Question about Frigidaire Affinity ATF7000E Front Load Washer
The plastic latch is broken. How easy is it to get a replacement?
  • 10,865 Answers
Hi. This is a common item. Go to any appliance store and they can get one for you. OR go to searspartsdirect.com and order what u need. J
Posted on Oct 08, 2010
My Bosch Dishwasher door sticks shut at the end of the cycle. I can open and close it with ease during the cycle, but once it finishes I have to pull really hard to open it.
see all this steps and fix it. God bless you
Door or Lid Latch Assembly
If the door won't latch, the latch assembly might be defective. Inspect the latch assembly to see if it is cracked or worn out. The latch assembly is normally replaced all as one part.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Door Hinge
If the door won't latch, one or more of the door hinges might be bent or broken. If the door hinges are not working properly the door won't close squarely and then the door won't latch.
Door Catch
If the door won't latch, the door catch might be out of alignment or broken. If it appears to be OK, reposition it as needed. If appears broken it should be replaced.
Door Lock
If the door won't latch, the door lock assembly might be defective. These are normally made of plastic and cannot be repaired. If the door won't latch and the door lock is broken, replace it.
Door Latch
If the door won't latch, the door latch assembly might be defective. These are normally made of plastic and cannot be repaired. If the door won't latch and the door latch is broken, replace it.
Door Strike
If the door won't latch, the door strike might be defective. These are normally made of plastic or metal and cannot be repaired. If the door won't latch and the door strike is broken, replace it.
Apr 05, 2013 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
Door wont shut
Door Hinge
Door Catch
Door Lock
Door Latch
Door Strike
Apr 05, 2013 | Miele Dishwashers
Hatch latch broken
did you try some WD 40 in the key hole and then working the key back and forth gently? Even tapping the key hole with a tact hammer to giggle the tumblers inside after you lube it up may fix the problem. If this doesn't work then the next step is a new lock. You can buy replacements as long as you have the title to your vehicle and proof you are who you say you are. The Raz
Apr 16, 2010 | 2002 Toyota Sequoia
Changing rear door latch handle
Take the plastic cover off from the inside. Fairly easy, a few bolts and some plastic clips holding it on. You may be able to open it from the outside but you'll have to take the inside cover off to replace the handle anyway. This is a common problem and if you need more detailed instructions just do a search on the net.
Mar 25, 2010 | 2000 Toyota Sienna
The back seat latch on my 2005 Honda CRV not not
check to see if parts are jammed in the path of movement
Sep 12, 2009 | 2005 Honda CR-V
Broken latch
Replacement latch can be found at amazon, click here Amazon com mailbox latch and chose needed one. Wish you best of luck. John
May 03, 2009 | Solar Group Black Aluminum Mailbox Post,...
My hood latch is broken on my 2001 Subaru Outback. How do I manually opent the hood? I think my problem is the same. I have a 1997 Legacy--when I pop the hood, it releases, but I can't located the latch...
If the cable link to the latch is rusty or broken you have to take the front grid down. It's relatively easy. It's held there by plastic fasteners. Then reach for the latch with you hand, or the leftover broken cable. Pull it, it should release the first latch, than you just have to get to the security latch, like you usually do to open the hood.
Feb 07, 2009 | 1997 Subaru Legacy
NEFF H5470NOGB Microwave door latch fault
theres a small plastic hook inside the door which holds a tension spring this will have snapped off stopping the latch from entering the lock its actually quite easy to fix the inner plastic frame can be unclipped with a small flat blade screwdriver exposing the hook mechanism and the spring will be lying in the bottom of the door frame you can reconnect it to the metal inner frame it stretches the spring a little more but it will never snap again ive done this loads of times with no probs otherwise you will have to replace the outer door to reinstate the broken hook.
Oct 27, 2008 | Neff H5470 Microwave Oven
Closing the dryer door
you need a part number 5366021400 latch kit I think take your model and serial number to you local appliance dealer and they will probably have one on the shelf and its so easy to install just pull the old broken part out and replace with new one
Nov 15, 2007 | Frigidaire Affinity ATF7000ES Front Load...
Maytag Dishwasher Latch Sticks
John, I had the same problem and just disassembled by removing the dozen or so screws around the inside of the door, lifting the waterproof panel, and pulling up the latch assembly to see what was broken. In my case there were plastic pieces broken off of the latch handle and where the latch hinges on the back of the control panel-the latter piece is $50 to replace. unfortunately. Good news is the disassembly and replacement will be easy as a DYI. Sorry this is too late to help you, but maybe others will have the same problem. Bruce
Dec 20, 2006 | Maytag 24 in. MDB5600A Jetclean II...
Frigidaire Affinity ATF7000E Front Load Washer Logo
55 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
