Question about Kitchen Ranges
Need to switch from 240v to 120v. it has a dual motor but do not have the schematics. can you advise as to the rewiring? been told only 3-4 wires need to be changed, but do not know from where to where.
  • cynthia miller Oct 08, 2010
    Kenmore Stacked Washer and ElectricDryer Model #: 110.88752793. it has a dual motor
  • 10,865 Answers
Hello. Get back with the brand name and model number. That way we can provide the exact schematic u will need. Joe
Posted on Oct 08, 2010
  • Kitchen Ranges Master
  • 1,711 Answers
All you need to is to match the wire according to 4-wire or 3-wire receptacle you have or connecting it direct wire.
We have below a manual for your model at which in page 9 you will find the three possibilities with diagrams, schematics and colours and number.
http://www.managemylife.com/mmh/owner_manuals/2871/KENMORE-Laundry-Centers-L0305420?brand_name_search=Kenmore++110.88752793
How to rewire my century 3hp ac motor part # 8-141443-02 from 230v to 120v
look on the side of motor it has a schematic for 110 volts and 220 volts have to move wires or turn a switch
Sep 11, 2015 | Century Pool & Spa
Wiring instructions to rewire Pentair universal booster pump from 240V(Factory wired) to 120V.
see side of motor for schematic for low voltage you have to move wires or change a switch
Jul 05, 2011 | Pentair 34 HP Pool Pressure Side Booster...
I'm confused about how to properly hook the wiring to the product below. Specifically where does the "neutral" wire attach. I have it all hooked up, but I'm not getting the full 220...
Your 240V wiring is not described clearly, and it sounds like you are confused about 240Volt circuits.
You posted under T104R indoor-outdoor 240volt timer:
http://waterheatertimer.org/images/T-104-control-240V-Load4-35.jpg
Typically a 240Volt cable is 2-wire with ground, and does not have a 'neutral'
A neutral is not necessary to complete 240V circuit.
If your 240Volt cable is a 3-wire with ground, then the neutral connects to terminal A on timer.
Open following links for specific T104 wiring diagrams plus illustration of 2-wire and 3-wire cables, and illustrations and explanation of difference between 120V and 240V circuits:
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html
http://waterheatertimer.org/images/wire-ga-250.jpg
http://waterheatertimer.org/B220C.html
If you have 240Volt cable, then do not move clock motor wires.
The clock motor wires connect to terminals 1 and 3.
240V power from circuit breaker connects to same terminals.
Load wires connect to terminals 2 and 4.
If you are not getting 240V across terminals 1 and 3, then check circuit breaker.
240Volt circuit breaker can be tripped off on one leg, or bad on one side so you get 120V on one leg at timer, and then clock motor does not rotate dial.
http://waterheatertimer.org/How-to-troubleshoot-Intermatic-timer.html
Jul 03, 2011 | Intermatic T104R 208-277Volt 40-amp Timer...
How to wire a intermatic timer T104 240 v to a 120v?
T104 is 240volt timer.
Timer has terminals A 1 2 3 4
T-104 clock motor must receive 240Volts to operate.
Clock motor wires are white-colored and can be seen connected to terminals 1 and 3.
http://waterheatertimer.org/images/Back-of-WH40-2b.jpg
There are two work-arounds for using T104 for 120V.
1) Diagram 1 showing how to change wiring:
http://waterheatertimer.org/images/T-104-control-120V-Load-500.jpg
Move 240V clock motor wires to terminal 1 and A.
Connect 240V Hot leads to terminals 1 and A. This will power the 240V clock motor
Hot wire going to 120V load connects to terminal 2. This wire will be turned on each time timer turns on, and 120Volts will power the 120V load.
To complete 120V circuit, neutral wire that comes from neutral busbar in breaker box connects to 120V load.
To control additional 120Volt circuit, run jumper wire from terminal 1 to terminal 3.
Connect Hot to second load to terminal 4.
2) Second method is to change T104 timer into T103 timer:
http://waterheatertimer.org/images/T-104-control-120V-Load-2-5.jpg
Replace T104 240V clock with identical 120V clock motor from Grainger
http://www.grainger.com/Grainger/INTERMATIC-Time-Clock-Motor-1PNK1?Pid=search
Neutral wires connect to terminal A.
Hot wire from Breaker connects to terminal 1
Hot going to Load connects to terminal 2
Dec 26, 2010 | Intermatic T104 24h 208-277v Mechanical...
How do I wire an intermatic t-103 timer switch
The T-103 has a 120Volt clock motor
From there, the wiring can go two directions depending on your Load voltage (load is the fan, light or motor that timer turns on-off)
Here is a link that shows exact wiring:
http://waterheatertimer.org/How-to-wire-T104-Intermatic-timer.html#T103
When wiring the T-103, steps 1-2-3 are true for 120V or 240V installation:
1) A white Neutral wire is always connected to terminal A (Neutral wire connects to Neutral busbar in breaker box)
2) A black Hot wire is always connected to terminal 1 >> this hot wire can come from 120V or 240V breaker
3) Black wire going to Load (fan, light, motor) is always connected to terminal 2
The following step is true for 120V Load
4) if Load is 120V, then white wire from Load connects to terminal A
The following steps are true for 240V Load
5) Only the neutral wire connects to terminal A as described in (1
6) The second Black hot from breaker box (240V has 2 hot wires) connects to terminal 3
7) The second White going to Load connects to terminal 4
Here are 2 more links that show how 120V and 240V circuits are wired
http://waterheatertimer.org/See-inside-main-breaker-box.html
Oct 21, 2010 | Intermatic T103 Indoor 120-Volt 40-amp...
How do you wire a intermatic t103
I'm looking at the T-103 sitting here in my office.
Terminals are labeled: A 1 2 3 4
I have about 10 different Intermatic timers on the shelves & each is a bit different
The T103 has a 120Volt (or 110V) clock motor
You need a white Neutral wire to operate the T103 clock
120V: Let's say your Load (light, fan, pump) is 120V
The white Neutral from breaker box connects to Terminal A
The 120V black Hot wire from breaker box connects to Terminal 1
The black wire going to Load (fan, light, motor) connects to terminal 2
The white wire going to Load connects to terminal A along with the Neutral
Ground wires connects to green ground screw
If your wires from breaker and wires to load are wired in reverse, the timer will turn ON the Load but the timer will not shut the circuit OFF.
To test which wire is Hot and Neutral, look at explanation at bottom of page.
240V: Let's say your Load is 240 Volts (or 220 Volts)
The clock motor is still 120V so you still need a white Neutral wire connected on Terminal A
Now you have 2 Hot wires coming from breaker box
Hot wire 1 from breaker box connects to Terminal 1
Hot wire 2 from breaker box connects to Terminal 3
Wire 1 going to Load connects to Terminal 2
Wire 2 going to Load connects to Terminal 4
What if you don't have a Neutral wire and you are wiring a 240V circuit?
240V circuits normally have 2 hots and a ground, but no neutral
Buy the T-104 timer
The T-104 has a 240V clock motor
Wiring for the T-104 is exactly the same as 240V wiring shown above for T103 EXCEPT there is no Neutral on Terminal A, and Terminal A is bare
How to test which wire is Hot
Test requires wires with live electricity >>> this is not advisable without precaution
Stand on dry boards, do not touch anything metal, wear dry clothes, do not hold screwdriver in mouth, wear gloves, tape tester leads to wood sticks so hands are away from power
Remove wires from terminals
Separate wires so they can be tested
Turn on power
Test each wire to bare ground wire
Tester lights up on Hot wire(s)
If circuit is 120V, then there is only one Hot wire
If circuit is 240V, then 2 wires will test hot to ground >> these wires will be Hots 1 & 2
Test assumes circuit breaker is functioning normally.
How do you test for neutral?
If you have 120V line with only 1 hot wire, then one of the white wires will be Neutral?
Test Hot wire to each white wire
Tester lights up on neutral
Oct 17, 2010 | Intermatic & Indoor/Outdoor Rain Tight...
My intermatic model T104 was not activating. I bought a new one yesterday but sill not activating. Howcan I prove the unti when it has two white cable only. Please advise asap. Thanks
T104 is 240V timer with 240V clock motor.
-This timer will not work for 120V circuits.
-Test your two wires for 240V.
-If your load (lights, motor etc) is 120V then you need the T101 timer.
Confusion about cables
When you say 2 white cables, does each cable have a black and white line?
If you have two cables with black and white lines, then one comes from breaker box, and the other goes to load ( water heater, motor, lights etc.)
How to wire T104 for 240V
How to wire T101 for 120V
Sep 16, 2010 | Intermatic Inc. EJ500C Digital Wall Switch...
Compatability with US 240v 60HZ 1phase wiring?
It should work OK The US system is 240V single phase (split) into two 120v branches. Aussi system is hot on both sides, with a center ground (a virtual ground system) Connect the 2 main wires (usually brown and blue) to the 240 (black and red), and connect the grounds (Green/yellow to green), and leave the neutral wire off.
Jun 14, 2008 | Saeco Royal Professional Espresso Machine
Kitchen Ranges Logo
99 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
