un-checking mute in the playback controls).
NOTE if your microphone is not listed in the 2 sets of volume controls click OPTIONS, PROPERTIES on the tool-bar and place a check against microphone in the list entitled 'show the following volume controls' and then click OK. Same applies for Internal mic.
That should be it.
To adjust audio volume generally.
Under VOLUME tab adjust Device Volume as necessary. Also (under Loudpeaker Settings) click Speaker Volume and adjust slider to suit.
You might put a check mark in the box to show the volume control on the Task Bar so you can go straight to it to make adjustments in the future.
Feb 20, 2011 | Logitech (980240-0403) Microphone
ATR3350 Microphone: Battery in. Plugged into laptop. Recorded video. ATR3350 Mic is ignored. Audio is still recorded from my Logitech Webcam software. How does this thing work?
You need to tell your computer which microphone / sound source to use.
In he absence of other instructions it is defaulting to the built in microphone.
Normally your sound-card software should detect a new device plugged in and ask you to confirm it. However if it is not doing so you may need to change the audio settings.
How to correct this will vary slightly depending on which operating system you are using.
Click VOICE
Now click the VOLUME button in the SOUND RECORDING BOX. Here you need to SELECT microphone as an input source for recording (as opposed to un-checking mute in the playback controls). If your webcam/ microphone is built in to the laptop there should also be a volume control called 'Internal MIC' - disable it by placing a check-mark in the mute box.
NOTE if microphone (or internal MIC) is not listed in the 2 sets of volume controls click OPTIONS, PROPERTIES on the tool-bar and place a check against microphone in the list entitled 'show the following volume controls' and then click OK.
That should be it but it is possible you may also need to turn off the microphone in the software for your web-cam.
Feb 09, 2011 | Audio Technica ATR3350 Microphone
I plugged in microphone but its showing it was not plugged in and my o.s is vista
Try to uninstall sound driver and reinstall sound driver again.
1. First solution : go to control panel, then system , device manager and select sound audio device , right click and uninstall the driver and restart the computer.
2. Soulution : check in system bios setup is there is any option available for mic enable or disable from there ?
3. update the sound driver.
4. check mic is working in another computer
Dec 29, 2010 | ASUS M2N-E SLi Motherboard
I can't use my hp microphone keeps saying no audio input device
First of all check in the BIOS that the audio device is enabled. Then, in Device Manager, check that the sound device is properly recognized and it's driver is active - if not you will have to reinstall it. Finally , from the Realtek Control Panel check that the mic socket is correctly identified and active - take the mic out, start Realtek Control Panel, plug the mic and the corresponding icon should light up if all is ok. If it lights up but you still don't have a mic or it doesn't light up at all then the mic is dead , replace it.
If it lights up but it blink it means that it's not recognized so another window will popup, select the mic in it and it should work.
Jul 05, 2010 | HP Computers & Internet
Mic is recognized by the computer, but not registering sound. Help?
Try this:
click on start, control panel, hardware and sound.
Click on manage sound devices and click the recording tab.
Make sure you have a tick on the mic you want to use and double click on it.
Make sure it says" Enabled" in the device usage box, then click on levels.
There should be 2 sliders, one is the volume of the mic and the other is microphone boost make sure the Microphone volume is near or at 100
It not too good using microphone boost but you may need to use it a little, if you set it too high you will get the horrible feedback screech.
I hope that helps..
Mike
Jul 30, 2009 | Dynex Voice-Certified PC Desktop...
Cannot get microphone to work while connected to computer.
I found this on the Turtle Beach website: ________________________________________
Let's make absolutely sure that the microphone in your headset is working correctly. If the mic is working, a replacement talkback cable should fix it. If not, then please send in your name, shipping address, the name of the store where you purchased your X1 and the date (month/day/year) of purchase.
OK, here's how to test the X1 using the Microphone input on your PC:
1) Take the pink plug from the X1 and plug it into the pink jack (Microphone input) on your PC's soundcard.
2) Take the green plug from the X1 and plug it into the green jack (Front L/R Out or Line Out) on your PC's soundcard.
3) Take the USB plug from the X1 and insert it into a USB port on the PC (not a USB hub, please).
4) In the soundcard's control software, enable the Microphone for playback. In the Microphone > Advanced settings, enable the Microphone Boost. Make sure the Microphone is not muted (Mute switch is not enabled).
5) Adjust the volume for the Microphone to about half-way up.
6) Adjust the overall playback volume to about half-way up.
7) Put on the headset. Make sure the Mute switch on the X1 amp box is not set to Mute (the LED should be green).
Now speak into the microphone. Do you hear your voice in the headphones? If so, the mic works and your X1 headphones should be OK. If you still cannot get the X1 mic to work over Xbox Live, then you need to take a closer look at Dashboard settings and other connections, or check the integrity of your X1-Xbox Controller Cable.
In order to enable the chat make sure that the Mute button in the Off position. If it is on the ON position the Mic will not work.
Red = Muted Green = UN-Muted
_________________________________________________________________
If you're having trouble adjusting the Mic in Windows:
WINDOWS XP:
For Windows XP, there's a nice video on YouTube that takes you through all the steps of setting up your microphone: http://www.youtube.com/watch?v=Vissxo8furo
WINDOWS VISTA:
Please follow these instructions to configure your microphone within Windows Vista:
1. Left-click on the Start button. The Start Menu will appear.
2. Left-click on Control Panel. The Control Panel will open.
3. Left-click on the Hardware and Sound option. The Hardware and Sound window will open.
4. Left-click on the Sound option. The Sound window will open.
5. Left-click on Recording from the three tabs at the top of the Sound window. While in the Recording tab of the Sound window, you will see all options available for recording - Microphone should be one of them. (If you don’t see an option for Microphone, ensure your microphone is plugged into your computer using the jacks commonly located on either the front or back of the machine.)
6. Left-click on the Microphone option to highlight it. This will enable the Properties button toward the bottom-right of the window. Left-click on the Properties button.
7. You should see the Properties for your recording (input) devices. One of these should be Microphone.
8. Left-click on the Levels tab (or similar). Adjust the Level (Volume) and Mic Boost controls to at least half-way up. If your Mic Boost control is a simple check box, please make sure it is checked (Enabled). You should hear your microphone in your headset or speakers.
Once the levels are adjusted to your satisfaction, left-click OK and OK to save your settings. You can then close the Control Panel.
Your microphone should now be ready!
Apr 17, 2009 | Voyetra Turtle Beach Ear Force X1 Headset
Microfone no work
Check first audio properties, in control panel.
On windows the mic is disabled by default, you need to manually enable audio in, either from control panel, or from audio card mixer.
Aug 23, 2008 | Creative Labs Sound Blaster Live! 5.1...
No microphone works
Do you see mic volume at the volume control?
if not then do the following:
Please check the volume control of your system. in the task bar double click the volume control.
if not see in the task bar, then go to control panel and then "sounds and audio device" and then "advanced"
see the master volume.
click "option"
and then " properties"
show the ff volume control
check the "microphone", and the "line volume"
if set to mute, uncheck the box and adjust volume.
Dec 27, 2007 | Dell Dimension 3000 PC Desktop
Acknowledging Microphone
Sounds like the mic is bad. The only way to confirm this is to plug a different mic into the computer and see if that works. If the second mic gives no sound then the computer may have an issue. Hope this helps.
Nov 04, 2006 | Logitech (980240-0403) Microphone
Logitech Gaming Headset G330  Headset ( behindtheneck ) Headsets Logo
99 people viewed this question
Top Logitech Radio Communications Experts
Bharat Das
Bharat Das
Are you a Logitech Radio Communication Expert? Answer questions, earn points and help others
