Question about Acer Aspire™ T180 PC Desktop
Nothing happens when I press power button - Acer Aspire™ T180 PC Desktop
  • Acer Master
  • 5,660 Answers
1) Make sure THE receptacle in the surge protector that the computer is plugged into, has power. Plug an electrical device such as a table lamp for example, into THAT receptacle. I have had a few surge protectors where just THAT receptacle was bad.
2) Receptacle checks out, I suggest you see if the problem is the Power On switch, or the Power Supply.
(The Power On switch is located in the plastic Power On button.
This is an example of a generic ATX power on switch,
http://www.directron.com/atxswitch.html
The procedure involves bypassing the Power On switch.
If the Power Supply comes on you have a bad Power On switch.
If the Power Supply does Not come on, you have a bad Power Supply.
The procedure does not involve the wires of the Power On switch, nor the switch itself.
The procedure involves using a jumper on the ATX main power cable's connector.
Jumping from the Soft Power On wire (Green wire) to ANY Ground wire.
(ANY Black wire is a Ground wire)
The Acer Aspire T180 uses a 24-pin ATX main power cable.
The 24-pin ATX main power cable plugs into the motherboard, in-between the Ram Memory slots, (Slot 4), and the outside edge of the motherboard.
This shows you a typical 24-pin ATX main power cable, it's connector, and the matching female connector on the motherboard,
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain24
This is to show you the motherboard, (Not advertising for the website, nor the seller),
http://cgi.ebay.com/Acer-Aspire-E380-T180-Motherboard-MCP61S-EM61SM-/140420704873?pt=Motherboards&hash=item20b1b9ea69
Scroll to the bottom of the page, and then click on -
Click to view supersized image
When you open your computer case, (Computer unplugged from power), you will see various cables, and hardware components, plugged into the motherboard.
Viewing the photo in the link above, look to the right of the Orange Ram Memory slot.
You will see the blue connector.
The opaque whitish connector to the right of it, and next to the outside edge of the motherboard, is where the 24-pin ATX main power cable plugs into.
Looking back at the link that shows the 24-pin ATX main power cable (Playtool link), look at the photo to the far right.
This is what you will see when you open your computer case.
View the Green wire.
Now view the Black wires.
The jumper wire you will fashion, will go down into the socket hole with the Green wire, and ANY Black wire.
One end of the jumper wire, will go down into the socket hole with the Green wire.
The other end of the jumper wire will go down into a socket hole with ANY Black wire.
The jumper wire will go down into the socket hole, Right next to the wire that is already in the socket hole.
(The Back of the connector is where the wires go in. The Front of the connector plugs into the motherboard.
The jumper wire goes into the Back of the connector, down into the socket holes, and right next to the existing wire that is already in the socket hole)
At the end of the power wires going down into the socket holes, is a metal terminal.
The metal terminal is pretty far down into the socket hole.
(Approximately 1/2 inch)
You need to ensure that the ends of the jumper wire Touch the metal terminals.
The jumper wire is fashioned from a paper clip.
The paper clip is first straightened out, then bent into a U-shape.
Black plastic electrical tape is wrapped around the bend of the U-shape.
This taped area is where you hold onto the jumper wire.
The voltage for the Green (Soft Power On) wire is 5 Volts DC.
Two D cell flashlight batteries produce 3 Volts DC.
Low, low voltage in case you are concerned of being shocked.
However, you may wish to wear a glove on the hand that holds the jumper wire.
There may be a small spark.
Suggest you lay the computer on it's side, computer case open, opening of the computer case up.
(Won't hurt the computer to operate laying on it's side)
Place the ends of the jumper wire into the socket holes.
The contact is no more than 2 seconds.
Power Supply comes on, you have a bad Power On switch.
Power Supply does not come on, you have a bad Power Supply.
The Power Supply is an ATX.
(ATX form factor.
The ATX form factor for a Power Supply is approximately 6 inches Wide, {Width},6 inches Long, {Length},and 3-1/2 inches Tall {Height)
It's a 250 Watt unit.
Post additional questions in a Comment.
Posted on Oct 08, 2010
NOT BOOTING WINDOWS XP IN DELL INSPIRON 1545
1. Press and hold the power button for 10 seconds. If nothing happens go to the next step.
2. Remove the battery of your laptop, then plug the power cord of your laptop directly, then press and hold the power button for 10 seconds. If nothing happens I would suggest to contact your manufacturer so that they can provide further assistance.
Jun 13, 2011 | Computers & Internet
MAV4755A Top Load Washer: When I turn the dial to start wash cycle, nothing ...
if press button selection, make sure that no 2 buttons are pressed
Jan 27, 2018 | Maytag MAV4755A Top Load Washer
Lumix keeps showing message 'remove lens cap and press > button
1. Power off
2. Remove the battery.
3. Put the battery to its place
4. Power on
5. If nothing happens
6. Replace the battery with charged one
7. Power on again
It should be work.
Mar 26, 2010 | Panasonic Lumix DMC-FZ3 Digital Camera
My laptop fell down and now my screen does not display anything
try to press and hold Fn and F8 - this is to toggle screen setting to ext and back to LCD on laptop. if nothing happens turn off computer by pressing power button, unplug the ac adapter, remove the battery. remvoe residual electricity from computer by pressing power button 10 times. just plug again the ac and leave the battery out. Pres and hold the letter D and while holding that press the power button once and release both of them. it will perform the built in self test on the lcd. if nothing happens, turn off computer. press anf hold Fn and while holding it press power button. it will perform diagnosis on computer. if still nothing happens need to repalce motherboard and LCD.
Mar 03, 2010 | Dell Inspiron 6000 Notebook
DC5100 want start up
You need to replace the power supply, a fairly common problem.
Jul 17, 2009 | HP Compaq dc5100 PC Desktop
I am so confused because i can´t turn on my iPhone the screen is still black This is what i tried... 1. Pressing the Power Button (Result: Nothing happens.) 2. Pressing the Power Button and the Home...
we need more info on the phone itself, has it recently been subjected to abuse water or physical? if so maybe the battery itself is damages also try to bull the battery and leave it out for a full minute! if you can get power and just not on the screen then maybe the lcd digitizer is damaged and needs replaced! (please write back with any result or questions)
Jun 12, 2009 | Apple iPhone Smartphone
System turns on however hard drive will not cycle nor will mouse or key board activate
Turn power off and unplug power from computer.
Unplug printers,backup drives and speakers.
Open case and unplug power supply from the board.
plug power cord back in press the power button.
Of course nothing will happen.
unplug power cord again.
plug power supply back into the board.
plug power cord backup and press power switch.
If nothing happens unplug power cord again.
pull out your memory sticks and plug cord back in and press power button.
Of course not much will happen.
But really something is happening to your computer so continue.
Pull power cord and replace memory sticks.
replace power cord and press power switch.
Continue this pulling out pci cards one at a time until you find out what the problem might be.
Try different keyboards and mice too.
Good Luck
Oct 27, 2008 | Intel Computers & Internet
Presario v2000 stuck in hibernation, can't power it up
remove battery plug in power...see what happens ...nothing happens press and hold power button until you hear response(shut down)press power as usual to boot.if it doesnt work first time try a few times more remember to keep power button pressed to shut down.
Oct 19, 2008 | Compaq Presario R3000 Notebook
Acer Aspire™ T180 PC Desktop Logo
346 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
