Question about Craftsman 10" Bench Grinder
How to stop shaft from turning to remove nut and replace wheel
  • 843 Answers
If you put a wrench on the nut on the other end of the shaft, you have a 50/50 chance that the nut you want loose will come loose. If the wrong one comes loose, you can remove that nut completely (and the wheel) then take the nut with you to the store to buy another one. Then put two nuts back on and tighten them together as a jamb nut. Then try again. If the wrong nut still turns, you have to tighten the pair of nuts together tighter. good luck
Posted on Oct 08, 2010
  • Al Kupchella
    Al Kupchella Oct 08, 2010
    I forgot to mention that after you have the pair of nuts tightened together, put your wrench on the inside nut (the one closer to the motor) to hold the shaft still while you put another wrench on the nut you are trying to remove.
  • 52 Answers
Sometimes the friction of a wooden wedge or shim is all you need to get the nut you want off. Tap the wrench on the nut you are removing with sharp soft blows using a woden mallet to disengage the nut without the wheel slipping.
Posted on Oct 01, 2016
    Welcome Back:
    Visited the website for 2 consecutive days.
    Problem Solver:
  • 12 Answers
There is a left handed thread and a right handed thread on the arbors.
Double nut is the preferred method.
OR
Removal
Right Hand Side (RH)
Wrap a piece of rubber or leather around the threads on the LH side of the arbor & hold with pliers, while turning the RH nut CCW.
Left Hand Side (LH)
Wrap a piece of rubber or leather around the threads on the RH side of the arbor & hold with pliers, while turning the LH nut CW.
Installation
Note: Hand tighten the nut, then 1/4 turn.
Wrap a piece of rubber or leather around the threads on the LH side of the arbor & hold with pliers, while turning the RH nut CW.
Left Hand Side (LH)
Wrap a piece of rubber or leather around the threads on the RH side of the arbor & hold with pliers, while turning the LH nut CWW.
For grinding stones:
  • ring test the stone
  • discard the stone if it has been dropped
  • be sure the paper washers are installed on the wheel
GRINDER SAFETY 101 (graphic injury video so be warned)
http://www.garagejournal.com/forum/showthread.php?t=263083
Posted on Feb 25, 2016
I have 04 vue. Fwd 3.5. How do i change out right side cv axle? I can't free end that goes into carriage bearing?
remove lower ball joint and remove axle nut in the center of spindle. then move the spindle out of the way separating the axle from the spindle.
Mar 28, 2015 | 2004 Saturn VUE
1998 ford explorer 2 wheel drive rear wheel bearing replacement
what about it?
conventional axle or limited slip? Get axle code off door sticker.
SECTION 205-02: Rear Drive Axle/Differential - Ford 8.8-Inch Ring Gear 1998 Explorer/Mountaineer Workshop Manual
IN-VEHICLE REPAIR Rear Wheel Bearing and Axle Shaft Oil Seal -4.0L SOHC and 4.0L EI, Conventional
Special Tool(s) swn~us~en~file=st1514a.gif~gen~ref.gif Axle Seal Replacer
T83T-1175-A swn~us~en~file=st1283a.gif~gen~ref.gif Axle Wheel Bearing Puller
T83T-1225-A swn~us~en~file=st1322a.gif~gen~ref.gif Axle Wheel Bearing Replacer
T83T-1225-B swn~us~en~file=st1326a.gif~gen~ref.gif Driver Handle
T80T-4000-W swn~us~en~file=st1185a.gif~gen~ref.gif Impact Slide Hammer
T50T-100-A
Removal
  1. Remove the axle shaft; refer to Axle Shaft in this section.
Axle Shaft Removal
  1. swn~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not use heat to loosen a seized lug nut. Heat can damage the wheel (1007) and the rear wheel bearings (1225).
    Loosen the lug nuts (1012).
    1. Remove the center cap.
    1. With the weight of the vehicle on the wheels, loosen the lug nuts.
  1. Raise and support the vehicle.
  1. Remove the wheel and tire assembly.
    1. Remove the lug nuts.
  1. Remove the axle housing cover (4033).
    1. Loosen the axle housing cover bolts (4346) and drain the rear axle (4001).
    1. Remove the axle housing cover bolts.
    1. Remove the axle housing cover.
  1. Remove the rear disc brake rotors (2C026); refer to Section 206-04 .
  1. swn~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Once the differential pinion shaft (4211) has been removed, turning the differential case (4204) or an axle shaft (4234) will cause the differential pinion gears (4215) to fall out of the assembly. This could result in chipped or damaged components.
    Remove the differential pinion shaft.
    1. Remove the differential pinion shaft lock bolt.
    1. Remove the differential pinion shaft.
  1. swn~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not damage the rubber O-rings in the U-washer grooves.
    Remove the U-washers (4N237).
    1. Push the axle shafts inboard.
    1. Remove the U-washers.
  1. Reinstall the differential pinion shaft.
    1. Install the differential pinion shaft.
    1. Install the differential pinion shaft lock bolt finger-tight.
  1. swn~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not damage the inner wheel bearing oil seal (1177).
    Remove the two axle shafts.
Installation
  1. Lubricate the lip of the inner wheel bearing oil seal.
    • Use Premium Long-Life Grease XG-1-C or equivalent meeting Ford specification ESA-M1C75-B.
  1. swn~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Once the differential pinion shaft has been removed, turning the differential case or an axle shaft will cause the differential pinion gears to fall out of the assembly. This could result in chipped or damaged components.
  1. swn~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not damage the inner wheel bearing oil seal.
    Install the two axle shafts.
    Install the U-washers.
    1. Position the two U-washers on the button end of the axle shafts.
    1. Pull the axle shafts outward.
    1. Align the hole in the differential pinion shaft with the differential pinion shaft lock bolt hole.
    1. Install the differential pinion shaft lock bolt.
  1. Install the rear disc brake rotors; refer to Section 206-04 .
  1. Install the axle housing cover and fill the rear axle housing (4010) with 2.4 liters (5.5 pints) of specified lubricant; refer to Axle Housing Cover in this section.
  1. swn~us~en~file=ani_caut.gif~gen~ref.gif WARNING: Always remove any corrosion, dirt or foreign material that may be present on the mounting surfaces of the wheel or the surface of the wheel hub or rear disc brake rotor that contacts the wheel. Installing wheels without proper metal-to-metal contact at the wheel mounting surfaces can cause the lug nut to loosen and the wheel to come off while the vehicle is in motion, causing loss of control.
    Clean the wheel hub and mounting surfaces.
  1. Install the tire and wheel assembly.
    1. Position the tire and wheel assembly.
    1. Install the lug nuts and lower the vehicle.
    1. Tighten the lug nuts.
    1. Install the center cap.
  1. swn~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Never remove the axle shaft oil seal by itself. Always remove the rear wheel bearing and the axle shaft oil seal at the same time.
    NOTE: If the axle shaft oil seal is leaking, the axle housing vent may be plugged with debris.
    Use Impact Slide Hammer and Axle Wheel Bearing Puller to remove the rear wheel bearing and the axle shaft oil seal.
Installation
  1. Lubricate the new rear wheel bearing.
    1. Use Thermally Stable Rear Axle Lubricant XY-80W90-QL or equivalent meeting Ford specification WSP-M2C197-A.
  1. Use Axle Wheel Bearing Replacer with Driver Handle to install the rear wheel bearing.
  1. Lubricate the lip of the new axle shaft oil seal.
  1. Use Axle Seal Replacer with Driver Handle to install the axle shaft oil seal.
  1. Install the axle shaft; refer to Axle Shaft in this section.
May 18, 2011 | Ford Explorer Cars & Trucks
A headset wire stuck (wound) in crack of steering column in 1998 Contour. How do we retrieve it? Can the wheel be dismantled?
Yes - the steering wheel can be removed, just be prepared for the wire to be smashed or mangles and unusable. Look on the back side of the steering wheel - you will see some small holes for the retaining screws for the center piece of the steering wheel. If your model has an airbag in the wheel you will need to disconnect the battery to prevent activating the airbag.Remove the panel below the steering wheel to access the harness for the airbag and unplug. Now remove those retaining screws and the center piece of the wheel. Now you will see a large nut on the center shaft of the column.Before you remove the center nut, look at how many threads are exposed above the nut before removing. Lock the steering wheel and remove that nut. Now you will need a steering wheel puller. Find the fasteners that fit your wheel and mount the puller, Turn the puller shaft 3 turns and try to remove wire - if it won't come out then you'll need to completely remove the wheel to extract the wire. Place the wheel back on the column shaft and use that center nut to re - install the steering wheel. You may need to place that nut socket over the shaft around the threaded part and tap lightly to seat the wheel far enough to use the nut to seat the wheel back down. Press steering wheel until it sits where it did in the beginning. Re - install center piece, plug in airbag and replace that lower panel. Your local auto parts store may have a steering wheel puller for rent - if not, they are not expensive to buy ( should be less than $10.00 USD).
Hope this helps!!
Dec 03, 2010 | 1998 Ford Contour
How technical is it to replace a front wheel bearing on a 2005 Pontiac SV6 and can I do it without any specialized tools
you will need a big socket (20 or 21 mm) and 1/2 inch drive to remove axle nut and torque wrench to reinstall. The book DOES call for a special tool to get the hub off the axle, but I have never used one before.
Removal & Installation
  2. Remove the wheel.
  3. Remove the wheel drive shaft nut.
  4. Remove the brake caliper and wire aside.
  5. Remove the brake rotor.
  6. Disconnect the electrical connector from the wheel speed sensor.
  7. Remove the wheel speed sensor connector from the bracket by depressing the locking tabs.
  8. Remove the 3 hub and bearing assembly bolts.
  9. Install Wheel Hub Removal tool J-42129 to the hub and bearing assembly in order to remove the hub and bearing assembly from the wheel drive shaft.
  10. Remove the hub and bearing assembly from the steering knuckle.
To install:
  1. Install the hub and bearing assembly to the steering knuckle.
  2. Install the 3 hub and bearing assembly bolts and tighten to 85 ft. lbs. (115 Nm).
  3. Install the wheel speed sensor connector into the bracket until the locking tabs click into place.
  4. Connect the electrical connector to the wheel speed sensor.
  5. Install the axle nut to the wheel drive shaft and hand tighten.
  6. Install the brake rotor.
  7. Use a screw driver or similar tool to stop the rotation of the brake rotor.
  8. Tighten the wheel drive shaft nut to 159 ft. lbs. (215 Nm).
  9. Install the brake caliper.
  10. Install the tire and wheel.
Sep 24, 2010 | Pontiac Montana SV6 Cars & Trucks
Replace left side front drive axle
  1. loosen center wheel nut (look up utube)
  2. remove wheels
  3. remove rod end
  4. remove strut bolts
  5. remove center wheel bolts
  6. press center shaft off or use a brass punch
  7. drop rotor assembly down
  8. pull shaft out ( check for circlips or bolting plates)
Sep 10, 2010 | 1997 Honda Civic
How to install a new steering gear box on a 1998 Grand Marques?
  1. Disconnect the negative battery cable.
  2. Remove the stone shield.
  3. Tag the pressure and return lines so they may be reassembled in their original positions.
  4. Disconnect the pressure and return lines from the steering gear. Plug the lines and ports in the gear to prevent the entry of dirt.
  5. Remove the clamp bolts retaining the flexible coupling to the steering gear.
  6. Raise and safely support the vehicle.
  7. Remove the nut from the sector shaft.
  8. Remove the pitman arm from the sector shaft with a suitable pitman arm removal tool. Remove the tool from the pitman arm.
  1. Support the steering gear and remove the steering gear retaining bolts.
  2. Work the gear free of the flex coupling and remove the gear.
  3. If the flex coupling did not come off with the gear, lift it off the shaft.
To install:
  1. Turn the steering wheel to the straight-ahead position
During installation, position the steering gear input shaft as shown on 1992-98 vehicles
  1. Center the steering gear input shaft with the indexing flat facing downward on 1989-91 vehicles. On 1992-98 vehicles, center the steering gear input shaft with the centerline of the 2 indexing flats at 4 o'clock.
  2. Slide the steering gear input shaft into the flex coupling and into place on the frame side rail. Install the retaining bolts and tighten to 50-65 ft. lbs. (68-88 Nm).
  3. Make sure the wheels are in the straight-ahead position. Install the pitman arm on the sector shaft and install the lockwasher and nut. Tighten the nut to 233-250 ft. lbs. (316-338 Nm).
  4. Move the flex coupling into place on the steering gear input shaft. Install the retaining bolt and tighten to 20-30 ft. lbs. (27-41 Nm).
  5. Connect the pressure and return lines to the steering gear and tighten the lines. Fill the reservoir and turn the steering wheel from stop-to-stop to distribute the fluid. Check the fluid level and add fluid, if necessary.
  6. Start the engine and turn the steering wheel from left to right.
  7. Check for leaks.
  8. Install the stone shield.
May 28, 2010 | 1998 Mercury Grand Marquis
Corvette sway bar installation
Stabilizer Bar: Service and Repair
Front
Removal Procedure
1. Raise and support the vehicle. Refer to Vehicle Lifting.
2. Remove the tire and wheel assemblies. Refer to Tire and Wheel Removal and Installation.
3. Remove the stabilizer shaft link nuts from the stabilizer shaft.
4. Remove the stabilizer shaft insulator clamps from the front crossmember.
5. Remove the stabilizer shaft from the vehicle.
Installation Procedure
1. Install the stabilizer shaft, insulator clamps and bolts to the crossmember.
2. Install the stabilizer shaft links to the stabilizer shaft.
Notice: Refer to Fastener Notice in Service Precautions.
3. Install the stabilizer shaft link nuts.
- Tighten the stabilizer shaft link nuts to 72 Nm (53 ft. lbs.).
4. Install the stabilizer shaft insulator clamp bolts.
- Tighten the stabilizer shaft insulator clamp bolts to 58 Nm (43 ft. lbs.).
5. Install the tire and wheel assemblies. Refer to Tire and Wheel Removal and Installation.
6. Lower the vehicle.
Rear
Removal Procedure
4. Remove the stabilizer shaft clamps, bolts and nuts retaining the shaft to the crossmember.
1. Install the stabilizer shaft to the vehicle.
2. Install the stabilizer shaft insulator clamps to the stabilizer shaft and the crossmember.
- Tighten the stabilizer shaft insulator clamp bolts to 65 Nm (49 ft. lbs.).
- Tighten the stabilizer shaft insulator clamp nuts to 95 Nm (70 ft. lbs.).
3. Install the stabilizer shaft links to the stabilizer shaft.
4. Install the tire and wheel assemblies. Refer to Tire and Wheel Removal and Installation.
5. Lower the vehicle.
Oct 30, 2009 | 2001 Chevrolet Corvette
Replacing blower wheel
make sure you turn the nut clockwise to loosen it.
(backward threading)
Jan 29, 2008 | LG DLE2532W Electric Dryer
Craftsman 10" Bench Grinder Logo
776 people viewed this question
Top Craftsman Grinders Experts
Jim London
Jim London
Lawrence Oravetz
Vernon Taylor
Are you a Craftsman Grinder Expert? Answer questions, earn points and help others
