Virus cannot be deleted and hidden files that i cannot see
  • Computers & ... Master
  • 27,725 Answers
Virus try another antivirus program to show hiden files control panel folder options select view then scroll to hidden files and folders tick show hidden files
hope this helps
Posted on Oct 08, 2010
Delete autorun inf virus 4gb
If you have a autorun.inf virus on your memory card/USB stick the anti virus software on your PC may not allow access in order to stop it from spreading.
First you need to disable autorun feature on Windows operating system :
Follow steps in link :
http://www.redmondpie.com/how-to-disable-autorun-autoplay-in-windows-7-and-windows-8/
After disabling the feature you will have access to your memory card/USB stick. The next step is to delete autorun.inf virus file hidden on your memory card/USB stick. But first you need to make the hidden virus file visible.
Follow steps in link to show hidden system files :
http://www.bleepingcomputer.com/tutorials/show-hidden-files-in-windows-7/
Now navigate to your memory card/USB stick you should see the autorun.inf file - DELETE IT.
(If it doesnt allow you to delete it - restart the PC in safe mode by pressing F8 on start up and choosing safe mode and try again)
Back up your files on the memory stick/USB stick to your PC and to make sure the virus is gone from the memory stick/USB format it using your PC.
Dont to forget re-hide your system files to prevent accidental deletion.
Oct 15, 2013 | SanDisk 1GB microSD Memory Card
Tip
Remove shortcuts from pendrive,
If your Pen Drive is infected with any of the following viruses:
  • Autorun.inf
  • new folder.exe
  • Iexplorer.vbs
  • Bha.vbs
  • nfo.exe
  • New_Folder.exe
  • ravmon.exe
  • RVHost.exe or any other files with extension.
Actually this viruses are hidden and can't be seen even after
you enable show hidden folders.
Following simple dos command will change the attributes of
these files ,there after you can remove it by pressing delete
key.
Follow these steps:
Step1.:Type cmd in Run
Step2.: Switch to the drive on which pen drive is connected
(like C:\> h: enter)
Step3.: type exactly as attrib -s -h *.* /s /d and hit enter
(don't forget spaces).
Now you can see hidden virus files and you can delete them.
on Apr 03, 2015 | SanDisk Cruzer Fit 16GB Pendrive
Tip
How to check whether a virus has effected a PC
Most common type of virus disable the windows capability to show hidden files. To check whether the computer does not have virus , goto My Computer > Tools (Tab) > Folder Options > View >
Select "Show Hidden Files and Folders"
Click apply and ok
Again repeat the same procedure and check whether the selected "Show hidden files and folders" is still active or its been return to the "Don't show hidden files and folders".
If its still active then it means virus has not effected the system of at least you could delete the hidden virus files.
If it automatically return to the "Don't show...", virus has effected you system. Then go for a good anti-virus software.
on Dec 07, 2009 | Computers & Internet
I'm unable to find some important data stored in my Sandisk micro cruzer. I'm not sure if I accidently deleted it or if it is corrupted. Please suggest if there is a way to recover the files.
If the pen drive is working, the data is there and can be recovered. I think it could be due to virus activity. Some virus make the contents of the drive hidden, thats why user can't see the files and the space available for use is less than the capacity.
It is suggested that go to FOLDER OPTIONS - and select SHOW HIDDEN FILES. It may show the hidden files. Otherwise, you can use any data recovery program to recover the data. Please not that you should not sav/write any data to avoid overwriting the existing data.
Hope this helps!
CreativeTECH
Feb 14, 2011 | SanDisk Cruzer Micro 2GB USB 2.0 Flash...
I lost some of my files from my pen drive. those files are infected by viruses, so i repaired them using anti virus. In dos prompt the folders are showing but while opening the pen drive the folders are...
your all pendrive folders hidden by viruses, so search your pendrive data
file name *.*
and
under advance option tick mark hidden and system files.
show all file.
Apr 23, 2010 | SanDisk Cruzer Micro 4GB USB 2.0 Flash...
How to solve rahul's virus protection.vbe
First
Open task manager and kill process wscript.exe.
Then
Delete VirusRemoval.vbs and Autorun.inf files from all usb drives if u have the virus in them.
Then
Go to c:\Windows\System32 and delete the file VirusRemoval.vbs. It is super hidden so first go to Folder Options and check show hidden and check boxes. Also required for the above files.
Then
go to start>run and type regedit and enter
Go to HKLM\Software\Microsoft\Windows NT\CurrentVersion\Winlogon
On the right side look for Shell which should have value of just explorer.exe.
delete anything at right side of explorer.exe if there is anything.
Under same key Winlogon also look for Userinit which should have value of
c:\WINDOWS\system32\userinit.exe,
Delete all the **** after the comma.
Then
Go to HKCU\Software\Microsoft\Internet Explorer\Main
On the right side locate Window Title and delete its value i.e. Sujin.com.np
Feb 21, 2010 | Computers & Internet
Why would all my pictures disappear if i never deleted them.?
if you r sure that u havnt deleted then check if they are hidden or not, a virus can also affect the pics so beware of the virus!!!!! to check the hidden files click folder option then ckeckmark show hidden files and folder then apply and check ur pics.
Oct 16, 2009 | SanDisk 2GB microSD Memory Card
Missing dcim.exe file
Hi! I had same problem and fix it no time. Well this is trick! virus hide dcim folder and make only visible dcim.exe. 1. so anti-virus will delete that virus "dcim.exe" (or can you) 2. go to start/run and type cmd 3. there you type "attrib -s -h e:dcim" (assuming that your cam is assigned e:) Now go to My Computer and DCIM shoud be there!!
Sep 16, 2009 | Sony Cyber-Shot DSC-T1 Digital Camera
Autorun.inf virus
no antivirus needed
goto control panel and choose a box that says shown hidden files and folders and delete autorun.ini in the folder that has the virus
Mar 03, 2009 | Microsoft Windows XP Home Edition
Computers & Internet Logo
David Payne
David Payne
