Question about Panasonic KX-TD7896 Cordless Phone
I have attached this cordless to KX-TA824 supporting 2 incoming lines. How can I select which line (CO 1 or CO 2) to call from?
  • Panasonic Master
  • 2,460 Answers
If you start with intercom dial tone, press 81 or 82. If you dial 9 you'll get line 2 before line 1 in normal programming, and if you dial a line that's busy with 8x access codes, you'll get a busy, even if the other line is free.
Of course, you could also RTFM and program the system to function with your TA-824 http://public.carl.airpost.net/Pana/TA-824/UG_TA_0823%5B1%5D.pdf
Starting on page 15 or so of the pdf, after you set up the keys, you'd press the > and 1 or 2 to get to lines 1 or 2 :-)
Carl
Posted on Oct 08, 2010
Testimonial: "Just fantastic! Both the solutions were tried and worked!! I can't thank you enough.Have a great week-end."
Line not assigned
make sure that your service provider has installed 3 individual lines into the building
check that the 3 incoming lines are not all together in the plug at the wall
you may need a telephone technician to check it out
Feb 17, 2016 | Panasonic Kx-tda100 Kx-tda100 Digital...
CO 1 cannot call out or receives incoming.
Panasonic KXDT321 Phone
Conference call Call party 1 and speak
Press transfer
Call party 2 (press 9 for outside line if needed)
Party 2 answers
Press transfer then 3 speak to all three people
Repeat if required
Jan 24, 2014 | Panasonic KX-T7731 Corded Phone
Panasonic KX-TA824 Phone Line Problem....When I connect the phone companies incoming line to my phone system everything works fine...When then attach my home phone to the incoming phone line with the...
If I'm understanding right, you are plugging in a regular "residential" phone into a phone system jack. The system phones work differently than home phones and you won't get a dial tone out of the jack unless you use a system phone.
Nov 04, 2013 | Computers & Internet
Panasonic KX-T7730, we have a 824 phone system and cordless handsets (kx-tg1711) we cannot make outgoing calls on these handests but can take incoming calls and can transfer calls. how do we programme
  • Locate the program and auto-store button on your telephone. You will be using these to customize many of the features on your KX-T7730. The program button is used to enter or exit programming.
  • 2
    Program your outgoing line preference, i.e., the line you prefer to seize when you go off hook. Press "Program" "1" "1" "store" for no line. Press "Program" "1" "2" "Store" for an idle outside line. Press "Program" "1" "3" "Outside Line Number" "Store" for an assigned outside line. The outside line number will be a single or double-digit number that is set through your phone system.
  • 3
    Program your incoming line preference, i.e., the line you prefer to answer when you go off hook. Press "Program" "2" "1 "Store" for no line. Press "Program "2" "2" "Store" for ringing line. Press "Program" "3" "Outside Line Number" "Store" for an assigned outside line.
  • 4
    Program your flexible CO buttons. These are the inner row of 12 lighted buttons. Your outside lines need to be programmed to these--you can choose any of these 12 buttons in any order. Press "Program" "CO Button" "0" "Outside Line Number" "Store." The outside line number will be a single or double-digit number that is set through your phone system.
  • 5
    Program any other unused flexible CO buttons for an extension number or any frequently dialed phone number. Press "Program" "CO button" "1" "Extension Number" "Store" or "Program" "CO Button" "2" "9 + Phone Number" "Store". A "9" must be entered at the beginning of a phone number to tell your phone system to seize an outside line before dialing, e.g., "9-1-212-555-1234."
  • 6
    Locate the programmable feature buttons (the row of 12 solid buttons on the right). These buttons are basically one-touch buttons that can be set for extension numbers or phone numbers. Press "Program" "(PF) Button" "Extension Number" "Store" or "Program" "(PF) Button" "9 + Phone Number" "Store." Remember to press "Program" again to exit programming.
  • 7
    Locate your "FWD/DND" button. This button is used for setting "Call Forward" or "Do Not Disturb" on your telephone. To set call forwarding, go "off-hook" either by lifting the receiver or pressing speakerphone. Make sure you go to intercom and not an outside line. To forward all calls, go off-hook, press "FWD/DND" "1" "extension number" (the extension number that you wish to forward all your calls to) "#". After you hear a confirmation tone, place the receiver on-hook. The steps to set call forwarding for busy/no answer are the same as above, except you will press "2" in place of "1". To cancel call forwarding, press "0" in place of "1".
  • 8
    Program "Do Not Disturb," which stops your phone from ringing--any callers will just hear a DND tone. To program, go off-hook, press "Program" "4" "#" on-hook, to set. Press "0" instead of "4" to cancel.
  • 9
    Locate the message button--this works in coordination with your message light at the top right of your telephone. If the light is lit, press "message" to hear a message left to you either by another extension or a voice mail system. The message button can only be programmed as a message or one-touch button. To program as a message, press "Program" "Message" "3" "Store." To program as a one-touch, press "Program" "Message" "1" "Extension Number" or "Program" "Message: "2" "9 + phone number."
  • 10
    Return your KX-T7730 to its default settings by pressing "Program" "#" "*" "Store."
  • Read more: How to Program a Panasonic KX T7730 ' eHow.com http://www.ehow.com/how_7159736_program-panasonic-kx-t7730.html#ixzz1eYPzbevZ
    Nov 23, 2011 | Panasonic KX-T7730 Corded Phone
    I have a panasonic kx ta824 system with caller id. Caller id works fine on lines 2 & 3, but no longer works on line 1. This is a new problem after 3 years of it working properly. I checked the...
    Hard to say. So, go to the cabinet and swap the connections between line 1 and line 2. If the CID still comes in on line 2 and not 1, then it's hardware or programming. If it doesn't come in on 2, then it's a telco issue. Since you checked programming, it would only leave hardware. The 82493 card plugs into a slot on the main board.
    Carl
    Mar 15, 2011 | Panasonic KX-TA824PK Phone
    Hello friends from FIXYA, I have a situation where I cannot get my Panasonic KX-TA824 pbx to answer incoming call at the fist ring using DISA. I have tried everything and I cannot get it to work. DISA...
    And??? What's the problem? My DISA is set for 1s on the first page and it never rings a phone. If you want it to answer the outside line on the first ring, you'll have to turn OFF Caller-ID. Now it will answer right after the first ring, but you lose CID logging.
    On my working system, the DISA 6.1 section is with AA and 1 second, and 6.2 the first two timers are 3 and 5 seconds. In 9.1 you can uncheck CID but I don't recommend it.
    Carl
    Sep 22, 2010 | Panasonic KX-TA824PK Phone
    KX-T7730 - Used to have 3 incoming/outgoing lines. Have cut this down to 2(lines 1 and 3). Outgoing calls are automatically selected by line 3, 2, 1. When calling out the second person can't get an outside...
    If you are using the KX-T7730 phone on a Panasonic KX-Txx 308 or 824 system.
    From the Switchboard / Main telephone ( usually ext 101, 10 or 9 ) with the handset on the cradle/hook :
    1. Press PROGRAM * # followed by the system password ( default is 1234).
    2. Now press 400 and then SP-PHONE. Enter the line number you wish to change. ( In your case 2)
    3. Press AUTO ANS / MUTE to change between Connect and Not Connect.
    4. Press AUTO DIAL / STORE to save your changes.
    5. Press PROGRAM to exit program mode and you are done.
    Mar 17, 2010 | Panasonic KX-T7730 Corded Phone
    I bught a kx-ta824, I just have one CO line and i want to put 4 extensions , but i couldn't. I can just recive 1 call and then the line sounds busy.
    With one CO line you can only make or receive one external call at a time. You can have extensions connected on intercom calls, but once your CO line is in use, anyone calling in will get a busy signal, as will anyone in the office trying to make an outside call. You'll need additional CO lines if you want to have several outside calls going on at once.
    Apr 10, 2009 | Panasonic KX-TA824PK Phone
    KX-TA824 Select idle CO line
    No. C.O. Line group access is always from high to low. However, you can turn off CO 5&6. In programming command 400.
    Carl
    Jan 24, 2009 | Panasonic KX-TA824PK Phone
    Panasonic KX-TD7896 Cordless Phone Logo
    222 people viewed this question
    Top Panasonic Lands Phones Experts
    guyvstewart
    george  peters
    george peters
    Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
