Originally installed in 1978 as a heat pump. Threw away the outside unit. Want to use the electric inside furnace/air handler as a shop heating source. I don't know how to wire in the thermostat which is 7801 thermostat. There are 5 wires which are loose.
    Scholar:
  • 80 Answers
Red is 24v from transformer to terminal R
Green is to Terminal G for the air handler fan motor
Yellow is to Terminal Y for calling cooling to the compressor and fan outdoor unit
White is to Terminal W for calling the heat trips which are usually sequenced to keep them from all coming on at once and over drawing Amps and kick off breakers.
Orange was for outdoor reversing valve for a heatpump system
Blue or Black is usually used for common or negative continuity in the circuit such as Red wire and Blue/Black wire to power a thermostat features on digital T-stats. If not digital T-stat then no common is needed to hook-up at T-stat
Posted on Oct 08, 2010
Heat pump problems
Some heat pumps have high and low pressure swiches installed to keep compressor from running when unsafe conditions occur that can damage the compressor. If the outside fan is not turing on, the unit is cycling on high pressure, if you see ice forming on the big refrigerant line coming from the air handler, then the compressor is shutting down on low pressure. Low pressure can be cause by lack of air flow through air handler or from a low refrigerant charge.
Feb 13, 2014 | Intertherm Heating & Cooling
Hey, I purchased your Honeywell RTH2510 Thermostat, but I didn't even think to label the wires when I took the old thermostat off. Upon installation of the new Thermostat (2510) the Air Conditioning...
The connections that you really need to reference would be at the air handler itself. That would tell you which wires go outside to the heat pump and which wires go to the air handler. I can however give you some basics that may help.
Heat Pump Wiring
Terminals/Colors/Function
R- Red- 24v power supply. (Usually a jumper between RC/RH)
G- Green- Fan
W- White- Heat (Sometimes W1-W2, first or second stage heat)
Y- Yellow- Cooling (Same applies as above i.e. Y1-Y2)
C- Common (Most people use blue unless it is used for B terminal and sometimes cooling on older 4 wire systems.
B/O- Reversing Valve for heat pump. Either powered heating or powered cooling, depending on system installed.
Aux- Also used for heat.
Note: Considering that the installer had their own way to run all wires, use different wires, connections, etc. This is just a reference to common wiring in the field.
How the most common system is hooked up:
Thermostat:
Red wire goes to R terminal
Yellow wire goes to Y1 or Y2 terminal
Green wire goes to G terminal
White wire usually goes to W1 or W2 terminal
Orange or Black wire goes to B/O terminal
Brown wire usually goes to Aux terminal
Blue wire goes to C terminal, unless its being used as stated above.
This is without using a fossil fuel kit or zone control board.
Where do they go from the thermostat?
Red
goes to the air handler transformer or board and goes outside to heat pump to power low voltage controls.
Yellow wire goes straight outside to Y terminals on heat pump unless going to a board inside first.
Green goes to the air handler fan relay.
Common goes to the air handler and outside to heat pump.
Black or Orange will go outside to heat pump terminals for reversing valve.
White usually goes outside to heat pump,and inside to air handler. Will explain reason further down.
Brown will go to the air handler to the heat relay for the emergency heat.
On a call for heat, with a powered cooling system (more common).
The R, Y, and G terminals energize, sending a signal to start the blower and pull in the contactor outside. Note that the Y terminal is usually cooling, but since this is a powered cooling system, the reversing valve is not energized, causing the system to run in heat mode. If you have powered heating, the reversing valve terminal will energize also. Depending on thermostat, if you set the temp substantially higher than room temp, it may kick on the emergency/aux heat to quickly raise the room temp. On a call for emergency/aux heat, the R, G, and E/Aux terminals are energized, turning on the electric/gas heat instead of the heat pump. This comes in handy since the heat pump can only pull so much heat from outside before its not enough to properly warm the house, usually around 30 degrees outside temp. If you are running the heat pump and the system goes into "defrost", the outside unit will send a signal back to the air handler, through the white wire I mentioned earlier, to tell the emergency/aux heat to come on while it is in defrost mode, providing heat whenever needed.
Again, this is just a reference guide to some basic wiring, but hopefully it will tell you where the problem is or at the least, give you a good start. There are variables in which things can change the wiring like a zoning system or fossil fuel kit. Even then, you should be able to get pretty close. Hope this helps and Happy Holidays!
Dec 07, 2013 | Honeywell Programmable Thermostat Heater
New A/C Unit makes loud noise when it starts up
It shouldn't be too loud. You don't explain where the noise is coming from? The air handler/furnace or the outdoor unit.
Jun 13, 2013 | Heating & Cooling
Furnace switches to auxiliary heat while in cool
It's likely a bad tstat. Turn the power off to your air handler. Remove red , green, yellow and orange wires inside the tstat and wire nut them together. Not sure if your reversing valve energizes in heating or cooling but, turn the power back on. If the unit is heating turn the power off and remove just the orange wire and turn power back on. Let this run and see if it you are ONLY getting cool air ALL the time. If so you have a bad stat. If still getting heat possibly you have a bad control board in the air handler. Good Luck!!
Apr 15, 2017 | Honeywell Heating & Cooling
I JUST BOUGHT THIS UNIT IT HAS THE OUTSIDE UNIT AND THE INSIDE UNIT AND I WAS TOLD THAT THE HEAT PACKS IN THE INSIDE HANDLER IS FOR EMERGENCY HEAT ONLY...IS THIS TRUE?
Yes, if you are talking about a heat pump. It you have an electric furnace inside, the electric elements are for emergency heat. Otherwise, unless you switch it manually at the thermostat, the heatpump (outdoor unit) will run all year around. If you want to use your inside heater (electric heater) just switch your thermostat to "emergency heat" and it will turn on the electrical elements instead of the outdoor unit. This way will make your elec. bill higher tho. The heat pump is much more efficient. Hope this helps you , have good day
Jul 21, 2011 | Goodman Heating & Cooling
Had a Goodman heating unit installed in Oct. 2009. Recently tried to turn ac on .but no action. Installer returned and hooked up some wiring which got fan working but no cold air. The outside compressor...
It sounds like the outside condenser wires are still not hooked up correctly or there is a problem with the 24v electrical inside the unit. Describing what you have, I'm just banking on the connections. Now, if you have a heat pump system, there will be more wires and a little more difficult, but a normal split system will have two wires going from the furnace to the condenser. These two wires should be hooked to the Y(Yellow) terminal and the C(COM) terminal on the board inside the furnace. If it is a air handler unit, then it needs to be connected to the Blue and Yellow wires. The two outside condenser wires can be hooked up either way, it doesn't matter. I hope this is a simple fix for you and not something more. Good luck and I hope this helps.
Jul 04, 2010 | GE AJCQ08ACB Air Conditioner
My air handler comes on ,not the outside unit when my thermostat is in the off position even if i turn the thermostat down to 50 and have it turned off the air handler comes on for about 5 to 10 minutes...
If you have a standard thermostat the fan switch is for the air handler only. It completely over rides the thermostat for most settings. Now lets see this is what I'd expect:
fan switch on Indoor fan runs all time
Fan switch auto Indoor fan only runs when thermostat is set to cool or heat and the thermostat is turned up above room temp for heat or below room temp for cooling. In both of these modes the furnace blower comes on and stays on til the room temperature is satisfied. The outdoor unit only comes on for AC the out door unit will not come on for heat or the "on" setting on the thermostat. See exception 1 & 2 below...
Exception 1- (in a heat pump the out door unit runs in both heat and cool mode unless it has emergency heat turned on then it will not come on outside in the heat mode, and depending on the type of heat pump and furnace or air handler it is). A heat pump thermostat usually has "backup heat" and an "emergency heat" setting switch on the thermostat.
Exception 2 - On some thermostats they are made to cycle on the heat if the temperature reaches a preset temp (around 50'f usually but definitely by 40'f). This mode prevents freezing when if instance the homeowner is away or while the home is under construction. In this mode the fan inside can run but the heat usually comes on with it.
Exception3 - On some electric furnaces the heating strips may be individually controlled and thus not all come on at one time. This may give the feel of no heat especially if the room is cold.
Now there may be other exceptions but Ive tried to give you a heads up on some of the most common ones.
If you need more help please post more specifics about your unit/system as to for sure what switches are set to what setting and what is happening with each. My first though was that maybe your system is OK and you needed to know if the thermostat was working properly.
If this helpd you understand your problem would you please give me as hifgh a mark as you can. Thnaks for using fixya and good luck.
Mar 28, 2009 | Carrier Heating & Cooling
3 amp fuse blows on a carrier 58mcb furnace board
Hi!!! Does your ac unit work fine?If not check your low voltage problem..You have a low voltage problem check the wire going out to your condensor make sure that they are not touching..Good luck..Check low voltage wires..short in progress..
Jan 04, 2009 | Carrier 52CQ-312-4 Comfort Series Heat...
Heat Pump Stops Working only in the Early Morning
When the unit does what you say does the fan motor outside stop also , if it does that means it is in defrost mode and should kick back over to normal after the system heats up the coil enough
Nov 24, 2008 | Weather King 12AJA4801AH Air Conditioner
Wiring connection for a Ruud air handler & seeking its wiring diagram.
we are trying to install a goodman heat pump with a rheem air handler, the orange wire is hook up and the unit is still staying in the heat mood. does anyone have a wiring diagram for the air handler, their is some white wires in the air handler one with a purple strip and one with a black strip we need help
Jan 05, 2008 | Heating & Cooling
Heating & Cooling Logo
50 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
