Question about Whirlpool ED2FHEXN Side by Side Refrigerator
Refrig door was accidentally left cracked adjar all night. Freezer is working, refrig seems to have shut down...everything is getting warm. What to do in this case?
    Sergeant:
    Champion:
  • 351 Answers
It has frosted from door being left open may clear it self over time best thing is take apart and defrost
Posted on Oct 08, 2010
Fridge and freezer at 50 degrees with settings on max cold. I can hear compressor cycling and all power is on. Suggestions?
Your Refrig/freezer should be set as follows:
Refrigerators: 36 to 40 degrees. Ideal temp is 37 Fahrenheit. Note: A temp above 42 degrees promotes bacteria.
Freezer: temp should be -5 to 6 degrees Fahrenheit. Ideal temp is 0 degrees.
Then check the door seals around the edges to see if any splits, tears or cracks have messed up the seal. This will cause your compressor to constantly run as it's trying to cool off the warm house is being sucked into the freezer (or Refrig). A sure sign the door seals are damaged is lots of ice in the freezer door area or water pooling in the bottom area of the refrigerator.
Wait about 4 hrs after you readjusted the Refrigerator/Freezer settings so everything settles down. If you still have problems then the coolant may need to be serviced (topped off) or the motor serviced/checked.
Don't procrastinate because a water heater and Refrig/freezer are the 2 largest energy users in your home- they run 24 hrs a day.
Hope this helps...
Nov 23, 2012 | Whirlpool 25.6 cu. ft. Side-by-Side...
Frigidare refrig. It seems like Freezer still working but not refrig. Temp is now 56 in refrig part. Refrig is not even 2 years old. Fan seemed to be working in refrig earlier but now not at all.
check the damper vent door between the two compartments to make sure its open to let the cold air in from the freezer then make sure the evaporator fan is operating to help push air thru this door,sometimes these doors freeze shut or if its a motor driven vent door the motor could be bad too
Jan 01, 2011 | Refrigerators
I have a profile refrigerator PDS20SCPARSS, SN TF047061. If youopen the door alot ( 4 kids) te refrigerator temp goes all the way to 60deg and the freezer goes to -30. If you don't open the door at all the...
If this is struggling to maintain temperature like this, either the system is low on gas (motor running all the time) or the fan has stopped which you should be able to hear. Make sure that the fan is not just jammed.also check the return air vent in the fridge as if this gets stuck with a spillage ie O.J. etc, the fridge cannot get air from the freezer and the freezer runs continually (-30) but the thermostat never cuts out in the fridge. Last idea most likely.
Dec 10, 2009 | GE Profile PSW26P Stainless Steel Side by...
GE GSH25JSTASS doesn't freeze or cool
Ok, first off, replace all thermistors, freezer (2) & refrig (2). Then check that evap fan is working properly. This is a DC volt fan, not ac volt. There have been some issues with these, I would replace if problem continues.
How this box works, main control board monitors everything from how many times doors are open, how long they are open, how and when I/M drops ice, etc.... Every so many hours, depending on how many times the doors are open, you got ice thru the door, etc... it will shut down and go into defrost mode. When it is time for defrost mode it will run refrig into a "sub zero" state, shut down evap fan, run deeper into sub zero effect, shut down compressor when the thermistors say it's cold enough, turn on defrost heater that melts any frost in evap, then turn compressor back on for a few minutes, then turn evap fan back on. Most techs think that the mother board is defective when in fact the thermistors are not measuring temps correctly within the whole unit. If the thermistor say, hey mother board I'm only 60 degrees in the freezer, then it will keep running the compressor trying to get to zero or -1 or till the darn thing freezes up and stops moving air.
Find another tech to work on your unit, one that has some electronics background and/or computer knowledge. It takes a electronics & computer degree to work on these units and understand how they function.
Doors, some of the new frigs have magnetic door gaskets, if it is not staying shut, replace door gaskets. If door stay open or is leaking air (especially around ice shoot) it can cause some really weird stuff to occur, like thermistors saying I'm cold at the inlet to evap but not at the top of evap and mother board will try to correct it's self by running longer. One other thing about door gaskets, if the drain plug in the evap area is frozen or plugged up, doors won't shut properly and stay shut.
For one thousand dollars, I'll come to Florida and fix for you, 200 to fix refrig and the rest for a good time at Disney World (LOL). Good luck. Contact GE for repair on this unit if you can't get good results from your repairman. Their people, like me, go thru extensive training on these boxes. You can thank our goverment for the energy codes that have gone into effect over the years requiring mfgs to have to keep the cost of running these refrigs down as low as possible, the only way to do this was to computerize these boxes. Good luck
Sep 30, 2009 | GE Monogram ZISS420NRSS 42" Built-In...
Cannot control temp on refrigerator side
thermostat problem replace that if you know how to do that or call a technician who will help you
Sep 12, 2009 | GE Profile PFS22 33" Artica French Door...
Water collects on shelves in refrig.
sounds like a drain clog in the freezer compartment above. remove the freezer rear panel and totally defrost the evaporator area, directly under the evap you see( under all taht ice) a small drain hole that has become frozen over, try defrosting with either a hair dryer( not a heat gun too much heat youl melt everything) or by pouring hot water donw the drain until you get a free flow of water down the tube. after its clear reassemble and you should be fine
Nov 26, 2008 | Kenmore 18.3 cu. ft. Top Freezer...
WARM REFRIGERATOR
Sounds like the damper isn't opening. Put you hand on the Left wall of the fridge side, at the top. If you feel No Air. Then there is your issue. Bad Damper Motor. Also check the back wall of the freezer, there sould be No Frost. If there is then you have a defrost issue. Not a damper problem. One more thing. Make sure when you shut the fridge door, the light goes out. About a half inch or so before the door is completly shut, the light will go out, if not then thats your issue. Let me know how you make out.
Bill
May 12, 2008 | Frigidaire FRS3R5EMB Side by Side...
Left refrigerator door open over night, next day it stopped working
sounds like you sucked in a lot of warm air over night freezer still working? just the refrig went out???easiest solution empty unit completly, unplug and leave doors open let al frost melt out 24 hrs later plug back in and you should be find
Feb 23, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Whirlpool ED2FHEXN Side by Side Refrigerator Logo
208 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
