Question about Acer Aspire One PC Notebook
Having problem connecting aspire to my sony 42 plasma, cable is hooked up properly vga to dvi but no picture in any of the video sources. right clicking on netbook and accesing the properties doesnt change anything, what do i do
  • Acer Master
  • 3,247 Answers
Depending on which version of windows you are using - you will need to select the monitor/ TV setting option from the laptop. This is what I believe you have already done. Have you tried with different display resolutions?
Finally do you actually select the TV from the F4/ F5 keys on the laptop. Do you see the laptop screen go blank briefly?
Posted on Oct 08, 2010
Link my acer aspire 592o laptop to my panasonic plasma
1. S-Video – This is probably the most commonmethod out there currently because an S-Video cable is cheap as heckand just about every TV under the sun has a S-Video port. You’ll haveto make sure you laptop is equipped with this port. Remember, there aretwo types of S-Video cables: 4-pin and 7-pin. Mostlaptops and PC’s are equipped with a 7-pin port, so if your TV only hasa 4-pin S-Video port, then this method will not work.
2. VGA – If you have a HDTV, then you will bebetter off connecting using a VGA cable. It gives much better qualitythan S-Video and as with S-Video, the cable is very cheap. You usuallywon’t find a VGA port on regular TV’s though, so this option is if youhave an HDTV.
3. DVI - DVI stands for Digital Visual Interfacewith “digital” being the key word there. The digital signal will give ahigher quality picture than either S-Video or VGA. Of course, yourcomputer will need to have a DVI connection and your TV will need to bean HDTV. This cord is definitely not cheap, it ranges anywhere from $40to $80.
4. HDMI – Using HDMI will give you the best qualityby far. No computers that I know of yet have HDMI ports, but you canget a DVI to HDMI cable to connect it to your HDTV. HDMI is compatiblewith DVI.
5. Scan Converter Box – This is the last methodthat I could think of and it involves using a scan converter box, whichtakes a VGA signal and converts it into S-Video or component video.
Here’s a graphic I created with some pictures of the various cables:
Hope this helps someone! If you have any other ideas or suggestions, please feel
Jan 26, 2010 | Acer Aspire 5920-6335 Laptop
All picture and no sound
Rick:
simply unplug--then replug--your HDMI cable. Or also go into the audio setup menu and reapply the "automatic" setting for HDMI to get the sound to work. I don't know if Sony can do anything about this or not in a firmware upgrade, but what it can do is try to simplify the labeling on some of the sound settings.
Let me know
Dec 26, 2007 | Sony Playstation 3 (PS3) Console
Esa 42 in plasma.....out of range?
i have a plasma tv (china brand) when i start the TV the remote control for other devices are not working, only working if the remote is too close to the sevices or by reducing the brightness to its minimum level (zero level..no brightnesss)
i need help strange fault
May 05, 2009 | ESA PDP4294LV1 42 in. EDTV-Ready Plasma TV
No sound when my computer is connected to my Sony Bravia TV
If your computer has a svga output use input 7 on tv with vga to vga cable and 3.5-3.5 Radioshack 42-2387 cable for audio for best results. If you use the dvi to hdmi on input 6 on tv use 3.5- rca Radioshack part number 42-2551 1/8=3.5mm.
Apr 20, 2009 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Is there someway to hook up our Hitachi 42HDS69 to our laptop
Your computer should have a DVI port to make this possible since your TV dont have a VGA port. If your computer have a DVI port then an HDMI/DVI cable is all you need. This allows you to connect you computer or laptop to you tv through the HDMI connection on your tv.
Dec 31, 2008 | Hitachi 42HDS69 42 in. Plasma Television
Problem connecting cable wires for Sony PFM-42B2 42 in. Plasma TV
I have this screen and my version does not include audio - I need to connect to an external amplifier, in my case my home theater.
Nov 18, 2008 | Sony PFM-42B2 42 in. Plasma HDTV
How do i make my hp computer connect to my samsung tv
First you have to make sure your TV has the right video input like VGA or DVI.
Then Your computer has to have DVI if the TV has DVI connector.
If the TV has VGA and you know that all computers come with at least VGA, all you would need is a VGA video cable.
Hook the cable to the VGA port, then set your TV to the input that coincides with VGA.
then you can set the resolution in the control Panel > display to the best resolution that gives you a good picture on the TV.
Please remember to rate all users who assist you for free :)
Oct 04, 2008 | HP Computers & Internet
Dvi to vga
You will not benefit from the DVI input unless you have DVI output on your computer. The great advantage of DVI is that the picture is transferred in digital form all the way from your computer to the individual pixels on the monitor. If you only have VGA output on your computer then you will never get a better picture than by using a good quality VGA cable to link that to the VGA input on your monitor.
The DVI plug is designed to carry both digital and analogue (VGA) signals on the various pins, so "adaptors" exist to allow a VGA monitor to attach to a DVI output on a computer. Monitors may also support VGA input from their corresponding DVI input sockets, but the picture quality will never be better than by using a good VGA cable because it is still not using the digital capability of the DVI interface. What's more, because you may need more adaptors and thinner conductors in the cable, you will probably achieve a marginally poorer picture than with VGA to VGA.
When you next buy a PC or a new video card, get one with DVI to take advantage of your new monitor. In the meantime, your best bet is a quality VGA to VGA link.
Sorry that's not what you were wanting to hear, but I hope it will help you avoid further frustration.
Sep 20, 2008 | Envision EN-985e Monitor
Trying to use rgb input
Cable TV: Connect the LCD TV to the cable with CATV and Digital cable. Preset the cable TV channels into memory with Auto Scan function when using a cable TV system. Make sure you set the INPUT SOURCE properly (TV, VGA, S-Video, etc)
Mar 10, 2008 | ViewSonic VPW425 42 in. Plasma HDTV
How to connect samsung plasma tv to a toshiba laptop?
to get high definition you will need to use either the vga or dvi output from your notebook and connect to the DVI input on the tv, vga connection on the tv will only give 480i whereas dvi will give upto 720i
Nov 04, 2007 | Samsung SP-R4232 42 in. Plasma HDTV
Acer Aspire One  PC Notebook Logo
71 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
