Question about Danby (DDR600R) Humidifier
How to use the mode button and all other buttons on danby dehumidifier serial #01018040700297 what do the 3 button4 buttons mean on panel is one for taking out water out of air,
I just sent u an email about my danby showing a P2 sorry it was a P1.
P1- means the dehumidifier is in a defrost mode. This occurs when the temperature on the evaporator gets too cold and the unit shuts down to defrost (a defrost cycle).
P2- means the internal bucket is full of water.
Hope this helps!
Jan 25, 2014 | Danby Humidifiers
Looking to download a danby humidifier manuel model DHCC6020-1
nursechris - The following is a downloadable and printable link to the owners manual, you're looking for.
Take good care of your Home Comfort Dehumidifier, as it has been discontinued by Danby.
http://www.beveragefactory.com/images/dhcc6020_efom.pdf
Hope this helped you & thanks for choosing FixYa.
Sep 11, 2011 | Danby PHD DHCC6020 3-in-1 Home Comfort...
I have one of these and I have no clue how it works, sometimes the water reserve catches water.. does that mean its dehumidifying? What are some of the settings I should put it on?
Yes, that means it's working, Basically, the lower the humidity setting, the more moisture it removes from the household air. The higher the setting, the less it will remove and run less, too. Once the water reservoir or "bucket" as most folks call it, is full the unit will shut off automatically and the bucket FULL light will come on. You will need to remove the bucket from the front of the unit and empty it (I prefer emptying it in the bath tub or shower). Then carefully replace it the unit, so that it triggers the safety switch and the FULL light goes out and the unit will restart automatically, if necessary.
You didn't list the model number of your Danby Dehumidifier. But all Danby units work pretty much the same. To help you further I have included a link to the Owners Manual for the Danby DDR25E (this also covers 2 other models) that you can download and print for future reference. Read it thoroughly and become familiar with it's operation and the required Routine Maintenance.
http://www.danby.ca/cms/uploads/products/en_manual
/DDR25E%2C_DDR30E%2C_DDR45E_EFOM.pdf
Hope this helped you. Please let me know. Thanks.
May 25, 2011 | Danby (DDR600R) Humidifier
Need a manual for Danby PHD DHCC6020...how do I get the dehumidifier to work??
Are you sure you have a Danby Humidifier and not a Dehumidifier? As Danby doesn't make humidifiers. At least, not in the US and Canada.
Please advise. Thanks
Apr 28, 2011 | Danby PHD DHCC6020 3-in-1 Home Comfort...
I got E4 error message, and my tank is empty. The humidity value blink too... What can be the problem?
There is some type of electrical component that needs to be replaced called a relay switch. I had the exact problem and it was only a little over a year old. I am not impressed with the appliance for the price i paid for it. I went and bought the cheapest dehumidifier I could find and it works great. You can bypass this problem on your home comfort system by attaching the hose that came with it to the back and the machine will work the water will drain out of it. I
Apr 07, 2010 | Danby PHD DHCC6020 3-in-1 Home Comfort...
Heating does not work in Danby 3-IN-1 Home Comfort Unit
Called Danby, and the Unit is under warranty. They gave me the name of someone local who will fix the unit under warranty. The only problem is contacting the person. Voice mail is full.
Thank you
Feb 02, 2009 | Danby PHD DHCC6020 3-in-1 Home Comfort...
Replacement HEPA filter for Danby DHCC6020?
We just ordered from Danby... call 1-800-26-danby... it's part number 6020.02
Nov 23, 2008 | Danby PHD DHCC6020 3-in-1 Home Comfort...
Changed filter and need to know how to reset icon
Press the 'Timer' and 'increase button' simultaneously (3 seconds) to resume normal operation.
Danby (DDR600R) Humidifier Logo
27 people viewed this question
Top Danby Humidifiers Experts
Mack Baxter
Dennis
Are you a Danby Humidifier Expert? Answer questions, earn points and help others
